Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 13th Feb 2012, 13:02   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Asus P9X79 Pro Review
We take a look at Asus' latest mid-range X79 motherboard
http://www.bit-tech.net/hardware/mot...9-pro-review/1
brumgrunt is offline   Reply With Quote
Old 13th Feb 2012, 13:13   #2
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
Is it just me or are these Sandybridge E CPU's coming up short in the overclocking department, i dont think i've seen one that's been stable past 4.6Ghz....is it a CPU or Mobo problem?.
Hustler is offline   Reply With Quote
Old 13th Feb 2012, 13:35   #3
dunx
ITX is where it's at !
dunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysis
This saw the GD65 (8D) leap up the graphs,
Last paragraph before conclusion - an error I presume ?
dunx
__________________
Gigabyte Z87x OC-Force - i7-4770k @ 4.3 GHz - 16 GB Crucial Ballistix Tracer DDR3 @ 1600 MHz - 256 GB Plextor SSD x2 - 6x WD Caviar Black 1TB SATA III HD's - GTX 970 x2- GTX 780 - Titan Black - Coolermaster 1250W PSU - Lian Li PC-D600 - 3x Noctua NF-A14 fans - custom water-cooled - Alphacoool 420mm rads in white - XSPC CPU block and D5 pump - Griffin Powermate x2
dunx is offline   Reply With Quote
Old 13th Feb 2012, 13:45   #4
noizdaemon666
I'm Od, Therefore I Pwn
noizdaemon666's Avatar
noizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyan
I think it's more the heat they pump out. Pookeyhead, thetrashcanman and True_gamer all have SB-E chips running at 5GHz or over.
On topic, excellent review. I want more money to upgrade
__________________
I make up-to-date Windows ISOs for the making of faster installs
noizdaemon666 is offline   Reply With Quote
Old 13th Feb 2012, 15:00   #5
BrightCandle
Multimodder
BrightCandle has yet to learn the way of the Dremel
[QUOTE=noizdaemon666]
Even under water they aren't going to higher clocks, which means its not just the heat. Its either the extra cores, or more likely the increased amount of cache that is causing the problem.
BrightCandle is offline   Reply With Quote
Old 13th Feb 2012, 16:04   #6
MjFrosty
Hypermodder
MjFrosty's Avatar
MjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on you
They were never going to clock as well with the additional cores. It's a great motherboard, I'm currently at 4.9Ghz on water using it. Not sure why people see <5Ghz and automatically their brain tells them it's a poor performer. I think it's pretty impressive for a hex-core. (no additional VRM cooling besides roof mounted radiator / rear motherboard fan)
Edit: Mid-range? pffft.
__________________
Fast
MjFrosty is offline   Reply With Quote
Old 13th Feb 2012, 16:34   #7
Cyberpower-UK
Professional Overclocker
Cyberpower-UK's Avatar
Cyberpower-UK has yet to learn the way of the Dremel
Getting any 3000 series hexa core to 5GHz is a challenge on any board. You're looking at 200W + through the CPU. To me that puts VRM waterblocks as a prerequisite as 5GHz can be done on an open bench but in a case the VRMs just don't get the airflow they need. We've done 4.75GHz for a few customers and ended up a 4.6GHz for the Cobra: http://www.pcadvisor.co.uk/reviews/d...verdictTab#top
__________________
Currently Benching: i7 3000s and AMD 8000s
Cyberpower-UK is offline   Reply With Quote
Old 13th Feb 2012, 19:05   #8
MjFrosty
Hypermodder
MjFrosty's Avatar
You need a bigger case
__________________
Fast
Old 13th Feb 2012, 19:19   #9
K404
It IS cold and it IS fast
K404 can run CrysisK404 can run CrysisK404 can run CrysisK404 can run CrysisK404 can run CrysisK404 can run CrysisK404 can run CrysisK404 can run CrysisK404 can run CrysisK404 can run Crysis
I suspect it's more than any 200W.......
__________________
Completely correct but utterly wrong
K404 is offline   Reply With Quote
Old 14th Feb 2012, 07:06   #10
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
Been rocking this board since December, really enjoying it so far. Can't wait to get some water loops going for some proper clocking
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: Cheers Luv!
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 14th Feb 2012, 08:24   #11
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
Yea, agree they really do need cooling at the very high-end, but the problem is most people see a bundled fan and stick their nose up because they think it's required for everything, or, they have a preferred case fan they already own. I would expect cases like Cooler Master ones with a large 200m fan placed right over the VRM area in the roof should cool quite well.
It's actually where our TProbe is real-world useful rather than a 'nice to have' value-add, as it modulates the load according to temperature. If you are still over-temping the VRMs though (say if you set it to Extreme/500Hz/no fan), our boards set the CPU to throttle or in worst case scenarios the system resets itself with 'OC failed' to prevent VRM damage.
I had a school day from RD. But I also think it's important people understand this rare situation might not be an 'unstable board', for example.
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 20th Feb 2012, 08:44   #12
Pookeyhead
It's big, and it's clever.
Pookeyhead's Avatar
Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.
I run at 4.7GHz as a 24/7 overclock. The only reason I stop there is cooling. I've passed a maximum stress test IBT run of 20 loops (with 16GB that's around 8 hours) at 4.9, but my temps were horrible. That was at 1.42v. I only have a H100. With a decent loop 5GHz would be no problem at around 1.46/1.5v.
You miss the point though. You don't NEED the same clock speed with a SB-E. Even at stock speeds, it beats overclocked SB chips with heavily threaded tasks, and let's be honest, if all you do is game, you don't need SB-E. These chips are for people who heavily multi-task, or do a lot of maths intensive tasks like rendering, graphics work, or encoding. Look at the Geekbench leader boards. I posted a time made with the P9X79 Pro at STOCK speeds with a 3960X and it beats all but the fastest overclocked SB chip.. at the stock speed of 3.6GHz. Even my "modest" 4.7GHz overclock sees nearly 20,000 points.. that's 5k clear of 2700Ks clocked at 5.1 and above. With heavily threaded apps, 4.5GHz with this chip will smoke anything, at any speed. Even a SB rig at 5.5GHz running on chilled water only JUST beats the stock speed of the 3960X and this Asus board. You need to get this 5GHz as a minimum out of your head.
Nice review!
I had this board for a few weeks. The only reason I changed it is because it can't run three GPUs at 16x, 16x, 8x. Best it can do is 16x, 8x, 8x. Only a problem if you want triple SLI of course. If you don't plan on going triple SLI, this is a killer board.
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ H105 ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ EVGA GTX980 Super-Clocked¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦
EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS9260-8i ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered
MOON | Thecus N3200pro 3TB RAID5
Pookeyhead is offline   Reply With Quote
Old 2nd May 2012, 18:54   #13
bt500
What's a Dremel?
bt500 has yet to learn the way of the Dremel
There's a minor typo on the first page, it says "seven fan headers" when it should say "six fan headers". Great review!
bt500 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
