Reply
Thread Tools View Mode
Old 15th Apr 2012, 02:23   #481
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.
Originally Posted by DarthBeavis View Post
Guess the only proc I have is an 2500k so it is installed . . .
installing Patriot stuff nao
Tomorrow, plan to use air-cooling so I can install OS and do a short burn in. Geno said the fittings should be at his place this week so my place the week after. Also waiting on the Mayhems coolant and replacement PCI-E cable then it is all here (we have a 580 instead of 570 so we need an 8 pin and 6 pin instead of two six pins )
I saw the pictures on FB with you out and about with family. You have no idea how much family means until they are all gone. My post was a banter between me and Cheaps. No reflection on you. Cheaps and I go WAY back. The boy built a waterblock for me with no electricity in the middle of a hurricane. Drill press by hand? Friendship.
john
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 15th Apr 2012, 02:23   #482
DarthBeavis
Supermodder
DarthBeavis has yet to learn the way of the DremelDarthBeavis has yet to learn the way of the DremelDarthBeavis has yet to learn the way of the DremelDarthBeavis has yet to learn the way of the DremelDarthBeavis has yet to learn the way of the DremelDarthBeavis has yet to learn the way of the Dremel
Grills look awesome sorry for blurry pic but my camera should be on its way from the shop . ..
__________________
Check out my modding blog: http://outoftheboxmods.com/
DarthBeavis is offline   Reply With Quote
Old 15th Apr 2012, 02:24   #483
DarthBeavis
Supermodder
this is how i will mount the res but cannot do that until I have fittings
__________________
Old 15th Apr 2012, 07:57   #484
rchiileea
Multimodder
rchiileea has yet to learn the way of the Dremelrchiileea has yet to learn the way of the Dremelrchiileea has yet to learn the way of the Dremel
Glad to see the patriot stuff at last looking forward to more updates
rchiileea is offline   Reply With Quote
Old 15th Apr 2012, 09:07   #485
Paslis
Supermodder
Paslis's Avatar
Paslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run Crysis
yes it looks awesome
Thanks mate i see you holding it.
Paslis is offline   Reply With Quote
Old 15th Apr 2012, 16:19   #486
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Ouch. I see some 90's in your future... That res is gigantic!
Cheapskate is offline   Reply With Quote
Old 15th Apr 2012, 16:59   #487
DarthBeavis
Supermodder
yep got some BP rotaries here
Gonna bolt the res to the HDD cage good thing I ship with Instapak . . .if that thing broke loose in shipping it would great so much damage it might take down the airplane in flight or make the UPS truck go off the road
__________________
Old 15th Apr 2012, 17:32   #488
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
I was wondering how the res would fit in thinking it would cover a good bit of the motherboard, just shift the gpu lower, of course.
It is an awesome feature for the rig & would have definitely been a shame for it to be hidden.
Waynio is offline   Reply With Quote
Old 15th Apr 2012, 18:59   #489
Plodder
Modder
Plodder has yet to learn the way of the Dremel
New members first post.
I am so lucky to be a member of such a comunity, (a new super nooby member but still...). You are all such an inspiration for my modding and life in general.
@John, I hope you are as well as you can be and though i have nothing material to offer, (very poor and struggling to pay bills atm sorry ), i send you my best wishes.
Thx to you all.
Plodder is offline   Reply With Quote
Old 15th Apr 2012, 19:02   #490
SilveR_172
Supermodder
SilveR_172 has yet to learn the way of the DremelSilveR_172 has yet to learn the way of the Dremel
What about fitting it in the HDD rack and it looking clean plus it'll have more support there ? My 2P thats all =0 Things are looking brilliant cant wait for this to go up , Ship to uk ? :P
SilveR_172 is offline   Reply With Quote
Old 15th Apr 2012, 19:40   #491
DarthBeavis
Supermodder
Does not fit . . .
__________________
Old 15th Apr 2012, 21:07   #492
Furball Zen
Shut up and Mod
Furball Zen's Avatar
Furball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run Crysis
Wow, grills do look good in red Yea, i didnt pull the paper off so this is the first time seeing one other than the black test model.
__________________
Life. Liberty. The pursuit of those who oppose it.
Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide
@furballzen
Furball Zen is offline   Reply With Quote
Old 15th Apr 2012, 22:29   #493
yougotkicked
A.K.A. YGKtech
yougotkicked's Avatar
yougotkicked has yet to learn the way of the Dremelyougotkicked has yet to learn the way of the Dremelyougotkicked has yet to learn the way of the Dremel
I hate to be the bearer of bad news, but I don't think you should mount that graphics card in the secondary slot. Most 1155 boards will only give the second slot 8 PCI-E lanes whether or not the first slot is populated, I'm checking the documentation for the board you're using (GIGABYTE GA-P67X-UD3-B3 right?) and it seems to be the case with this one as well.
Any way to mount it on the lower cage just above the floor radiator? could make wire management and tube routing a pain but it looks like it would fit.
__________________
Corsair Carbide 500R ::::: NINE (!) case fans
Intel I5 2500K @ 4.5Ghz ::::: AIR cooled (modified tuniq tower 120)
Asus P8Z68-V LX ::::: 16GB 1866 9-9-9-27-1T (1.4v) Samsung low profile 30nm's
Gigabyte Radeon HD 6870 1GB ::::: 1TB Samsung Spinpoint F3
128GB Intel SSD :::: 2x WD 1TB drives in RAID 1
yougotkicked is offline   Reply With Quote
Old 15th Apr 2012, 22:32   #494
DarthBeavis
Supermodder
Show me tests that indicate an appreciable difference between 8 and 16
http://www.tomshardware.com/reviews/...pu,2678-5.html
__________________
Old 15th Apr 2012, 22:38   #495
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Yay! You chose the spot I suggested. Are you going to also create a bracket like the one I sketched for you?
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 15th Apr 2012, 22:46   #496
DarthBeavis
Supermodder
thinking about the bracket part . . .might just make a simpler one want to keep it mounted close the the drive cage
__________________
Old 15th Apr 2012, 23:31   #497
yougotkicked
A.K.A. YGKtech
Interesting, I hadn't seen an article on the topic before. As a computer science major I would not have thought the bandwidth was so unnecessary, if you cut the bandwidth of the RAM link in two, you see an immediate 50% performance loss. I'll be moving my graphics card now, it's blocking the airflow of 5 case fans because I assumed it needed to be in slot 1.
__________________
Old 16th Apr 2012, 02:37   #498
DarthBeavis
Supermodder
as a former software engineer I can tell you the bandwidth is not saturated When I am not modding I also work events for ASUS and NVIDIA so I try to keep up with details like this as I give a ton of advice out while on the road.
__________________
Old 16th Apr 2012, 05:03   #499
yougotkicked
A.K.A. YGKtech
It makes a lot of sense now that I think about it. I know that when they make new format standards they make sure there is enough room to grow (the latest gen of CF memory cards' firmware can address a petabyte-scale capacity), I just didn't really think about how much throughput each lane could deliver.
HURRAY FOR LEARNING!!
__________________
Old 16th Apr 2012, 12:04   #500
mrMonkeyChunks
EVGA Cheesecake
mrMonkeyChunks's Avatar
mrMonkeyChunks is the Cheesecake. Relix smiles down upon them.mrMonkeyChunks is the Cheesecake. Relix smiles down upon them.mrMonkeyChunks is the Cheesecake. Relix smiles down upon them.mrMonkeyChunks is the Cheesecake. Relix smiles down upon them.mrMonkeyChunks is the Cheesecake. Relix smiles down upon them.mrMonkeyChunks is the Cheesecake. Relix smiles down upon them.mrMonkeyChunks is the Cheesecake. Relix smiles down upon them.mrMonkeyChunks is the Cheesecake. Relix smiles down upon them.mrMonkeyChunks is the Cheesecake. Relix smiles down upon them.mrMonkeyChunks is the Cheesecake. Relix smiles down upon them.mrMonkeyChunks is the Cheesecake. Relix smiles down upon them.
Its very touching to see an online community come together like this.
I just wish that I had some hardware that I could give towards the build, unfortunately it all seems to be sorted out.
__________________
NZXT Phantom 820: i5 3570k @ 4.5Ghz | Gigabyte G1.Sniper 3 | 16GB DDR3 Crucial Balistic Tracer RAM | 2 EVGA GTX 670 SC+ 4GB | Samsung F3 1TB | 120GB Corsair Force 3 SSD | 120GB Kingston Hyper x SSD | Corsair 850W |
Cooling: 360mm, 240mm radiators, 2 EK 670 Fullcover blocks, EK Supremacy, 250ml res, 2x MCP350 pumps
KBT PURE | Cyborg R.A.T 7 | 27" & 24" ASUS monitors
mrMonkeyChunks is offline   Reply With Quote
Reply
Tags
define r3, fractal-design window, hexagonads, internals, jhanlon303, mnpctech case mod, patriotic case mod, support jhanlon303, throws panties in
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
