Reply
Thread Tools View Mode
Old 5th Feb 2012, 18:58   #1
stallo709
Multimodder
stallo709's Avatar
stallo709 has yet to learn the way of the Dremelstallo709 has yet to learn the way of the Dremel
Mahatma
BASE.
we begin with measures that will be of 75x45 cm.
with these measures can prepare calmly what I have in mind without having to deal with space.
the skeleton of the base will be assembled with the strips of aluminum, and subsequently coated with the plex.
on it there will be a large number of cacti that surround the entire base,with the plex will be load-bearing part of some effects of light that I hope very suggestive.
but not only, the base will also host two radiators for cooling that will be arranged laterally.
I am convinced that the arrangement of the tubes of liquid, and sleeving of the cables will make you smile.
I can only say that the shape of the houses will be a bit special,but I will try to integrate the hardware with the topic of modding.
vamos...
already from the base you can imagine the massive size of this mod.
The strips are then secured to the wood for give stability.
for now ... ciao
Stallo709
stallo709 is offline   Reply With Quote
Old 5th Feb 2012, 20:55   #2
KidMod-Southpaw
Super Spamming Saiyan
KidMod-Southpaw's Avatar
KidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming Saiyan
That's bloody massive! Can't wait for more!
__________________
Project Logs: Refraction - Steampunk Flash Drive - Steel; Sleek; Slate
BitFenix Prodigy - Gigabyte Z87N - Intel 4670K - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - M4 128GB - WD Red 1TB X2 - H60 - Antec 650W - Dell U2312HM - Poker MX Red - Sennheiser HD 598
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 6th Feb 2012, 11:43   #3
stallo709
Multimodder
stallo709's Avatar
unfortunately guys when building from scratch is so , there is little to see at this stage of modding.
to give robustness to the entire base will us the plywood of 6mm.
I have in mind a series of special effects for this mod.
the structure must be especially designed in order to avoid having to repeat twice the assembly operation.
namaste
Old 7th Feb 2012, 08:59   #4
stallo709
Multimodder
stallo709's Avatar
aluminum structure.
continues
Old 7th Feb 2012, 09:07   #5
stallo709
Multimodder
stallo709's Avatar
The last picture is just to let you know how it will be the base.
where there are the pink circles, there will be the succulent plants.
while the two radiators are placed laterally...
am crazy
Old 7th Feb 2012, 11:27   #6
stallo709
Multimodder
stallo709's Avatar
begin to cover the entire structure.
1) disegno om
2) incision
Old 7th Feb 2012, 11:41   #7
stallo709
Multimodder
stallo709's Avatar
3) finish contours
4) paint wood
steel wool to make the surface paintable.
protective coating.
these 4 pieces are to be painted with a technique which is called " shabby chic ".
continued...OM NAMAH SHIVAYA
Old 8th Feb 2012, 10:48   #8
stallo709
Multimodder
stallo709's Avatar
is the turn of the aluminum profiles.
same treatment with steel wool for the outer part of the base.
the separation between aluminum and wood will not be noticed at all.
prepare the basis for the final coating with tape to protect the interior of the base from the residues of dust.
Old 8th Feb 2012, 11:12   #9
stallo709
Multimodder
stallo709's Avatar
shabby chic effect.
decorative art whose origins date back to Louis XV
Is primarily used to give an effect of aging and wear to the wood.
means the finishing technique that reveals the grain of the wood or the color of paint.
There are variations to this style of finishing, especially on the shades of color, but in any case we see emerge, with the desired effect of wear, the color below.
The style called Country Chic, involves the use of light colors on the surface, and darker colors that appear after the treatment of wear.
Shabby Chic is the word to signify the contrast between the elegance and wear.
With this technique 'can be reused in new and old furniture inexpensively. It 'a romantic style that has the flavor of the simplicity of the objects experienced.
also the color of the future sleeving must be matched with the base...
a first coat of black tempera very diluted with water to.
this technique can be realized in many ways, everything depends on what you want.
with a layer of resin in the red symbol, I conclude this first part of the work.
the base is nearly completed, you just cover it with plex and start building the top.
I leave you with a small preview of what you see in the next episodes ...
Old 8th Feb 2012, 11:19   #10
stallo709
Multimodder
stallo709's Avatar
ciao
Old 8th Feb 2012, 11:53   #11
mat0tam
Mr I Dont Know What I Want
mat0tam's Avatar
mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!
Gorgeous so far
__________________
i5 2500K l P8Z68-V LX l 6870 l 8GB 1600MHz l Samsung 840 EVO (240) l OCZ Vertex 3 l 750W OCZ
mat0tam is offline   Reply With Quote
Old 8th Feb 2012, 23:20   #12
dark_avenger
Ultramodder
dark_avenger's Avatar
dark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysis
Sub'd
dark_avenger is offline   Reply With Quote
Old 9th Feb 2012, 09:09   #13
stallo709
Multimodder
stallo709's Avatar
Originally Posted by mat0tam View Post
Gorgeous so far
Originally Posted by dark_avenger View Post
Sub'd
thanks guys
Old 9th Feb 2012, 09:49   #14
stallo709
Multimodder
stallo709's Avatar
hello all.
for the interior of the base I thought to cover all of with the acustic moquette.
the moquette makes things much cleaner and ordered.
the four symbols will be illuminated from behind with LED.
the two radiators from 120 will be disposed at the two ends of the base.
To be continued...
Old 17th Feb 2012, 17:58   #15
stallo709
Multimodder
stallo709's Avatar
plex has arrived, now we can start with the top.
I can finally give free rein to my imagination.
the color of modding is fully revealed, I want to match the effect schic shabby purple with the plex of the same color.
the lights, the sleeving, and the different effects that I'm going to use, should never lose sight of the sobriety of the colors I chose for the structure.
the upper structure for the most part will be in a plex, and surrounded with the wood paneling, always with the same effect.
vamos...
continued
Old 21st Feb 2012, 10:30   #16
stallo709
Multimodder
stallo709's Avatar
ciao!
base completely covered
tank " LAVA LAMP "
I want to recreate this effect in the PC.
ciao
Old 21st Feb 2012, 15:26   #17
TheBigFella
U jelly?
TheBigFella's Avatar
TheBigFella has yet to learn the way of the Dremel
Incredible
Really like colors, they go together...
TheBigFella is offline   Reply With Quote
Old 21st Feb 2012, 19:27   #18
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
I have no idea where this is going, but it should be fun to watch.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 21st Feb 2012, 19:33   #19
kinghong1970
Just a Clumsy Ape
kinghong1970's Avatar
kinghong1970 has yet to learn the way of the Dremel
no kiddin... aluminum, lava lamps... what else can we ask for?
kinghong1970 is offline   Reply With Quote
Old 21st Feb 2012, 21:46   #20
stallo709
Multimodder
stallo709's Avatar
a modding crowds... but fun
Reply
Tags
(5)16/18/9/26/5/19
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
