Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 9th Feb 2012, 16:08   #1
Archtronics
I *am* a Dremel
Archtronics's Avatar
Archtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for president
Online design portfolio
Hey guys
I am looking for a website to create a page for me to display my work to help me in securing another job in the future.
Are any websites that people would suggest are easy to use and look professional, preferably free.
Thanks
Mark
__________________
Now an Architect
Archtronics is offline   Reply With Quote
Old 9th Feb 2012, 17:29   #2
SuicideNeil
I'm insane, not stupid.
SuicideNeil's Avatar
SuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for president
I'm very fond of Blogspot.com- lots of professional ( graphic ) artists and designers put their portfolios & latest work on there. You can create seperate pages with 'about me' type info and seperate pages for different types of work or commissions from projects etc; they also have a massive range fo customizable free templates that are very easy to alter , worth a look..
__________________
ASUS P8Z77-M PRO | INTEL CORE i5 2500K @ 4.3GHZ | EVGA GEFORCE GTX 670FTW | CORSAIR VENGENCE DDR3 1600MHZ 2x 4GB | SAMSUNG SPINPOINT F3 1TB | TITAN FENRIR | ACER PREDATOR | WIN 7PRO x64
SuicideNeil is offline   Reply With Quote
Old 7th Jun 2012, 21:26   #3
JimmyTheTrumpet
What's a Dremel?
JimmyTheTrumpet's Avatar
JimmyTheTrumpet has yet to learn the way of the Dremel
One of the best communities for design portfolios is www.deviantart.com. It also allows you to create yourself a portfolio etc.
With a little effort you could make yourself some good contacts along the way too!
JimmyTheTrumpet is offline   Reply With Quote
Old 8th Jun 2012, 08:30   #4
BentAnat
Software Dev
BentAnat's Avatar
BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!
Free=fail, quite frankly... Wordpress and some cheap hosting will go a long way.
Domains cost next to nothing, and if you adda few bob for a good Wordpress template, it'll ook great and professional.
BentAnat is online now   Reply With Quote
Old 8th Jun 2012, 11:03   #5
Atomic
Gerwaff
Atomic's Avatar
Atomic is a hoopy frood who really knows where their towel is.Atomic is a hoopy frood who really knows where their towel is.Atomic is a hoopy frood who really knows where their towel is.Atomic is a hoopy frood who really knows where their towel is.Atomic is a hoopy frood who really knows where their towel is.Atomic is a hoopy frood who really knows where their towel is.Atomic is a hoopy frood who really knows where their towel is.Atomic is a hoopy frood who really knows where their towel is.Atomic is a hoopy frood who really knows where their towel is.Atomic is a hoopy frood who really knows where their towel is.Atomic is a hoopy frood who really knows where their towel is.
I'd also go the domain/hosting/WordPress route, you don't even need to pay for a template/theme, there a plenty of decent free portfolio ones available.
__________________
:: ASUS Maximus IV GENE-Z :: i5 2500K @ 4GHz :: 16GB Corsair Vengeance :: 256GB Samsung 830 ::
:: Awesome, Reliable Website & Server Hosting ::
Atomic is offline   Reply With Quote
Old 8th Jun 2012, 11:18   #6
Sexton
Supermodder
Sexton's Avatar
Sexton can run CrysisSexton can run CrysisSexton can run CrysisSexton can run CrysisSexton can run CrysisSexton can run CrysisSexton can run CrysisSexton can run CrysisSexton can run CrysisSexton can run CrysisSexton can run Crysis
This.
I just bought a .co.uk domain from 1&1 for around £5 for 2 years, then use 000webhost.com for my hosting (free but very good), where I installed Wordpress. Easy, cheap and very effective.
__________________
My Website
Core i5 750 @ 4Ghz | Titan Fenrir | Gigabyte P55-US3L | 8GB Corsair XMS3 | X-Fi Xtreme Gamer | MSI 560 Ti Twin Frozr
Logitech G19 | Sidewinder X8 | 128GB Crucial M4 | Samsung F3 | 700W Coolermaster Silent Pro Gold | BitFenix Shinobi XL
Sexton is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
