#1 |
Multimodder
Project Arclight
![]() Behold my latest creation to be Project Arclight will be a huge case built on an Enermax Fulmo GT chassis with some serious power behind it also provided by Enermax in the shape of the mighty Platimax 1200watt psu Te Arclight will be an all acrylic outer shell with a double action doors and servo actuated fan intakes that will open and close based on fan speeds, the shell will have a double tone look with layered panels of black and flourescent blue to accent every edge even the 100s of vent parts will have glowing edges, the interior will be a partitioned system very much like the custom partition for my other project "Sulaco" but with far more refinement Much of the details i would like to keep slightly underwraps untill I post them for that extra mystery, heres a little peek at the exterior ![]() ![]() ![]() several sponsors are already assisting me on this build and there help is as ever massively appreciated i simply would not be able to do this without them Acrylic and solvent supplied by Hindleys. These guys are amazing, catering for 100s of different types of materials from plastic to metal and everything in between. And allays happy to answer even the craziest of questions a modder like me can ask Massive thanks to Enermax for supplying a Fulmo GT, Platimax 1200wall and a vast array of case fans from there amazing Vegas range Thanks also go to Bitfenix for givign me so much on my last project that i have enough spare to add to Arclight ![]() ![]() ![]() ![]() Stay tuned for a lot more to come........ Last edited by tobyak; 3rd Nov 2012 at 16:36. |
#2 |
Shut up and Mod
Its always nice to get stuff for free
__________________
Life. Liberty. The pursuit of those who oppose it.![]() Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide @furballzen |
#3 |
Supermodder
looks like it's going to be crazy acrylic time! =)
#4 |
Fenrir The Wolf
Nice design. Looks very sharp.
#5 |
Multimodder
IT is going to be a pretty hard build, over 100 parts on the intakes and i need to add all the pull rods and actuators
#6 |
Beyond Complexity Lies Simplicity
Nice one ! Subbed for sure !
__________________
Current Build : BORG COSMOS II Current build : 2001 - A Case Modyssey Finished build : IMPERIAL AT-AT Finished Build : USS EURISKO - Intrepid Mark II Class www.asphiax.wordpress.com |
#7 |
Multimodder
WoW a lot of time has passed since i was last able to get on this project, such a busy year
Well that was then this is now, and its all go from here, hew hardware, new materials, new tools Arclight was origionialy designed for the Enermax fulmo GT a huge and brillicnt case, but time has marched on and Azza have offered me the chance to use there superb Genesis 9000, so a little redesigning was called for, Concepts for the intakes have been redesigned to better fit the new chassis and all the electronics have been brouht in and in some cases teaching myself arduino voodoo Heres the first batch of parts going in to the chassis the origional blade design and array have changed slightly from this ![]() to this ![]() ![]() The array control mechanism of a pull rod attached to a servo will remain much thesame as the origional Some parts will need to be scrapped or completely changed to fit the new body shell such as the origional concept for the sides ![]() the new version will be a wait and see but they look great in the planning Well this project will need a huge number of mechanical and electronic parts in top of your typical PC set up This arduiuno kit courtesy of Phenoptix is a great start to the project and will be controlling several of my lighting systems including a rather clever hack of a LOL shield ![]() LOL shields and old school bar graphs will be making quite an appearance as accenting lights, and yes there will be larson scanners ![]() Servos and actuators will be making a big appearance including several mechanized fan intakes and a large front panel "shield" ![]() ![]() And to wrap up this update and REBOOT, Kingston have graciously given there support and provided some of there swesome products the amazing HyperX 120gig SSD ![]() and a quad kit of DDR3 2400MHZ RAM ![]() ![]() Stay tuned |
#8 |
Never stuck with stock@Hotmods.net
I simply don't understand why I hadn't subscribed to this project log already.
Oh well - error corrected!
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#9 |
modeteer
exciting! I'm going to be using micro controllers and similar gear in a build I'm working on designing still. I'm stoked to see what you come up with!
#10 | |
Multimodder
http://www.pololu.com/catalog/product/1350 a lot cheaper then using an arduino shield and can control 6 rather then 1 |
#11 |
Multimodder
Just a little update today
An absolute ton of cutting and sanding today Well i dont have access to a lazer and i need a lot or duplicate pieces to were rocking it old school with a stencil ![]() And what better to cut out my many many parts than a home made table saw, complete with mitre fence ![]() Problem.... no sharpie..... solution... stick paper to plactic cover on acrylic and use engineering pencil... copy template.... move.... repeat.... over, and over ![]() and now its on to cutting first up divide the sheet up in to manageable blocks ![]() then drill holes for turning the cutting blade in ![]() some more cutting to further separate each component ![]() first half done, all rough cut ![]() bit of refining the shapes to reduce sending ![]() sanding time...... 1 of 24 ![]() and yes that is a dyson taped to the extraction port all done for the day, 24 pieces of the main intake array rough cut and rough sanded ![]() i may never want to see acrylic AGAIN after this build.... |
#12 |
Supermodder
Thats alot of cutting...
#13 |
↓ Don't trust that face!
Awesome concept.
![]() -Personally, I wouldn't shape the parts too accurately until you get the layers glued together. That would make 3X less sanding and shaping.
__________________
#14 |
The Mod Zoo Podcast Host
I say that all the time....
Good work so far Toby!
__________________
Kyle van der Merwe host at www.TheModZoo.com Podcasts!
Project: Codename C :: LANBOY APOCALYPSE (built with MNPCTECH!) :: Project: Deadline :: Project: MNU Projects supported by EK Waterblocks, MNPCTECH, Fractal Design, NZXT, ENERMAX, and TM3 Connections Core i7 920 D0 :: Asus P6T Deluxe v2 :: 6GB Crucial BalistiX :: Asus GTX 570 :: ENERMAX Platimax 850W :: OCZ Agility 3 120GB :: 4x Samsung SpinPoint F3 1TB |
#15 | |
modeteer
I'm thinking I will probably use a Pic controller because I have an extra kicking around my house somewhere. My needs for the motor are pretty simple though, and I might end up going with a different solution. This is for linear movement not rotary, so slides, springs and dampers might end up being the better way in my case.Looks like your making some awesome progress though man, keep the updates coming! |
#16 |
Supermodder
One of these days, they'll make a Sketchup mod that models the lighting too.
Subscribed. Mod on my friend. |
#17 |
modeteer
#18 |
Supermodder
You can get Sketchup to show the light and shadows cast by various light sources and how they interact with your modeled parts?
#19 |
Multimodder
damn, ive not been getting my updates on replies so sorry for late get backs
@Cheapskate Well ahead of you dude, spotted that early so i broke out the WW2 era Russian glass syringe and the dichloromethane. results in next update ile have up over the weekend @Kylevdm this is just one grill..... 3 more smaller fiddely ones to go @sixfootsideburns i know a great UK online store to get actuators, the stripped down motor with threaded shaft versions, there not pretty or refined but they are dirt cheap and have enough power for PC use @monkeyfun learn solidworks ya bum next update over the weekend, keep em peeled, and Kyle/Cheapskate ile see you on the podcast |
#20 |
Car lover and Speed Junkie
Great idea on the slats! hope you dont mind if i steal that idea for the plans on my first build, if i can get my ass lit on fire and get a job.
| Tags |
| (6) 20/15, acrylic, servos |
| Thread Tools | |
| View Mode | |
