Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 9th Feb 2012, 07:46   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Illuminate Your PC - Part 2
Antony has been playing with acrylic...
http://www.bit-tech.net/modding/guid...ur-pc-part-2/1
brumgrunt is offline   Reply With Quote
Old 9th Feb 2012, 09:52   #2
coolmiester
Coolermaster Legend
coolmiester's Avatar
coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!coolmiester - it's over 9000!!!!!!!!1!1!1!!!
Nice guide Antony
picture links are all wonky on the second page
coolmiester is offline   Reply With Quote
Old 9th Feb 2012, 09:53   #3
McDuff32
Multimodder
McDuff32 is a hoopy frood who really knows where their towel is.McDuff32 is a hoopy frood who really knows where their towel is.McDuff32 is a hoopy frood who really knows where their towel is.McDuff32 is a hoopy frood who really knows where their towel is.McDuff32 is a hoopy frood who really knows where their towel is.McDuff32 is a hoopy frood who really knows where their towel is.McDuff32 is a hoopy frood who really knows where their towel is.McDuff32 is a hoopy frood who really knows where their towel is.McDuff32 is a hoopy frood who really knows where their towel is.McDuff32 is a hoopy frood who really knows where their towel is.McDuff32 is a hoopy frood who really knows where their towel is.
Woow, cool guide!!
McDuff32 is offline   Reply With Quote
Old 9th Feb 2012, 12:05   #4
feathers
Banned
feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.
I purchased an M1 tank spotlght on eBay for $400. I am using it to light my PC but the problem is I can't run it for more than 2 seconds without the PC getting extremely hot. What can I do?
feathers is offline   Reply With Quote
Old 9th Feb 2012, 12:53   #5
The Bodger
Supermodder
The Bodger's Avatar
The Bodger has yet to learn the way of the Dremel
What sort of bulb does it use? I'm guessing something that runs on 12V and is about 50 - 100Watts? I can only think of one practical way to solve the problem, and that is to install a bulb which generates less heat. I'd suggest that you look into whether you can buy a sufficiently bright LED based bulb that fits. Failing that, you may be able to buy and dismantle a 12V LED based spotlight / downlighter bulb and mate it with the metal fitting off the original bulb from the lamp.
Using a high power LED 'bulb' would allow you to get down to between 1 and 5 watts, which would reduce the heat by a factor of at least 10.
Regarding the article, one thing that I don't think has been mentioned is the possibility of engraving the acrylic; with a bit of care, some very attractive effects can be achieved by adding engravings to the illuminated sheet. Rather than masking and spraying the acrylic, if you have the tools you can engrave and in - fill to get a similar effect, and it is less prone to getting rubbed off / worn away. Obviously though, you only get one shot at that... not for the faint hearted!
The Bodger is offline   Reply With Quote
Old 9th Feb 2012, 14:48   #6
skreenname
SFF Forever
skreenname's Avatar
skreenname has yet to learn the way of the Dremel
Neat article,never thought of cutting just a slot or something into the case panel, neat idea!
__________________
3570S | 12GB DDR3 1600 | Ref. GTX 980 | Ncase M1 V2 | P8Z77I-Deluxe WD | SX500-LG | 840 Evo 120Gb | 850 Evo 500 Gb
skreenname is offline   Reply With Quote
Old 9th Feb 2012, 15:03   #7
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.
__________________
The Box:i7 2700K@5.3GHz|EK Supreme LT+Coolstream XT 360|16GB HyperX DDR3@1866MHz|EVGA GTX780 ti+EK FC780ti|MSI P67A-GD55||M5 512|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Perixx MX2000 + Intuos 4M
Audio: PC->TosLink->TEAC UD-501->Fostex TH600|InEar LivePro 3|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 9th Feb 2012, 16:14   #8
Yemerich
I can has PERSUADETRON?
Yemerich's Avatar
Yemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpit
great article!
__________________
----------------------------- Yemerich -----------------------------
Hephaestus (best design Windows Vista Magazine - 2007, MotM nominee 2008)
Odinn (CCE best design in CP-Brazil 2008)
Hades (Best advanced casemod design CP-Brazil 2010)
Take a look on my projects here.
Yemerich is offline   Reply With Quote
Old 12th Feb 2012, 14:29   #9
Mr_Armageddon
Multimodder
Mr_Armageddon's Avatar
Mr_Armageddon has yet to learn the way of the Dremel
Really liking these guides. I am actually getting ready to do an illuminated mid-panel for my system, so the more info I can read on the subject, the better.
Mr_Armageddon is offline   Reply With Quote
Old 12th Feb 2012, 15:21   #10
alamoqqvv
What's a Dremel?
alamoqqvv has yet to learn the way of the Dremel
alamoqqvv is offline   Reply With Quote
Old 12th Feb 2012, 19:41   #11
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Sorry about the images on the second page guys, somehow the numbering had got out of sync - all sorted now!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
