#1 |
Supermodder
The green water of class
Hello I introduce myself my name is Ermanno I love modding and now I want to present my work.
I hope you like it, the path will be 'long. It takes time ideas and furthering your friends crazy. The project is in most 'parts, the first will be' all the components in brushed stainless steel I apologize for my English but I'm 'using google translator ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us Last edited by Corsaronero333; 26th Feb 2012 at 20:24. |
#2 |
Supermodder
After 2 weeks the pieces arrive ......
Still from the film wrapped and ready to be reshaped as needed. ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us Last edited by Corsaronero333; 26th Feb 2012 at 20:23. |
#3 |
What's a Dremel?
Hi Ermanno! Really nice to see your mod also there. Take the good flame of modding alive
![]() Cheerz! Tony |
#4 |
Minimodder
Welcome Corsaro... OMG this should be a great job.
For all... this guy is a great italian modder, I advise you to follow him. Good work Ermanno. |
#5 |
E22.BIZ
Thank you for taking the time to post here Corsaronero333 it must be frustrating having to use google translator!
I have seen a few of your builds doing the web circuits and if they are anything to go by this should be awesome!
#6 |
jack of all trades
That bares a passing (but much more elegant) resemblance to the HDD rack in the bottom of the Lian Li PC-A10. Hopefully the rest will continue to be sleeker and more intrinsically simple.
#7 | ||||
Supermodder
Eheheheheh is beautiful ...... but the change is coming. First of all I have to remove the upper part of the support, because hides too much HD or SSD, so doing I take this opportunity to drill further supports aloggiare SSDs also in more 'I have to drill and countersink the bottom then I'll need' for anchor at the base, after threading from M3 ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us |
#8 |
Supermodder
And here is the base perforated with 2.5 mm drill bit and threaded M3, the glazing was buffing because the original in my opinion was a little 'too, I made ??more so by the' soft, you'll notice the rear two special screws that are intended to guide the upper support
![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us Last edited by Corsaronero333; 26th Feb 2012 at 20:32. |
#9 |
Supermodder
From here begins the frenzy to see how it comes out, and basically makes' her dirty figure, everything fits perfectly
![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us As last working, I just have to remove all sharp edges with a file, mount the rubber ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us And after many adventures here we are with the supports of the SSD mounted ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us |
#10 |
Multimodder
Hi corsaro, you are a great
#11 |
Butt-kicking for goodness!
Looks good so far!
__________________
Uni Box:i5 2500K@5GHz|EK Supreme LT+Coolstream XT 240|16GB HyperX DDR3@1866MHz(in blue)|EVGA GTX670SC 4GB+EK FC670|MSI P67A-GD55||M4 128GB|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Sidewinder X5 + Intuos 4M Audio: PC->TosLink->TEAC UD-H01->Schiit Asgard-> Denon 5000|PFE232|Truth B2030A Monitors BT Feedback |
#12 |
↓ Don't trust that face!
Welcome to BitTech.
__________________
#13 |
Supermodder
#14 |
Supermodder
And here is the second processing, brushed stainless steel.
This keeps the same basic design as that of HD but change its width, the top will be slightly extended to cover the whole frame of a possible DVD. ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us Before starting work, I have to drill through with a peak of 2.75 and then threading from M3 and countersink the screws where they will go to find accommodations. ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us All parts including the base will be retouched with sandpaper to reduce the sign of the original glazing, considered excessive ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us Assembling the various pieces ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us |
#15 |
What's a Dremel?
Great work! This is simply beautiful.
#16 |
What's a Dremel?
Very interesting and well done. Excellent solution.
#17 |
Supermodder
thanks
![]() Tonight I continue not to leave you up with the processing and support for VGA slot for USB3 and the power button / reset ![]() ![]() ![]() ![]() ![]() ![]() Support for VGA ![]()
#18 |
jack of all trades
Bench?
Attention to detail is phenomenal. |
#19 |
Supermodder
wow man they look factory made real high class build going on here cant wait to see more!
#20 |
Supermodder
![]() ![]() Thanks guys, short new developments |
| Thread Tools | |
| View Mode | |
