Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 15th Feb 2012, 13:23   #1
nagyizom
Supermodder
nagyizom's Avatar
nagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremel
Star Wars - Tydirium Mod | 22.04.2012 | Minor update - Mold was made!
„No, I don't think the Empire had Wookiees in mind when they designed her, Chewie." by Han Solo
Welcome everybody in my opening entry of my new project. I decided that in the year 2012. I apply with the building of another uniq pc .Like in the JAWA Sandwalker project, I will choose theme from the beloved Star Wars universe. This time it will be a space vessel, in wich i will implement a pc config. And the vessel will be the space shuttle from the Return of the Jedi , the Tydirium.
Sienar Fleet Systems Lambda-Class Shuttle
Tydirium:
Tydeus was the father of Diomedes, a Greek hero of the
Trojan War. The Latin genitive plural would be _Tydeorum_,
"belonging to Tydeuses."
Tyndareus (Lat. gen. pl., "Tyndareorum") was the consort of
Leda, Queen of Sparta, whom Zeus courted in the shape of a swan.
Explanation
An elegant example that stands apart from typical brutish Imperial engineering, the Lambda-class shuttle is a multi-purpose transport used in the Imperial starfleet. The Empire pressed the shuttle into service for both cargo ferrying and passenger duty. Even the Empire's elite, like Darth Vader and the Emperor Palpatine used these shuttles.
It has three wings: a stationary center foil and two articulated flanking wings. When in flight, the side wings fold out for greater stabilization. When landing, the wings fold in, shrinking the vessel's silhouette.The well-armed vessel has two forward-facing double laser cannons, two wing-mounted double cannons, and a rear-facing double laser cannon. It is equipped with a hyperdrive.
Prelude:
After finishing the PC Case called Illuminated Mind , for a year I had no energy and no cash to begin a new project, I was just buliding the best cases in my mind. I drawed multiple plans in this period. I have searched a theme that nobody has ever builded. First I planned to build the Sentry Turret from the game Portal, but a modder from here the Bit-Tech forum was quicker than me, so I have turned to the Tydirium.
Beginings
I knew from the beggining that with an ATX mainbord and with a normal sized display card and Psu the buildnig of this kind of Pc-Case woluld be an insane plan, I decided to build the system around an ITX mainbord so the construction could be held in normal sizes. I knew that too that if i build a Lambda Class Space shuttle then the wings on both side will be up- down movable, so i have searched an ITX mainbord with parraler ports to control easaly the wings manuvering engines.
Plans
I have found a full machine on a hungarian it-webpage with mainboard ,Psu and a 2,5” hdd. The mainboard is a VIA EPIA 10000, wich has parallel ports. Perfect!.
The box within the config.
After unpacking.
Here is the ITX system
After it has arrived I started the planning!
The first step was searcing the web again. As I experienced with the sandwalker , this vessel has a big number of fans too.I have found a lot of photos of the original inmovie modell, and a blogspot with a lot ofpictures of a pro-modeller who has built a studio-quality modell. There was RF plan , which was a big help to me.
Christmas has arrived and my girlfriend’s xmas present was not a pair of socks or a new scarf no, she has buyed me a Tyridirum shuttle modell.
So now i can see the shuttle in 3D , got a lot of pictures and good drawings, I could started to work with the details. According to the plans I have modified the shuttle size to the mainbord and the other hardware elements size. So the hull will be fit in a 30x30x10 block. If everything will be fine the full case will be made of polystyrene plate.
With the help of Sketchup from bit by bit the config in the hull is sarted to stand together.
The mainbord’s connectors will face the engine nozzels, the wireing can be plugged in from the two oval intakes. Tha mainboard will take place in front of the PSU, and in the front of that will be the panel with the wing –mover mechanism. The Hdd will be under the Psu because of the better space management. The mechanism of the wings are from FDD drives, the kinetic energy of the mechanism will be forwarded with a gear to the axis, on the axis will be 3-3 disks to hold the wings.
The cooling of the mainboard and the Psu will be provided by a 12cm cooler. The mainbord could be work with passive cooling but during the probe, in the BIOS the temperature ran up to 60 °C. I think this is too much , and if the OS (XP) will be runing on the system it could easaly be much higher. The polystyrene plate melts to the heat so I have to be sure of the proper temperature. I hope with the fan in action the stuff will not melt .
This for the begining. One of my friend is just building a plastic vacum forming machine and he promised me to help in the making of the shuttles coverage. I start to make the template as i can.After the finishing of the machine i will start the great work.
May the Force be with You!
__________________
Current projects: Graphite 5 | Tydirium is on the way!
Previous mods:|Sandcrawler Mod| |Illuminated Mind|
Follow me on Facebook
nagyizom is offline   Reply With Quote
Old 15th Feb 2012, 14:47   #2
Mark_Skeldon
Multimodder
Mark_Skeldon's Avatar
Mark_Skeldon has yet to learn the way of the Dremel
Loving the idea of doing the Imperial shuttle. Probably one of my favourite Star Wars vehicles (that along with the B-wing and the ARC-170).
Not sure if you meant to post picture, but none are showing?
I'll be following this one very closely
__________________
i7 2600k @4.42GHz, | Asus Maximus IV Gene-z | 8GB G.Skill Ripjaws CL9 | GTX 570 @ 803/2002 | 128GB Crucial M4 SSD | Coolermaster RP Pro 1000w | Lian Li PC70 | Onkyo SR608 amp | Mordaunt Short components |
Mark_Skeldon is offline   Reply With Quote
Old 15th Feb 2012, 15:02   #3
ASPHIAX
Beyond Complexity Lies Simplicity
ASPHIAX's Avatar
ASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the Dremel
Lovely !! Another Star Wars build !
Good and thought through introdution Gabor!
Looking forward to seeing one of my favorite models ever being built!
__________________
Current Build : BORG COSMOS II
Current build : 2001 - A Case Modyssey
Finished build : IMPERIAL AT-AT
Finished Build : USS EURISKO - Intrepid Mark II Class
www.asphiax.wordpress.com
ASPHIAX is offline   Reply With Quote
Old 15th Feb 2012, 15:18   #4
nagyizom
Supermodder
nagyizom's Avatar
Mark Skeldon, ASPHIAX Thank you Guys! I hope the winter will go back to Siberia very soon, and I occupies my workshop to make those styrene forms.
Nobody can see my beautiful pictures? I uploaded them to my BT's server, made a new album and used the URLs.
__________________
Old 15th Feb 2012, 15:21   #5
Moddingboy
Multimodder
Moddingboy's Avatar
Moddingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the Dremel
Nice idea my friend! Subbed!
__________________
Gymkhana Mod - MOTM 2011 September Winner
Moddingboy Mods on Fb
Moddingboy is offline   Reply With Quote
Old 15th Feb 2012, 16:27   #6
Helldog
What's a Dremel?
Helldog has yet to learn the way of the Dremel
Can't see the pictures too , thats unfortunat because the pictures are great. I have seen them already. Please correct it as soon as possible.
Helldog is offline   Reply With Quote
Old 16th Feb 2012, 08:24   #7
Mark_Skeldon
Multimodder
Ditto! Please fix the pics Throw them up on Photobucket? Really looking forward to seeing this now!
When it's finished you could get this desk to stand it on
__________________
Old 16th Feb 2012, 09:14   #8
nagyizom
Supermodder
nagyizom's Avatar
I hope i fixed the problems now!
__________________
Old 16th Feb 2012, 09:39   #9
alain-s
Supermodder
alain-s has yet to learn the way of the Dremelalain-s has yet to learn the way of the Dremelalain-s has yet to learn the way of the Dremelalain-s has yet to learn the way of the Dremelalain-s has yet to learn the way of the Dremelalain-s has yet to learn the way of the Dremelalain-s has yet to learn the way of the Dremel
Jep can see it all, looks promising looking forward when u will start to build the base.
alain-s is offline   Reply With Quote
Old 16th Feb 2012, 09:47   #10
Mark_Skeldon
Multimodder
Looks good!
__________________
Old 16th Feb 2012, 14:16   #11
kinghong1970
Just a Clumsy Ape
kinghong1970's Avatar
kinghong1970 has yet to learn the way of the Dremel
hmm... that chair looks a bit small to fit Jabba...
kinghong1970 is offline   Reply With Quote
Old 16th Feb 2012, 15:50   #12
nagyizom
Supermodder
nagyizom's Avatar
HaHa Nice idea
__________________
Old 17th Feb 2012, 05:13   #13
Helldog
What's a Dremel?
Finally I can see the pics again. Looking forward to see project updates.
Regards
Kornél
Old 17th Feb 2012, 11:58   #14
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Really nice start and idea my friend!!!! I will be watching this!!
AnG3L is offline   Reply With Quote
Old 17th Feb 2012, 12:51   #15
Korvus
May contain traces of sanity.
Korvus's Avatar
Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!
Looking interesting, can't wait to see where this goes
Korvus is offline   Reply With Quote
Old 25th Feb 2012, 07:21   #16
nagyizom
Supermodder
nagyizom's Avatar
Thank you AgG3L!
Tech-Jakl: I hope, after the next update you'll see the path
__________________
Old 26th Feb 2012, 21:23   #17
motorsportcfd
Multimodder
motorsportcfd's Avatar
motorsportcfd has yet to learn the way of the Dremel
Im looking forward to this build!
motorsportcfd is offline   Reply With Quote
Old 27th Feb 2012, 17:32   #18
Nexxo
There is no rep for awesomeness.
Moderator
Nexxo's Avatar
Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.
So am I, but:
Originally Posted by WilHarris View Post
2. Your first post must contain pics of the actual mod in progress. If all you have is an idea, you don't have a log. If all you have is some conceptual sketches, you don't have a log. If all you have to show is a heap of parts, you don't have a log. This forum is purely for concrete work in progress - the other modding forums are more appropriate for concepts and thoughts.
Moved to modding for now... Sorry.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust
Nexxo is offline   Reply With Quote
Old 5th Apr 2012, 21:06   #19
Carl97
Sorry, for my bad english.
Carl97's Avatar
Carl97 has yet to learn the way of the Dremel
[Eng] I look forward, will surely be a great success! Good luck my fellow countrymen!
[Hu] Kívácsian várom, de így is tudom nagy siker lesz! Sok sikert honfitársam!
Carl97 is offline   Reply With Quote
Old 9th Apr 2012, 14:20   #20
Nanosec
absit iniuria verbis
Nanosec's Avatar
Nanosec has yet to learn the way of the DremelNanosec has yet to learn the way of the DremelNanosec has yet to learn the way of the DremelNanosec has yet to learn the way of the Dremel
Sub'd
Nanosec is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
