Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 5th Feb 2012, 20:37   #1
AoE
Banned
AoE is a hoopy frood who really knows where their towel is.AoE is a hoopy frood who really knows where their towel is.AoE is a hoopy frood who really knows where their towel is.AoE is a hoopy frood who really knows where their towel is.AoE is a hoopy frood who really knows where their towel is.AoE is a hoopy frood who really knows where their towel is.AoE is a hoopy frood who really knows where their towel is.AoE is a hoopy frood who really knows where their towel is.AoE is a hoopy frood who really knows where their towel is.AoE is a hoopy frood who really knows where their towel is.AoE is a hoopy frood who really knows where their towel is.
Evga 580 Block
Started research into watercooling, basically its been brough to my attention that I may have some trouble getting a evga 580 water block? any recommendations I think i'll be going with an EK Kit, but dont include gpu blocks
AoE is offline   Reply With Quote
Old 5th Feb 2012, 20:39   #2
longweight
GIFted
longweight's Avatar
longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.
Can you not just buy it from EVGA?
longweight is offline   Reply With Quote
Old 5th Feb 2012, 20:42   #3
thetrashcanman
Angel headed hipsters
thetrashcanman's Avatar
thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.
This block will work mate http://www.scan.co.uk/products/ek-fc...plusen-(nickel)
__________________
i7 3930k/watercooled on 360 rad/Asus Rampage IV Extreme/16Gb Corsair Dominator GT 2133Mhz/Gtx 480/2 x Corsair Force GT 240Gb RAID0 /Silverstone TJ11/Enermax Platimax 1500W
thetrashcanman is offline   Reply With Quote
Old 5th Feb 2012, 20:47   #4
AoE
Banned
Originally Posted by thetrashcanman View Post
thanks man, will this work for certain? and do you know if the card you sold me or both of them had heatspreaders? apparently some 580s dont as evga changed the profile of the processor slightly
Old 5th Feb 2012, 20:51   #5
thetrashcanman
Yeah because EVGA are a bunch W**KERS! all cards that had torx's instead of normal screws had no Intergrated Heat Spreader on them, and yes mate that will work for definite
__________________
Old 5th Feb 2012, 20:54   #6
AoE
Banned
did you have a block on it before selling? need to for 100% man before I buy this?, need it to make contact with processor.
Old 5th Feb 2012, 20:55   #7
thetrashcanman
No I didn't mate, they where never watercooled and just read the description of the block on scan's website if your don't believe me chum
__________________
Old 5th Feb 2012, 20:58   #8
AoE
Banned
ahh i see it now, IHS_less cards
Old 5th Feb 2012, 20:59   #9
thetrashcanman
That's it, as for the rest of your watercooling gear, what else you thinking of doing, what case you using and you going with compression fittings or barbs?
Oh and did you try overclocking the card?
__________________
Old 5th Feb 2012, 21:01   #10
IvanIvanovich
будет глотать вашу душу.
IvanIvanovich's Avatar
IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.
If you can't get the evga branded hydro copper blocks and actually want them, you might be able to get the plain swiftech ones, they are the same thing. if you wanted to go a cheaper route, and have gpu block that you can use on your next card, swiftech also do a pretty decent looking full cover heatsink to use with a universal block.
I am still skeptical of EK nickle plated. I know they say they have it sorted but... I would still stick to copper myself if buying EK.
Heatkiller blocks look pretty good too, might have a look at them as well if you haven't.
__________________
[end of line]
intel i5-750 | evga p55 sli | 8gb mushkin blackline | evga gtx670 | 240gb mushkin chronos dx
| creative titanium hd | mushkin 580w | gh60 custom | logitech mx revolution | achieva shimian qh270
IvanIvanovich is offline   Reply With Quote
Old 5th Feb 2012, 21:09   #11
Bladesingerz
Supermodder
Bladesingerz's Avatar
Bladesingerz has yet to learn the way of the DremelBladesingerz has yet to learn the way of the DremelBladesingerz has yet to learn the way of the Dremel
If you want to be sure the EK block will fit on your card you can use http://www.coolingconfigurator.com/ to be sure
Bladesingerz is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
