Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 17th Feb 2012, 09:58   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Illuminate your PC - Part 3
The final part of our illumination guide...
http://www.bit-tech.net/modding/guid...ur-pc-part-3/1
brumgrunt is offline   Reply With Quote
Old 17th Feb 2012, 10:57   #2
improprietary
FT03 is a bitch to watercool
improprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremel
#offtopic earlsmann site got some server issues atm
__________________
I'm spending a year dead for tax reasons. - Douglas Adams
Wanna help me and get cloud storage? Use Dropbox http://db.tt/msbUQQC
improprietary is offline   Reply With Quote
Old 17th Feb 2012, 12:58   #3
leibritz
What's a Dremel?
leibritz has yet to learn the way of the Dremel
the shop wants me to log in...
leibritz is offline   Reply With Quote
Old 17th Feb 2012, 14:24   #4
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Site's still there but the old link seems to have gone - works now!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 17th Feb 2012, 16:12   #5
Mr_Armageddon
Multimodder
Mr_Armageddon's Avatar
Mr_Armageddon has yet to learn the way of the Dremel
I can't find any A4 size panels for less than $55 USD here in the States. So just the EL panels alone would cost me $110.
Unless I can find it cheaper, I will probably follow the method outlined by SFraze in his build log, where he makes his own illuminated panel from scratch using an LED light strip. Seem a bit brighter, and much less expensive as well.
http://forums.bit-tech.net/showpost....30&postcount=7
Mr_Armageddon is offline   Reply With Quote
Old 18th Feb 2012, 10:26   #6
KryptiK
Minimodder
KryptiK has yet to learn the way of the DremelKryptiK has yet to learn the way of the Dremel
looks totally badass
KryptiK is offline   Reply With Quote
Old 18th Feb 2012, 14:46   #7
D B
Supermodder
D B's Avatar
D B has yet to learn the way of the Dremel
Link at Earlsmann for EL panels does not work
Cool idea though and looks good
__________________
You keep those pink gloves up & swinging, Kimber
Think Pink Scuba
D B is offline   Reply With Quote
Old 2nd Mar 2012, 09:53   #8
gigik
Multimodder
gigik's Avatar
gigik has yet to learn the way of the Dremel
Or you can use backlight panel from broken notebook lcd like I did..
http://gigi.pcservispardubice.cz/1/mgb2/mgb2.html
gigik is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
