Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 24th Feb 2012, 23:42   #1
cillerbee
Minimodder
cillerbee has yet to learn the way of the Dremel
Overclocking i7-920 Need help To 4.0GHz+ Any tips are welcome =)
I've had my current i7-920 Since 2009 and over the course of its life I've tried many times to hit 4.0 GHz while being stable with a vcore of about 1.42. However no matter what different settings of my own and those from around the web I've tried I've had no luck. I'm hoping maybe some direct help from fellow forums members and overclocking enthusiasts will lead to better results.
My current settings are:
Temp @ Idle: 37 C
Temp @ 100% Load over 1 Hour: 67 C
-So far I've been Stable at 3.9 GHz with a VCore of 1.425V at 100% Load
-I tried 4.0 GHz with the same VCore and Settings I crashed in 3 Mins @ 100% Load
-I've tried underclocking
-I've also tried using multipliers of x19, x20 and x21
-Under the assumption that this is a Bad Bin CPU I have hence the High Voltages to run stable @ 100% load
My current Mainboard is a: ASUS P6T V2 Deluxe
Ram: 12 GB of Triple Channel G.SKill Ripjaws 1600 Mhz Ram
Cooling: Custom Water cooling with just CPU Loop on EK-XTX 360 RAD and RASA CPU Block
What I'm trying to achieve:
- 4.0 GHz or Over
- No permanent Damage to CPU for 5 Months
- Idle Temps Below: 50 C
- Load Temps Below: 80 C
I don't mind trying any extreme solutions as long as i don't damage my CPU permanently or at least for the next 5 months.
Thanks for taking a look, any help and or tips would be appreciated =)
cillerbee is offline   Reply With Quote
Old 25th Feb 2012, 15:43   #2
xxxsonic1971
W.O.T xxxsonic1971
xxxsonic1971's Avatar
xxxsonic1971 can run Crysisxxxsonic1971 can run Crysisxxxsonic1971 can run Crysisxxxsonic1971 can run Crysisxxxsonic1971 can run Crysisxxxsonic1971 can run Crysisxxxsonic1971 can run Crysisxxxsonic1971 can run Crysisxxxsonic1971 can run Crysisxxxsonic1971 can run Crysisxxxsonic1971 can run Crysis
hello bud, i can get my 920 to run at 4.2 with about 1.375 core volts......i have my ich voltage a bit more than yours, i also have to give it more pll than you are giving yours.
i noticed you got uclk and qpi on auto, i always have mine set at a number.
thers lots of good i7 overclocking guides on the web.
good luck!
xxxsonic1971 is offline   Reply With Quote
Old 25th Feb 2012, 15:50   #3
noizdaemon666
I've been away far too long
noizdaemon666's Avatar
noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.
It may help if you put QPI link speed from auto to 16x (I have this on my p55 board, as well as 18, it could be 32 and 36 on yours). Oh and I found disabling Virtualisation Tech helped stability above 4GHz, unless you need it of course. Oh try using a bclk of 200 and a 20x multi. Or a 190 bclk and a 21 multi to get 4GHz. Oh and I think uclk is the uncore speed which should be 2x RAM speed + bclk, but I'm not overly sure on that.
After that my knowledge of X58 runs out lol
__________________
AMD A4 5300 @ 4GHz | | 4GB 1600 Patriot | 128GB SSD | 500GB Samsung HD501LJ | 320GB Hitachi 2.5" | CX430 PSU
noizdaemon666 is online now   Reply With Quote
Old 25th Feb 2012, 16:10   #4
cillerbee
Minimodder
good luck!
I'll give those two a try. I've actually tried a lot of the guides on the web including the one on Bit-tech and found those unsuccessful which is why i decided to ask just for this case.
Going to give the QPI and V-tech off and see how that goes. I already tried 200 for bclk with 20x multi but anything beyond 195 and I cant get past the boot screen.
If it helps I have a C0 revision chip.
Old 25th Feb 2012, 17:55   #5
wiby645
Multimodder
wiby645 has yet to learn the way of the Dremelwiby645 has yet to learn the way of the Dremelwiby645 has yet to learn the way of the Dremelwiby645 has yet to learn the way of the Dremelwiby645 has yet to learn the way of the Dremelwiby645 has yet to learn the way of the Dremelwiby645 has yet to learn the way of the Dremelwiby645 has yet to learn the way of the Dremel
i bought a bundle from Marvin-HHGTTG ,he clocked his to 4.2Ghz. currently i have it running at 3.8Ghz to keep the temps down. hope this link helps you
http://forums.bit-tech.net/showthread.php?t=211550
wiby645 is offline   Reply With Quote
Reply
Tags
bad bin, help!, high voltage, i7-920, overclocking
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
