Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 7th Feb 2012, 15:11   #1
Xye
Supermodder
Xye's Avatar
Xye has yet to learn the way of the DremelXye has yet to learn the way of the Dremel
Change language
I've tried google.
I know it should just be as easy as changing the format under regions and times but we have switched it to english usa and restarted and its still coming up in german.
Is the english language pack missing? How can I find out bearing in mind I'm navigating a German system.
__________________
WoT's: Xye_Sol Playing: Panther II, SU-8, PzIV, M2, M4A3E8, M36, Tetrarch, T43, T20, T50, JgdPnth, AMX13 75, ARL44
Mech_Antec: Xeon 3450@3.809GHz | Asus P7P55D-Evo (1808 BIOS)|Asus 6950|Corsair C300 128Gb|RAID 0 WD Cav.
HTPC in Progress: E35M1-I DELUXE|Intel 320 Series 40Gb|2Tb Seagate Barracuda|The Dragon Reborn (Case)
CNC Controller: E8500@3.3GHz (unable to push further)| Asus P5N-D|8800GTS|Barracuda 250Gb| Condensation (Case)
Xye is offline   Reply With Quote
Old 7th Feb 2012, 16:55   #2
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpit
Region option to so say to Windows where you are located in the world. This is just for software. Windows Media Center, Zune, are examples that uses what you put in to deliver you content options, or be able to log-in into your account and stuff.
It doesn't change the system language.
You need to get Windows Language pack (not free) to change the system language, unless you use Windows Ultimate where they are included.
Apparently this is how do it:
1. Start -> All Programs --> Windows Update --> Optional Updates.
2. Open optional Updates and go to the section Windows 7 Language Packs.
3. Tick the Language Pack you want and hit OK
4. Proceed with Install Updates
5. Depiction of Windows 7 downloading a Language Pack
6. Automatic install initiated after download
7. Go to Start -> Control Panel -> Clock, Language, and Region / Change the display language
8. Switch the display language in the Choose a display language dropdown menu.
9. Click OK
10. Restart your computer
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features.
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is online now   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
