Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 2nd Feb 2012, 12:13   #1
Lankuzo
CPC Refugee
Lankuzo's Avatar
Lankuzo should be considered for presidentLankuzo should be considered for presidentLankuzo should be considered for presidentLankuzo should be considered for presidentLankuzo should be considered for presidentLankuzo should be considered for presidentLankuzo should be considered for presidentLankuzo should be considered for presidentLankuzo should be considered for presidentLankuzo should be considered for presidentLankuzo should be considered for president
Windows freezes after 5 seconds
Hey all
Im having some problems with my main system. Windows 7 seems to stop working 5 seconds after it has loaded onto the desktop.
I thought it might be down the the ram as I had been playing with the overclock yesterday but I've since changed the ram to mushkin 4gb and it still does exactly the same.
I've booted into safe mode and it works fine so while I was there I decided to backup anything I might want to keep.
I have sort off run out of ideas and thinking a new install of windows might fix it. Unless its a hardware issue.
Could the motherboard be messed up?
Any help please guys
__________________
Main:Sabertooth : I7 950 : GTX580 : Crucial M4 124GB : 6GB OCZ 2000mhz : Custom 360 Loop
1T F3 : CM Stacker 831 : Corsair HX750 : Samsung 24"
HTPC:Gigabyte H61m-D2H : G620 : 4GB Mushkin : 30GB SSD : 2TB F4 : Samsung 40"
Lankuzo is offline   Reply With Quote
Old 2nd Feb 2012, 12:43   #2
Jester_612
"Jammy..."
Jester_612's Avatar
Jester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for president
What do you mean by it stops, is it a BSOD? 'cause that'll point to the OC.
__________________
- Jes Vindeqx
i5 2500k @ 3.97Ghz on stock
EVGA GTX 670 FTW @ 1275 Mhz
Jester_612 is offline   Reply With Quote
Old 2nd Feb 2012, 12:46   #3
bdigital
Is re-building his PC again
bdigital's Avatar
bdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpit
Have you tried disabling aero? I had a similar issue that turned out to be my psu, which once the gpu was pulling a decent amount it just froze the whole system.
changing the psu sorted it
__________________
My photography website: http://www.polarityphoto.co.uk Please share! || Follow me @polarityphoto on Twitter|| My Flickr ||
Check out my Apline White TJ07 - Case Mod and Water cooled build. http://www.flickr.com/photos/6188486...7631486959032/
bdigital is offline   Reply With Quote
Old 2nd Feb 2012, 13:57   #4
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.
Is your system overclocked now? If so, restore everything to default. Start with that.
Also check your temperatures, if you can open a program quick enough.
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features.
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is offline   Reply With Quote
Old 2nd Feb 2012, 14:27   #5
Lankuzo
CPC Refugee
Lankuzo's Avatar
The clocks were default and It wouldn't open any programs in time.
I just reinstalled windows and all seems ok now on the mushkin ram.
Will try my ocz ram in a mo
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
