#1 |
Hypermodder
Project Slow
Ok after 6 months better try and put some order to some pictures that have been posting.
With lot of old bits floating around my pit and some stuff from work decided to build my self a Nas / small server (not decided yet). On Side note as everyone says this this is the first case I have ever try to build bit of a learning curve and alot of reading to be done. With a Quick chat with the powers that be a rather large sheet of 2mm stainless steel was aquired ![]() ![]() Plates cut down tacked and started to tig together cube ![]() ![]() Tig Welds sanded clean ![]() 8mm Perf mesh cut to size ![]() Mesh and Fan Mount ![]() can you Guess what it is yet ?
#2 |
Minimodder
love that Hilti!
![]() Lookin' forward to this lil' Cube
#3 |
Ultramodder
Good start!
Looks as if its going to be a Mini itx build? with a 120mm fan? |
#4 |
Making You Feel Old Since 2010
Simple and cool- love it!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#5 |
long live the pc
nice start mate. i like your skills
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl, ![]() |
#6 |
Hypermodder
Slow by name Slow by nature
![]() some little case feet been added ![]() MB plate marked out read for some more tapping
__________________
I must not fear, Fear is the mind-killer.
Fear is the little-death that brings total obliteration. I will face my fear. I will permit it to pass over me and through me. And when it has gone past I will turn the inner eye to see its path. Where the fear has gone there will be nothing. Only I will remain |
#7 |
Hypermodder
a square line not something I am used to in my job
![]() A tile saw is a very hot method of cutting but when needs must ![]() Time to start some filing
__________________
Fear is the little-death that brings total obliteration. I will face my fear. I will permit it to pass over me and through me. And when it has gone past I will turn the inner eye to see its path. Where the fear has gone there will be nothing. Only I will remain Last edited by Big_malc; 21st Aug 2012 at 20:25. |
#8 |
Hypermodder
aluminium so much nicer than stainless steel but not as forgiving
__________________
Fear is the little-death that brings total obliteration. I will face my fear. I will permit it to pass over me and through me. And when it has gone past I will turn the inner eye to see its path. Where the fear has gone there will be nothing. Only I will remain Last edited by Big_malc; 21st Aug 2012 at 20:21. |
#9 |
Hypermodder
Time for a little Hdd mount for 2 drives 16gauge Stainless drilled and bent
![]() mmmm Shiny ![]() Two old drives mounted up for setting size ![]()
__________________
#10 |
Hypermodder
Wonted to keep the Hdd tray and the MB tray as one so bit more marking and some M5 tapping sorry forgot to take some pics.
![]() cutting the M5 bolts down I nicked the MB plate but it wont be seen another one to put down to stop rushing and pay attention
__________________
Fear is the little-death that brings total obliteration. I will face my fear. I will permit it to pass over me and through me. And when it has gone past I will turn the inner eye to see its path. Where the fear has gone there will be nothing. Only I will remain Last edited by Big_malc; 21st Aug 2012 at 21:13. |
#11 |
Hypermodder
__________________
#12 |
Hypermodder
Bad light and a cam on phone dont make good pics
__________________
Fear is the little-death that brings total obliteration. I will face my fear. I will permit it to pass over me and through me. And when it has gone past I will turn the inner eye to see its path. Where the fear has gone there will be nothing. Only I will remain Last edited by Big_malc; 24th Aug 2012 at 17:33. |
#13 |
Hypermodder
if I pull my finger out I might finish something started months ago
few coats of white primer ![]() ![]() ![]() and a little bit of gray ![]() and a sneak peek of colour ![]()
__________________
Fear is the little-death that brings total obliteration. I will face my fear. I will permit it to pass over me and through me. And when it has gone past I will turn the inner eye to see its path. Where the fear has gone there will be nothing. Only I will remain Last edited by Big_malc; 9th Dec 2012 at 20:24. |
#14 |
Multimodder
That IS small! What a pack! It's impressive when every single centimetre is organized to fit properly! Great Job!
#15 | |
Hypermodder
thanks Ra6 could be about 70mm smaller but what you get for rushing and not planning.
__________________
#16 |
Hypermodder
__________________
#17 |
Hypermodder
__________________
| Thread Tools | |
| View Mode | |
