Reply
Thread Tools View Mode
Old 23rd Feb 2012, 14:05   #1
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for president
Official "John Hanlon Fund Raiser" PC Build (Thank you Mach!)
Please Share this Project Thread with your friends!
Fractal-Design visited Mnpctech to check out the case, before it shipped out!
Fellow, bit-tech member, JohnHanlon303 lives with incurable Asbestos Poisoning, which leaves him with 40% lung capacity. He can no longer be employed with this condition. Hes filed paperwork for Government financial assistance, but won't see 1st check until this April. Until then, he needs financial help with living expenses and medical prescriptions. To help raise money for John, I've teamed up with Darth Beavis to build a custom PC, to auction off on Ebay. I'm doing the case modifications then sending the modified case to Darth, he'll install a water cooled system and oversee the auction of the PC on Ebay.
Another way to help John is by making a direct donation via Paypal, HERE organized by Alex Ftoulis aka AnGEL and Masbuskado Modding, leaders of HOTG modding association and NewModCity.
You can join the "Support John Hanlon" Group on facebook organized by Alex Ftoulis aka AnGEL to offer your help however you can. Even if you can't afford to help financially, post your words of support for John!
This Case Mod portion of this build is done by bit-tech's MOTM Sponser, Mnpctech!
Set of Mnpctech Machined Aluminum "Diamond Knurl" PC case feet
2x140mm (280) Mnpctech Billet Raditor Grill for top panel and 2x120mm (240) Mnpctech Billet Radiator Grill
Top Radiator grill installed with M4 socket head machine screws for radiators
Custom clear cast acrylic PC Case window installed in the define R3 by Mnpctech
For clear installation, Scotch 4010 Clear Mounting Tape was used to apply clear cast acrylic PC Case window in the define R3
The System will be installed by Richard Surroz (aka Darth Beavis) from Out of The Box Mods
bit-tech Members who have donated Hardware to the build!
Kayinblack donated DDC Waterpump
Slickdsg donated Windows 7 Operating System
Furballzen's business PCModul.us has donated 240 radiator grill / 120mm fan grill
240 Honeycomb Radiator Grill from PCModul.us
Cheapskate has donated his custom hand made Waterblock & DDC waterpump top!
Custom hand made DDC waterpump top by Cheapskate
Custom hand made CPU Waterblock by Cheapskate
"Custom application launcher made by yougotkicked based on the rainmeter platform - YGKtech"
Mayhems Dyes
Mayhem’s are rapidly becoming the leading manufacturer of liquid cooling solutions in Europe. Our product range is expanding monthly, providing the water cooling community an expansive array of differing solutions and liquids intended for the thermal performance market. However it doesn’t end there, we are working on a myriad of new solutions for the enthusiast and will continue to develop our range.
Thank you to SteelSeries and Richi Bowzer (aka rchiileea) from XtremeComputing.co.uk for donating these new Peripherals for the Hanlon Fund Raiser system!
SteelSeries Siberia Headset
SteelSeries Merc Stealth
SteelSeries Sensei
Thank you!!! to Patriot Memory for donating these awesome products to the "John Hanlon Fund Raiser" PC Build
Viper Extreme DDR 500
Patriot PYRO 120BG SSD
NZXT has donated a new 850W Power Supply!
Lutro0 Customs is sleeving the NZXT 850W PSU with Red / White / Blue Paracord!
You can contact Lutro0 Customs through their facebook Page
Hand crafted Stainless Steel Watercool Loop Reservoir by Paslis!
Thank you to ZOTAC! for donating a new 580 GTX Video card!
Thank you to Prolimatech for donating two 120mm and 140mm Vertex BLUE LED Cooling fans to the John Hanlon Fund Raiser PC Build!
BIG Thank you to these fellow Sponsors for donating their products!
Fractal Design Define R3 White case, Only $99 at Newegg
Features:
Improved model over Fractal Design Define R3
Stunning front panel design
Patent pending ModuVent™ design - removable vents!
Pre-fitted with dense, noise absorbing material
Motherboard tray cut-out, allows easy access to rear of motherboard
Eight HDD-trays, with silicone mounting
Can accommodate up to seven 120/140mm fans, two supplied
PCI fan controller for 3 fans included
Easily removable front fan filters with clip-on holders for 120mm fans
Specifications:
Dimensions 207.40 x 440 x 521.2mm (WxHxD)
Weight 12.5 Kg
Motherboard Compatibility Mini ITX, Micro ATX and ATX
Power Supply Compatibility Standard ATX, can accommodate long PSUs
PCI/AGP Card Compatibility Full size (up to 290 mm long)
3.5" Drive Bays 8, all SSD compatible
5.25" Drive Bays 2, one bay converts to 3.5" for floppy or card reader
Roof Cooling Fans Space for two 120mm, none supplied
Rear/Side Cooling Fans Rear - space for one 120mm fan, supplied; Side - space for 140 or 120mm fan not supplied
Front/Floor Cooling Fans Front - space for two 120mm fans (both with filters), one supplied; Floor - space for one 120mm fan (with filter), not supplied
Expansion Card Slots 7, with sleek white painted brackets
Front I/O Ports 2x USB 2.0, 1x eSATA and Audio I/O
Accessories PCI fan controller, controllers up to 3 fans
Warranty 24 months
Project Log Update 3/5/12
Here is the Patriotic custom paint mural we've created for the White Define R3 case. The airbrushed mural is done hand, by Brad Galvin
Updated 5/03/12
Updated Photos 5/6/12
mnpctech is offline   Reply With Quote
Old 23rd Feb 2012, 14:05   #2
mnpctech
bit-tech sponsor
mnpctech's Avatar
The Fractal-Design Define R3 has Black factory sound dampening foam on the side panels. My goal is to install a custom window without the Black U-channel window molding, so the panel has clean look.
Make first initial cut with your Dremel and reinforced cutting wheel, to allow use of Jigsaw and cut the window more efficiently
You have created a slot to allow a Jigsaw w/ 18 TPI cutting blade. The blade will cut through the Steel and sound dampening foam. You will have to periodically clean foam debris from the Jigsaw blade.
Using a Jigsaw is much quicker than using a Dremel to cut your window
I'm removing 1/4" of Black foam from the edge of opening with X-acto knife, so I can install Clear acrylic window with 3M 4010 Tape.
Using Flat head screw driver to peel off the 1/4" of sound deadening foam
Reside left on the Steel after peeling off 1/4" foam
Small particles of the foam will melt onto outside of window, that need to be removed.
Using small hand file to remove small particles of the melted foam.
To remove residue of the foam, I dabbed Sunnyside brand Mineral Spirits to a piece of cloth and rubbed off the residue. The Mineral Spirits did not effect the factory paint finish on the Define R3.
Residue of foam, before applying Sunnyside brand Mineral Spirits.
Foam residue removed.
Now you can install Clear acrylic window cut to the dimensions of the exposed Steel, with 3M 4010 Tape
I'm going to install a Clear Cast Acrylic window later, after the panel has been custom painted with 3M 4010 Tape
Old 23rd Feb 2012, 14:33   #3
Mark_Skeldon
Multimodder
Mark_Skeldon's Avatar
Mark_Skeldon has yet to learn the way of the Dremel
Nice and neat
__________________
i7 2600k @4.42GHz, | Asus Maximus IV Gene-z | 8GB G.Skill Ripjaws CL9 | GTX 570 @ 803/2002 | 128GB Crucial M4 SSD | Coolermaster RP Pro 1000w | Lian Li PC70 | Onkyo SR608 amp | Mordaunt Short components |
Mark_Skeldon is offline   Reply With Quote
Old 23rd Feb 2012, 14:43   #4
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Thats the spirit of the modding community. Not only creating. But supporting our friends too. I am proud to be a member of this brotherhood. Bill you rock bro!
AnG3L is offline   Reply With Quote
Old 23rd Feb 2012, 14:55   #5
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.
Subed. Oh my.
the john
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 23rd Feb 2012, 15:01   #6
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
When I get home this evening, I'll donate whatever's in my Paypal at the time. Has to be close enough to £20.
Great start Bill.
Oh, and I almost forgot, something like this deserves a rep bomb.
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 23rd Feb 2012, 15:03   #7
LithiumDesign
3dsMax User
LithiumDesign's Avatar
LithiumDesign is a hoopy frood who really knows where their towel is.LithiumDesign is a hoopy frood who really knows where their towel is.LithiumDesign is a hoopy frood who really knows where their towel is.LithiumDesign is a hoopy frood who really knows where their towel is.LithiumDesign is a hoopy frood who really knows where their towel is.LithiumDesign is a hoopy frood who really knows where their towel is.LithiumDesign is a hoopy frood who really knows where their towel is.LithiumDesign is a hoopy frood who really knows where their towel is.LithiumDesign is a hoopy frood who really knows where their towel is.LithiumDesign is a hoopy frood who really knows where their towel is.LithiumDesign is a hoopy frood who really knows where their towel is.
oh wow! :O
__________________
Intel Core i5 750 | G.Skill Ripjaw 8GB | XFX HD5770
Asus P7P55D LE | 500W OCZ ModXstream Pro | Antec Three Hundred
500GB + 1.5TB Samsung Spinpoint F3 | Logitech G9x | 23" LG | Windows Se7en 64-Bit
FiiO E07K | AKG K451 | NAD 3020i
LithiumDesign is offline   Reply With Quote
Old 23rd Feb 2012, 15:10   #8
DynamoNED
What's a Dremel?
DynamoNED's Avatar
DynamoNED has yet to learn the way of the Dremel
Subbed. I don't have much, but I'll be happy to donate and to bid on this mod when it's finished.
DynamoNED is offline   Reply With Quote
Old 23rd Feb 2012, 15:25   #9
jhanlon303
jhanlon303's Avatar
There will be custom paint too? I have to follow this.
__________________
Old 23rd Feb 2012, 15:29   #10
masbuskado
Compulsive Modder
masbuskado's Avatar
masbuskado has yet to learn the way of the Dremelmasbuskado has yet to learn the way of the Dremelmasbuskado has yet to learn the way of the Dremelmasbuskado has yet to learn the way of the Dremelmasbuskado has yet to learn the way of the Dremelmasbuskado has yet to learn the way of the Dremel
Nicely done Bill it is time that we get united more often not just in times like this... Respect bro... mod on and Viva la Revolution... Hands of the Gods!!!
I will send you an AMD ATX that offer JH on FB so you can put it in there so don't worry about MoBo...
If I can help some how (with the modding) just let me know!!! : )
__________________
UN1TY: Hands of the Gods
masbuskado is offline   Reply With Quote
Old 23rd Feb 2012, 15:32   #11
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
Well said Alex and well done Bill for doing this mod...You both top blokes.
bulldogjeff is offline   Reply With Quote
Old 23rd Feb 2012, 15:43   #12
DarthBeavis
Supermodder
DarthBeavis has yet to learn the way of the DremelDarthBeavis has yet to learn the way of the DremelDarthBeavis has yet to learn the way of the DremelDarthBeavis has yet to learn the way of the DremelDarthBeavis has yet to learn the way of the DremelDarthBeavis has yet to learn the way of the Dremel
Thanks for getting an awesome worklog up Bill! FYI: I am pointing sponsors here as I work to get more support As new sponsors are added I encourage everyone to like their FB pages and thank them for supporting our community. Alex and Bill you two are awesome people as is john, a guy who deserves our love and respect.
__________________
Check out my modding blog: http://outoftheboxmods.com/
DarthBeavis is offline   Reply With Quote
Old 23rd Feb 2012, 15:49   #13
KayinBlack
I Endure
KayinBlack's Avatar
KayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for president
I'll see what I can find here for you guys, be it parts or money. You're too important to us to let leave the internet, John. Who would I discuss being sick with?
Tell ya what. I have 4x1GB of Ballistix Tracers (green LED) here if you guys don't have any other RAM. Let me know and it's yours.
KayinBlack is offline   Reply With Quote
Old 23rd Feb 2012, 15:50   #14
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
I was just now thinking about this so thought I'd better keep an eye out for it starting & really awesome to see it start, hope it raises a good amount, mod on Bill, nice window already.
Stars & reps
Originally Posted by jhanlon303 View Post
Subed. Oh my.
the john
Awesome isn't it, hope all is as good as can be for you mate, we all appreciate the john.
Just done my rep bomb on all involved in this.
Waynio is offline   Reply With Quote
Old 23rd Feb 2012, 15:57   #15
Angel OD
Pump Killer
Angel OD's Avatar
Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.
If this was not for John, I'd be very worried to see Bill mod this Fractal as he might do a better job than me at it!
But since it's for a case as good at helping John, I'll actually forgive him! Mod the HECK out of that thing, and make it as EPIC as you possibly can!
Can't really think of a better reason to mod TBH.
And John, PLEASE don't spend your remaining money on buying this off of Ebay when the auction starts!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nominee
WII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee
Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse
http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee
The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
Angel OD is offline   Reply With Quote
Old 23rd Feb 2012, 15:58   #16
E.E.L. Ambiense
Acrylic Heretic
E.E.L. Ambiense's Avatar
E.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run Crysis
Just dropping in and throwing in my support too. I know I've been away waaaaaaay tooooo long, and I know it's just a project log banner, but I still wanted to help! If you need anything else guys, lemme know!
__________________
Latest Builds:
LilyPC - in progressBIO-A10 - MotM Jul. '12 Nominee Loser!"Movie Sign!" - in progressCheckMate - MotM May '09 Nominee Loser!BluBawx I - MotY '09 Nominee Loser!Lumière Noire - MotM Apr. '08 Nominee Loser!NOTalis w/ MNPCTech"Building Better Worlds" - MotM Feb. '08 Nominee Loser!
E.E.L. Ambiense is offline   Reply With Quote
Old 23rd Feb 2012, 16:02   #17
jokkos
Belgian beer modder
jokkos's Avatar
jokkos has yet to learn the way of the Dremeljokkos has yet to learn the way of the Dremel
I'm also here. This goes to show what a great community BT is.
__________________
Der_Meister: 100% completed, again... project log here.
jokkos is offline   Reply With Quote
Old 23rd Feb 2012, 18:13   #18
rchiileea
Multimodder
rchiileea has yet to learn the way of the Dremelrchiileea has yet to learn the way of the Dremelrchiileea has yet to learn the way of the Dremel
subbed
rchiileea is offline   Reply With Quote
Old 23rd Feb 2012, 18:27   #19
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
So much awesome... I'm glad yer back on the net, John.
@DarthBeavis - Sent you a DDC top to go with this rig. If we don't get a pump, well, Just throw it in as a matching paperweight. Let us know what you are short on so stuff can happen.
@EEl - EEL! EEEEEEEELLLLLLL!!!!
Cheapskate is offline   Reply With Quote
Old 23rd Feb 2012, 18:45   #20
KidMod-Southpaw
Also John and Bill, are there any parts I could help out with. Sure I have some spare modding gear too.
__________________
Reply
Tags
define r3, fractal-design window, hexagonads, internals, jhanlon303, mnpctech case mod, patriotic case mod, support jhanlon303, throws panties in
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
