#1 |
Monimidder
EK Waterblock Problems
Took my system down today and stripped all the watercooling for its clean and check up.
Opened up the 580 block and found: - ![]() ![]() And in the EK Supreme CPU block: - ![]() The above is a little harder to make out but around the edges (inside the seal line) there is corrosion on both lower and upper parts. Have left this in a high res pic as its more noticebable. These blocks were bought last Jan, right in the middle of the problems EK had with the nickel plating. I only run pure distilled (actual distilled not de-ionised) with a silver coil. Gutted to say the least, am now in the process of going back to air until I can sort it
__________________
i5 2500k@4.5ghz, ASRock Extreme7 Gen3, 7970, 16GB GSkill RipjawZ 2133Mhz, Coolermaster Hybrid Pro 1050W, 128GB Crucial M4, 60GB Vertex 2E, 2TB Seagate, Dell U2711
#2 |
Resident Bulldozer Guru
I think EK might still be offering to replace it should there be any corrosion. It is faulty goods after all.
__________________
Dozy Beast: AMD FX8120 | Thermalright Archon | Asus Crosshair V Formula | 16GB (4x4GB) Corsair Vengeance LP | Asus Xonar DX/XD | 2X SLI KFA2 550Ti White Edition | Silverstone SSTG1000W | Silverstone Raven RV-02B V1.7 | OCZ Agility 3 60GB | 1.5TB in Drives | Lite-on Blu-ray ROM Acer H226HQL | Sennheiser HD 485s | Creative Gigaworks T40s | Logitech G13 | Microsoft Sidewinder X6 | Cyborg R.A.T 9 |
#3 |
Monimidder
Yeah just been checking up - they have 24 month warranties which is a relief. Not sure if they go back to Scan or EK though.
__________________
#4 |
Email scan, they should get back to you on monday.
__________________
#5 |
Monimidder
Good job I checked, got the cpu block from Aquatuning! Submitted RMA requests for both, although I think both blocks will be going for sale if they are swapped for new.
Too many good watercooling manufacturers out there that just don't suffer these quality issues EK has been blighted with.
__________________
#6 |
Panda have Guns
Useful thread in my signature if they want to play legal talk!
__________________
|Fractal Design Define R3, Black Pearl (Case)|ASUS P8P67 Deluxe (Motherboard)|Intel® Core™ i5-2500K (Processor)| |G-Skill 8GB DDR3 1600mhz Sniper 1.25v (Memory)|ASUS GTX 670 / Gigabyte GTX 670 (SLI Graphics)| |Corsair Professional Series Gold AX 850W (Power Supply Unit)|Asus Xonar D2X PCI-Express (Sound Card)| |OCZ Vertex 3 120GB (Solid State Drive - Boot)|OCZ Vertex 3 240GB (Solid State Drive - Games)|
#7 |
User
As was pointed above, send them back for Copper/Gold or Plexi versions. Avoid Nickel EK as they corrode. Oh and, avoid Nickelback as well.
#8 |
Technophile(and yes, thats 724Mb/s)
I don't think they'll replace it if you open up as it voids the warrenty...
__________________
i5 3570k @ 4.6GHz (1.28v) on custom water loop/ Watercooling how-to, Asus Maximus 5 Gene, 16GB Corsair Vengence 1600MHz (2 black, 2 red), Sapphire Radeon HD 5870, 128GB Crucial M4, 3 x Samsung F1 1TB in RAID 5, Xigmatek Elysium, Enermax Revolution 85+ 850W, Corsair K60, Corsair SP2500 speakers, Dell U2311H & Asus VK222W. |
#9 |
Monimidder
There is no issue with warranty as it is a known manufacturing defect. If memory serves, they will not warranty leakages occurring after the warranty sticker is removed.
Think that came from EK themselves when it all kicked off last year. Sent from my HTC Desire using Tapatalk
__________________
#10 |
User
Even the new Nickel EK's still corrode.
http://www.evga.com/forums/tm.aspx?m=1229439&mpage=1 Specifically tell them to send back a Copper version. |
#11 |
Monimidder
Thanks for heads up John, had no idea there were still issues. Replacements for both in copper and then sell them. Even my first res cracked and was replaced.
Like the look of the cuplex blocks and are highly rated. Will prob not bother with Gpu now until the card is replaced in a few weeks/months. Last EK block I will buy. Quite like the comp fittings although for my new project its bitspower all the way. Sent from my HTC Desire using Tapatalk
__________________
#12 |
User
Yep, Aqua currently makes excellent blocks. Their 480 block was the best out of all, and the Kyro's are also nice blocks.
#13 |
Banned
Think swiftech might be the way forward for me
#14 |
Monimidder
Love the bling look of the Cuplex Nickel over the Swiftech and there is virtually nothing in it in terms of performance. I nearly went with Swiftech XT last year but went ended up going with EK...
__________________
#15 |
jack of all trades
Pete, the warranty that you loose on opening up is just the non-leek warranty; the material qualities etcetera are still covered - EK had a lot of people complaining about damaged O-rings which they had damaged putting the block back together leaking over their stuff. The stickers are just there to make an easy proof that the end user had damaged the O-ring not the manufacturer.
#16 |
Monimidder
Hehe, Scan refused the RMA because the warranty sticker is broken! Tried to explain on the phone that this is not the terms of the warranty but have been asked to show Scan where it states this on their (EK's) terms.
I have raised a ticket at EK. Anyone have a direct link to an EK warranty document that clearly states this? I can;t find anything on the site tbh.
__________________
#17 |
jack of all trades
EK's Terms of Use
It doesn't mention the sticker in there at all unfortunately... And I can't find a definitive reference to it... it's just one of those things that is widely known (including scan, they've been spanked by EK a few times for mucking around over it) I'm sure if you trawled through XS for long enough you'd find something from Eddy or Tiborrr, but even my patience has it's limits. |
#18 |
Monimidder
Yeah I know it, you know it Scan probably know it. See what EK come back with.
I've a thread in the Scan forum below so guess its all better posted down there now. Was frustrated when I got the first reply to the rma and am much calmer now. Just want scan to handle the rma now, they got the block. Postage to scan, back and then to EK is a fair hit! Sent from my HTC Desire using Tapatalk
__________________
#20 |
Monimidder
Top man Asura many thanks +rep bro
Should make my case much easier to process
__________________
| Thread Tools | |
