Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th Feb 2012, 13:01   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Bethesda promises Skyrim Creation Kit due Tuesday
Promises a bonus surprise to boot.
http://www.bit-tech.net/news/gaming/...creation-kit/1
brumgrunt is offline   Reply With Quote
Old 6th Feb 2012, 13:18   #2
Fizzban
Man of Many Typos
Fizzban's Avatar
Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.
Excellent! This means lots of high quality mods in the near future.
__________________
-Banana in disc drive error-
To win the battle, is to be prepared to die - Miyamoto Musashi
Originally Posted by RedFlames View Post
Asking to pick between the main parties is like asking which testicle you want to be kicked in, you're gonna get kicked the nuts whoever you pick... Just have to hope whoever you pick aren't wearing steelies...
Fizzban is offline   Reply With Quote
Old 6th Feb 2012, 13:27   #3
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
If the surprise is a high-res texture pack (strongly hinted at by suenstar in the Skyrim thread), then it might finally be time to retire the old 280 and upgrade to something with a bit more grunt.
If only I had any money
__________________
6700K | Z170I | Liqtech 120X | EVGA GTX 980Ti SC | 16GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 6th Feb 2012, 17:36   #4
Warrior_Rocker
Holder of the sacred iron
Warrior_Rocker's Avatar
Warrior_Rocker has yet to learn the way of the Dremel
I wish this meant they were fixing the issues plaguing the PC version of the game including mouse input lag, quiet game volume, and menus that frustrate users to say the least. The game itself may be fun but does not justify releasing a half-baked port.
Warrior_Rocker is offline   Reply With Quote
Old 6th Feb 2012, 18:27   #5
improprietary
FT03 is a bitch to watercool
improprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremel
BetterBodies BetterFaces!!! =D
improprietary is offline   Reply With Quote
Old 6th Feb 2012, 18:42   #6
west
Modder
west has yet to learn the way of the Dremel
1) your asking Bethesda to abandon a huge (console) market or spend a lot of time re-vamping the game for the PC. I think you forget that they run a business, not a make PC gamers happy group.
2) With the construction set released every issue you listed can and will be fixed (and it wont take long ether) so stop complaining! they are basically doing exactly what your accusing them of not doing! (although not directly).
west is offline   Reply With Quote
Old 6th Feb 2012, 19:16   #7
Draksis
Code Monkey
Draksis's Avatar
Draksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for president
Though this does not by any means justify Bethesda's lack error/bug fixing work flow, but with the creation kit modders can address quiet game volume and menu system. In fact SkyUI is already out, and brings skyrim's inventory system back in-line with Oblivion's.
__________________
Originally Posted by liratheal View Post
Terrible, wrapped in a blanket of awful, with a dollop of useless.
Draksis is offline   Reply With Quote
Old 6th Feb 2012, 22:17   #8
Whindog
Supermodder
Whindog's Avatar
Whindog has yet to learn the way of the Dremel
You got an issue with the menues......go download SKYui and live a happy life. Untill you help yourself.......dont cry about petty sh** like menues when there are easily fixable solutions.....
SkyrimNexus is your freind.
SOme great mods will be comming and less messy in your "data" folder witht he .ini now inside mods etc. Will make everything alot cleaner.......
Hopefully i can expand upon the current......52mods im running
__________________
i5-2500k | Thermaltake Jing | 8Gb Vengence | 1TB WD Black Caviar | Asus P8P67 Pro | Gigabyte GTX460 OC | Xonar DX | Fractal Design Refine R3 | - Quiet as a mouse
Whindog is offline   Reply With Quote
Old 7th Feb 2012, 12:37   #9
Bede
Ultramodder
Bede's Avatar
Bede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for president
Warrior_Rocker has a point. Though the CK is a great gift from Bethesda and will lead to great things for Skyrim, it should not be released as a DIY bug-fixing tool.
__________________
Coolermaster 690 II Advanced (white edition) | i5-2500K | MSI P67-GD53 | Asus 970 Strix OC | 16gb Corsair Vengeance LP | Gelid Tranquillo
Asus Xonar DS | 700W Coolermaster Silent Pro M | Crucial M4 128GB | SanDisk Ultra II 480GB | Samsung Spinpoint F3 1TB
Bede is offline   Reply With Quote
Old 7th Feb 2012, 12:49   #10
kosch
Trango in the Mango
kosch's Avatar
kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.
Good times
__________________
Living the dream since 2004 -
Become a Star Citizen & sign up with Bit-Sec the official Bit-Tech organisation Use my referral code for an extra 5,000 credits!
kosch is offline   Reply With Quote
Old 7th Feb 2012, 16:38   #11
scrumble
Multimodder
scrumble's Avatar
scrumble has yet to learn the way of the Dremel
Errr, i think you'll find that any business needs to keep its customers happy.
I'm pretty sure that in this instance, that as they're selling a game to PC owners, they really do need to keep PC gamers happy.
__________________
Somedays your the dog.Somedays your the lamppost
scrumble is offline   Reply With Quote
Old 7th Feb 2012, 17:40   #12
west
Modder
That's not why its being released. Bethesda may release their own game patches to fix bugs (like with Oblivion).
Yes but they are not selling this game to just PC players. They have to consider the console market and they odiously can't afford to waste time and money on making each version of the game separately for each platform. And I would assume that most PC gamers are happy with Skyrim (judging by the reviews I've seen).
Old 7th Feb 2012, 17:43   #13
Elton
Officially a Whisky Nerd
Elton's Avatar
Elton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming Saiyan
Glad this is it. I'll wait until the unofficial patches are all done. Then I'll consider it.
__________________
Gotta keep it 100 we got fundamentals.
Elton is offline   Reply With Quote
Old 7th Feb 2012, 18:12   #14
awlllwa
What's a Dremel?
awlllwa has yet to learn the way of the Dremel
Creation Kit is up with Hi-Rez texture pack in tow
awlllwa is offline   Reply With Quote
Old 7th Feb 2012, 22:07   #15
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
Sounds awesome & I'm still nowhere near done with the stock game yet.
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 8th Feb 2012, 07:50   #16
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.
...Yes but they are not selling this game to just PC players. They have to consider the console market and they odiously can't afford to waste time and money on making each version of the game separately for each platform. And I would assume that most PC gamers are happy with Skyrim (judging by the reviews I've seen).
Odiously?!?
__________________
mclean007 is offline   Reply With Quote
Old 8th Feb 2012, 08:52   #17
bdigital
Is re-building his PC again
bdigital's Avatar
bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.bdigital is definitely a rep cheat.
I love the way the new mods are being displayed in steam. Much more accessible
__________________
My photography website: http://www.polarityphoto.co.uk Please share! || Follow me @polarityphoto on Twitter|| My Flickr ||Facebook||
Check out my Apline White TJ07 - Case Mod and Water cooled build. http://www.flickr.com/photos/6188486...7631486959032/
bdigital is offline   Reply With Quote
Old 8th Feb 2012, 09:14   #18
Anfield
Mod Master
Anfield's Avatar
Anfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming Saiyan
I fear the number of hours I'll spend playing Skyrim will now skyrocket...
Seriously though, making the use of mods so damn easy directly in steam is one of the most genius moves any game developer ever came up with.
<- hopes for other games to copy the mod support of Skyrim
Anfield is offline   Reply With Quote
Old 9th Feb 2012, 04:48   #19
west
Modder
@ mclean007, I meant to type "obviously", but "odiously" kinda works too :P
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
