#21 |
Multimodder
#22 |
Car lover and Speed Junkie
thanks.
#23 |
Multimodder
Although ive had a long break from posting my work has continued, i finally have time to sit and type
So i shall pick up where i left off The rough cuts were plastic welded in to pairs of one blue one black each with liquid dichloromethana injected in to edges to form 12 completed pairs After coming off the sander for the first time the edges are still as rough as a badgers behind but the biggest thing to address is the notch in the top that neither the belt or disc sander can get in to So out come the hand files ![]() 4 hours later and the stack is complete ![]() The edges still needed quite a lot of refining so on to the hand sander .... I broke my sender.... just imagine a lot of swearing and a run to the shop.... After sanding... ![]() ![]() A little test fit and tease before polishing the edges of each intake ![]() Three hours of polishing with a drill press slightly modified to server as a bench grinder/buffer and we have.... ![]() another 2 hours and we have a result ![]() A long time to finish from rough cut to finished intakes but they do look damn good if i do say so my self Next up, modding the roof and base plastics |
#24 |
bit-tech sponsor
Yay! an Update! and those will fit the theme very nicely Toby
__________________
Shop Our Case Mod Store We Ship International Orders! Client Builds / FIREFLY PC / DISTRICT-9 PC / Official STAR TREK PC / WOLFENSTEIN PC / LANBOY APOCALYPSE PC / CodeMasters DiRT Showdown PC |
#25 |
Supermodder
keep on modding! this is going to be good looking!
__________________
Works as a tool retailer, glad if i can help someone with tool questions! Hopes that i someday completes my first scratchbuild... |
#26 |
Supermodder
Great concept dude. Subbed.
#27 |
Multimodder
Time for the update that has been a long time coming
As most of you know the case changed from from an Enermax Fulmo GT to an Azza Genesis 9000 as the Genesis offered a stronger frame and more internal space to work with.... before work started it looked like this... ![]() ![]() and the chassis itsself looked like this.. ![]() IIt is a brilliant reverse ATX chassis, very well made and strong enough for an 16Stone man to stand on, BUT as is the case with mods some structure needed to be removed so after an hour with a drill we have ![]() Frame all ready to measure up the floor panels and internal enclosures As this case is somewhat modular in terms of its plastics i was freed up to mod sections in waves rather then all at once starting with the floor plate, this would also serve as a test run for the metals replacing all the red inserts in the bezels The base plastics are very heavy built and massive ![]() But the vents need to go to make way for metal inserts ![]() ![]() ![]() Perforated plate form ebay makes freat replacement vent intakes for the floor ![]() ![]() Ahh hot glue what would i do without you.... |
#28 |
Multimodder
All good mods start with a plan.... well thats me out of the window
But at least i got some penile work done measuring up the plastics for the enclosures ![]() ![]() Overkill 120 grills make handy stencils of.. erm... overkill 120mm grills Acrylics cut to size and welded with Hindleys Dichloromethane ![]() ![]() Ahhhh all snug fitting The psu, most of the tubing and a very thick 60x240mm rad will be housed under this. This 60x240mm rad to be exact, with a pair of Enermax TB silence 120mm fans on pull configuration ![]() Sharing the floor will be an Enermax Maxrevo 1200Watt fully modular PSU... it is MASSIVE ![]() ![]() I may have to many spare cables To kill some time waiting for some parts i partook in another of my favourite basstimes... no prizes for guessing what these 2 SciFi icons are ![]() ![]() Plastrics cut and marked up for the optical bay covers, the optical and hdd bay area will house both pumps as well as most of the tubing of the twin loops and access hatched have been cut in to the floor compartment to get to rad fittings and install cables and tubes
#29 |
Multimodder
First test fit of all the enclosures plus checking that weight of the res holders will not warp the top of the enclosure
![]() Pass through holes cut for Tubing to and from the twin res, due to access the PSU, bottom Rad and main PSU looms are already installed in the lower enclosure ![]() Well that's enough of the enclosures for now on to the roof again After installing the rails and letting the welds cure in go the 12 vent components in to there sockets, until the retention arm goes in they can move through 140deg ![]() ![]() I suspect that Dust is going to be an issue... just a hunch ![]() but DAYUM they look good lit ![]() I made a small plate to hold the servo, amazingly a tiny 9g servo can pull the vents, the full array weight close to 3lb ![]() ![]() ![]() ![]() Yes i know the metal wire is a little ghetto but im waiting on an RC pull arm |
#30 |
modeteer
Dude... I'm gone for two minutes and look what I missed!
Maybe I should leave more often. Looking epic man |
#31 |
Multimodder
it is about 90% built and functional, putting together the updates now
#32 |
Multimodder
With most of the structure and covers complete i can start the loops, that was a tad more involved than i expected, clearance between the top of the PSU and the Top of the floor enclosure is just big enough to get a 1/2 OD tube through... and i need to get 6 through it
Starting off... install res and attach to mounting blocks on the floor, plus attaching the main tubes from the CPU and MB waterblocks and taking then to the bulkhead ![]() ![]() Next up install pumps and run feed tubes through the floor plate to the lower rad and run the outputs to the waterblocks, as i side thought i added a fill port and hooked up the top 360 radiator to complete both loops ![]() ![]() Well at this stage i was going to fill my loops but my daughter has other ideas ![]() After a short fight that i eventually won with a stunning pile driver i finally filled the loops ![]() ![]() ![]() ![]() yay its leak free.... well it is now, it kind of wasn't but lets not talk about that.... nothing to see here... move along |
#33 |
Multimodder
Construction is 90% complete and its already in service as my main game machine, side door needs a window and massive changes are going to be made to the front of the case
So im going to show off some of the key features so far modified intakes and bottom deck enclosure ![]() Access ports ![]() Concealed tubing ![]() ![]() ![]() ![]() Tidy tubing with bulkheads ![]() Back plate mounted SSD and HDD ![]() Damn good lookin if i do say so myself ![]() MUCH MORE TO COME |
#34 |
Uber Noob
Love this mate,
cant wait to see more! |
#35 |
Multimodder
Few weeks for the rest, custom GPU shroud, need to shroud the top rad, and plan out the motorized front bezel
OH YEAHHHHH i said motorized |
#36 |
*hyperventilates* update.... already awesome.
![]() Krud! With all these promised updates im already out of beer ![]() Some rep, for the fact that you beat me to using the slats idea. Also, great idea for the res.
__________________
![]() I *am* the guy who loves too many threads to bump them all. Last edited by siliconfanatic; 8th Jan 2013 at 20:25. |
#37 |
Multimodder
I am VERY pleased to announce that EK is now official sponsoring Arclight, they are kindly supplying enough equipment to rebuild the entire double loop set up
![]() Stay tuned for a supply drop and more updates |
#38 |
Beyond Complexity Lies Simplicity
Congratz and yummy-yummy on the reservoirs !
Good concept blending!!
__________________
Current Build : BORG COSMOS II Current build : 2001 - A Case Modyssey Finished build : IMPERIAL AT-AT Finished Build : USS EURISKO - Intrepid Mark II Class www.asphiax.wordpress.com Last edited by ASPHIAX; 11th Jan 2013 at 19:06. |
#39 |
↓ Don't trust that face!
Lookin' sweet dude!
You have a bad case of modder's carpet there.
__________________
#40 |
Multimodder
It is finally time for an update
As most of you know by now a short while ago i acquired a small CnC mill with which to being my twisted imaginings to reality. here is how it went ![]() As i completely forgot where i left my shots of my mill here is a stock shot of the exact same model, I was rather dubious of the quality of the machine as it is a cheap ebay Chinese machine but after ironing out a few bugs i do haft to say this is a great machine.... i had to mod it of course ![]() i had heard that as the boards in the control boxes were generic i should find additional headers for a probe and limit (home) switches ![]() ![]() ![]() just what i wanted to find, headers for limit and probes, idon'tcurrently have a need for a probe but a limit (home) switch is a must have ![]() finding areas to mount the switches was a little tricky given the spaces i had to work in. i wont bore you with the details/ ![]() ![]() ![]() ![]() starting simple learning my way around the machine and everything went well..... if you forget the time i put an engraving bit part way through my T slot bed. the end result for a simple quick run was rather impressive although settings still needed some refining/![]() the first proper case parts to roll off are roof intake vents, the original vents took months to make by hand but with a cnc i can improve on them and get perfect results in just a few hours to cut all 30 of the new intakes (more about those in a later update) |
| Tags |
| (6) 20/15, acrylic, servos |
| Thread Tools | |
| View Mode | |
