Hiya guys i am pretty new to this forum but have been on others for a couple years now.I will start by saying Hi to all the incredible Modders and builders on this site and hope i will have a ball here and fit right in. Ok so to start the build Log: The Victim: White Nzxt Phantom with Blue Led's Venom Build Specs: Intel i7-2700k AsRock Fatal1ty Professional Z68 Gen 3 4 Gig's Corsair Dominator GT's 2133 C9 1.5v PowerColor 2 Gig HD6970 2 OCZ 60 gig SSD's Vertex 3's Raid 0 2Tb WD Black Edition 64mb Cache Cougar G1050 Power supply Asus Dual Layer Burner Antec Veris Multimedia Station Premium Cooling: Rasa Pump/Res Combo Rasa RS360 Radiator for Top Rasa CPU Block Magicool Extreme 240 Bottom Radiator Ek Nickel HD6970 reference Block EK Nickel Dominator Ram Block EK-MultiOption RES X2 - 250 Advanced Reservoir (8 Total Ports) 10 Akasa Viper 120mm Fans 83.63 CFM 1 Akasa Viper 140mm Fan 110.61 CFM 10 feet Primochill Primoflex Pro Tubing (Black) 8 Bitspower 1/2"ID X 3/4"OD Compression Fittings 3 Bitspower 1/2"ID X 3/4"OD Rotary 45 degree Compression Fittings 3 Bitspower 1/2"ID X 3/4"OD Rotary 90 degree Compression Fittings Silver coil and Biocide Yellow Anti Kink Coils Other Parts: 100 feet Yellow Parachute Cord 550lb 100 feet Black Parachute Cord 550lb 2 white Cathodes 2 Led strips 2 Frozencpu Led Res Plugs. Handful of white Led's Plexi Glass C Channel Molding Black Vinyl meterial Pci-e Slot covers (Black) Rivets/Screws and other hardware. 2 Quarts Automotive Primer 2 Quarts Lacquer Automotive Chrome yellow Base Coat 1 Quart Lacquer Automotive (Jet Black) 2 Quarts Lacquer Automotive Gloss Clear coat 2 Cans of Adhesion Promoter Some metal Stock (I think i got everything there in the list) Will add more shortly. Stay tuned.
Update: Finished build but will add the complete Log soon as i can: I was in a Mod of the Month contest on another forum which i Won but i was not allowed to post the build anywhere else while the contest was going on so now the log is way behind. And i am In the Middle of a new Sponsored NZXT Switch 810 build so as soon as i get the chance i will update the whole work log.Its going to be allot of work to move it so i need at least a whole day set aside to do it. Thanks for understanding and hope you like the build.
Also here is a little Video if its allowed that shows allot of the build Process. Enjoy: http://youtu.be/NkFbwOR2Pvc
