Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 25th Feb 2012, 00:04   #1
GregTheRotter
I Mod, Therefore I Own
GregTheRotter's Avatar
GregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for president
What do I need for these speakers to work? Do I need an amp?
Hi guys, am pretty clueless with regard to buying speakers. Do I need a seperate amp etc to rig a pair of Q acoustics 2020i bookshelf speakers up to my computer??
__________________
Main rig: i7 920, 12gb 1600mhz ram @ 1333mhz, Asus P6T Mobo, Crucial m4 128gb SSD as OS disk, Samsung 1tb F1, 2x1tb F3 as storage, 1xSamsung F4 2tb, Creative X-FI Fatality pro soundcard,2 x EVGA GTX 670 in SLI, Dell U2711, Nec 20WGX2.
Photography gear; Nikon D700, Nikon 16-35 F4 VR, Nikon 24-70 AF-S, Nikon 70-200 F2.8 VR II, Nikon 35mm F2 D,Nikon 50mm 1.8D, Nikon 85mm 1.8D, Micro Nikkor 105 f2.8 AI-S, Nikon SB-800, SB-900,
GregTheRotter is offline   Reply With Quote
Old 25th Feb 2012, 00:09   #2
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.
Most likely since they won't have any plugs, they'll likely have plugs for bare speaker wire, which you could solder to a audio jack, but it'd be easier to use an amp.
__________________
Uni Box:i5 2500K@5GHz|EK Supreme LT+Coolstream XT 240|16GB HyperX DDR3@1866MHz(in blue)|EVGA GTX670SC 4GB+EK FC670|MSI P67A-GD55||M4 256|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Sidewinder X5 + Intuos 4M
Audio: PC->TosLink->TEAC UD-H01->Schiit Asgard-> Denon 5000|PFE232|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 25th Feb 2012, 00:15   #3
GregTheRotter
Ok, so I found an amp. These speakers are rated to 75 watts RMS each, will this be too much for them?;
http://www.amazon.co.uk/Yamaha-Integ...0132321&sr=1-1
They are rated to 85 watts.
Do you want an amp thats more powerful than the speakers, or less? (Wouldn't want to damage the speakers).
__________________
Old 25th Feb 2012, 04:25   #4
MSHunter
I *am* a Dremel
MSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpitMSHunter is almost as Godly as yodasarmpit
Yes that amp would be fine. But have a look on
What HiFi
To get an idea what is best for your budget. It is a good yard stick.
http://www.whathifi.com/review/q-acoustics-2020i
If the amp has higher watts then the speakers then you have to be careful not to let any one turn up the volume all the way as that might damage your speakers.
__________________
PC: Silverstone TJ08B-E, 2500K, Corsair H80, 120GBVertex 3 MAX IOPS,GENE-Z , Corsair V. LP 16GB, Gigabyte 1.5GB GTX 580 Super Overclock. U2711
PC Audio: AKG 271 mk II + Samson Go mic. + Asus Xonar D2X
Amp: DENON PMA510AE, Speakers: TANNOY MERCURY F1
MSHunter is offline   Reply With Quote
Old 26th Feb 2012, 10:53   #5
Picarro
Picarro's Avatar
Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.
Most speakers are actually damaged because someone turns up the volume on an amplifier that's not powerful enough, not vice versa.
Excuse my brevity - sent using Tapatalk
__________________
Intel Core i5 2500k @ 5gHz -:- Gigabyte Z68X-UD3H-B3 -:- 2x4 gbCorsair Vengeance 1,5v 1600mHz -:- Gigabyte Windforce X3 GTX 670 -:- Crucial M4 128 gb -:- Samsung F3 Spinpoint 640 gb -:- Corsair H60 with 2x Gentle Typhoon 1850 in push-pull -:- Corsair HX650 -:- Lian Li A05FN -:- Dell U2410 flanked by 2x Dell U2001FP -:- BenQ W1000+ -:-
Picarro is online now   Reply With Quote
Old 26th Feb 2012, 11:56   #6
Cleggmeister
Of reasonable knowledge...
Cleggmeister's Avatar
Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.
Don't worry about specifications, those speakers will run fine with the amp you mention, claimed power output and ratings are pretty useless indicators.
If you could get an amp with a digital input for sensible money you may get better performance from your sound cards digital output.
__________________
Pooting: Antec 300, P6T SE, i7 920 (3.20), Corsair F120SSD, 3x1TB HDD, 9Gb (1600XMP), GTX560Ti 2Gb (880/1760/2100), Win7 x64.
Grooving: Linn LP12, Klimax DS, Klimax Kontrol, Aktiv Akurate x 10 with Aktiv 242's.
Watching: WDTV Live to 50" Panasonic.
Serving: HP Proliant Microserver N40L running Openmediavault.
Cleggmeister is offline   Reply With Quote
Old 26th Feb 2012, 13:00   #7
dead beat
Rippin six 4 life
dead beat's Avatar
dead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for president
As a rule of thumb, you should choose an amp with a power rating that is 1.5 - 2 times the rated power of the speakers.
__________________
ASUS ROG Maximus IV Extreme-Z68 | Intel i7 2600K @ 5.1Ghz | 2x EVGA GTX680's SLI (water) | 8GB Corsair Dominator GT RAM @ 1866Mhz | Corsair AX1200 PSU | Crucial M4 256GB SSD | 2 x Samsung Spinpoint F3 HDD's | Dimastech Easy bench Dual V2.5 | Dell 3007 WFP-HC 30" monitor | Custom dual radiator waterloop
Photography gear: Nikon D800 | Nikkor 24-70mm f2.8 | Nikkor 70-200mm f2.8 VRII | Nikkor 35mm F2/D | Nikkor 50mm 1.8D | Nikkor 85mm 1.8G | Nikon TC-14E II | SB-700 Speedlight
dead beat is offline   Reply With Quote
Old 26th Feb 2012, 13:06   #8
Picarro
Picarro's Avatar
As Dead Beat says. Get an amp with around 120-140 watts on each channel. If you cannot find any new ones within your budget, try searching for used amplifiers. Most amplifiers can last 10's of years. We currently have 3 in the house. Two of them are over 15 years old and the youngest is 5. As long as you don't push them to maximum sound levels 24/7 a good amplifier will last you years and years.
__________________
Old 27th Feb 2012, 20:09   #9
Cleggmeister
Sorry folks, the wattage advise posts above arent correct. You dont need 100+ watts to drive a 2 way bookshelf speaker. Many valve and class A amps deliver 5-20w and will vastly outperform a 200w mainstream product. A good, budget NAD amp delivering 30wpc will sound fine and drive these all day. See if you can pick up a used but mint NAD 3020i, there were thousands sold in the 90's and one which has been looked after will be fine for another 10 years. Pay £30 or so.
__________________
Old 27th Feb 2012, 20:16   #10
dead beat
Rippin six 4 life
dead beat's Avatar
No they're not.
For a solid state toroidal amp he should be looking at around 1.5 times the rated power of the speakers. The extra amp power is useful as a protective measure aswell as providing headroom in the system.
Nobody is suggesting he spends a fortune.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
