Reply
Thread Tools View Mode
Old 17th Mar 2012, 08:52   #41
james-milligan
Multimodder
james-milligan has yet to learn the way of the Dremel
It does look pretty amazing I must say! Keep up the good work
__________________
i5-2500K, 1GB GTX 560-Ti Twin Frozr II, 2x4GB Corsair Vengeance DDR3 1600Mhz, Asus P8P67 Pro Rev3, 2x1TB Samsung F3, Gelid Tranquillo, 650W Antec TruePower New, Xigmatek Utgard, Dell U2312M
james-milligan is offline   Reply With Quote
Old 17th Mar 2012, 13:56   #42
quizz_kid
Squid
quizz_kid's Avatar
quizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysis
I LIKE ! ! ! The murano glass(not the most common of materials) looks sooo beautiful... It must be quite fragile though...
__________________
R-KAID-Я (in progress)
The Shrine / REDELUX / 4M / R-kaid-6 / Sputnik 0667
quizz_kid is offline   Reply With Quote
Old 18th Mar 2012, 15:01   #43
Corsaronero333
Supermodder
Corsaronero333's Avatar
Corsaronero333 can run CrysisCorsaronero333 can run CrysisCorsaronero333 can run CrysisCorsaronero333 can run CrysisCorsaronero333 can run CrysisCorsaronero333 can run CrysisCorsaronero333 can run CrysisCorsaronero333 can run CrysisCorsaronero333 can run CrysisCorsaronero333 can run CrysisCorsaronero333 can run Crysis
Originally Posted by Nutman View Post
Why at least 1000 modders didn't already subscribe to this thread is beyond me.
This is awesome - this is magnificent - this is....FANTASTICO!
I've been to Murano and seen those glass workers creating amazing pieces of art. This can NOT have been cheap and the "I rule the lot for the rest of eternity"-effect is on Corsaronero333's side for a very long time to come.
Thank you master glassblowers are fantastic, and as you say have a high cost, but I can assure you that they are all very well spent.
For the rest I will have 'surprise still hope
Originally Posted by Editor22 View Post
Wow that glass is amazing Corsaronero! looking really elegant.. true Italian style!
Thank you so much, I love the glass and all its features
thanks
Thanks to the glass you're right, it is not easy to find, but I can assure you that it is fragile, has 18mm thick, the only thing to be careful and tighten the screws, washers are rubber and not too heavy a hand
Corsaronero333 is offline   Reply With Quote
Old 24th Mar 2012, 06:57   #44
Corsaronero333
Supermodder
As soon as I can see you can place the arrival of the material, in this case we speak of the sleev NILS, to stay in theme colors I preferred to take the black, bottle green and finally green light, I think it will come a great job now we just have to wait for the arrival of the power supply ........ who will?
This is a small sample of vanilla-colored ...... I would say not bad
Old 26th Mar 2012, 15:29   #45
Corsaronero333
Supermodder
Returning home after a month, now takes up with small, early stage of assembly, good vision guys
Old 26th Mar 2012, 15:30   #46
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Gooooood, that's sexy.
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 26th Mar 2012, 15:39   #47
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Lovely. I'd be tempted to sneak LEDs into the pillars. I bet that glass lights up well.
Cheapskate is offline   Reply With Quote
Old 26th Mar 2012, 16:05   #48
RealWeaponX
Minimodder
RealWeaponX's Avatar
RealWeaponX has yet to learn the way of the Dremel
*subbed*
I can't wait to see how this work of art turns out...
RealWeaponX is offline   Reply With Quote
Old 26th Mar 2012, 17:02   #49
Cown
Multimodder
Cown's Avatar
Cown has yet to learn the way of the Dremel
This is absolutly amazing, this is not modding, this is art!
Did you make the glass look that way yourself or did you buy it and cut it out to fit your creation?
__________________
Finished Project:
ROG Meets Lian Li
Cown is offline   Reply With Quote
Old 26th Mar 2012, 17:36   #50
Corsaronero333
Supermodder
thank you very much
Brilliant idea I have 100 green LEDs will be used a test on a pedestal and then we will
Originally Posted by RealWeaponX View Post
*subbed*
Believe me I am more 'you eheheheheh
Thanks for the wonderful compliment, the glass is cut and drilled the second of the patterns of wood that I have prepared the first
New Uppp
Old 27th Mar 2012, 16:25   #51
peteski
long live the pc
peteski's Avatar
peteski has yet to learn the way of the Dremel
this is one sweet looking mod
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl,
peteski is offline   Reply With Quote
Old 31st Mar 2012, 16:12   #52
Corsaronero333
Supermodder
Thank you so much
Old 31st Mar 2012, 16:43   #53
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.
This is just fantastic, and it keeps getting better.
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - D-Link 320 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 6th Apr 2012, 16:21   #54
dirky90
Multimodder
dirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremel
very clean so far, i thought it looked good with the wood; and then that glass!!
dirky90 is offline   Reply With Quote
Old 6th Apr 2012, 16:56   #55
grejh0t
What's a Dremel?
grejh0t has yet to learn the way of the Dremel
amazing work
grejh0t is offline   Reply With Quote
Old 13th Apr 2012, 02:15   #56
deragoku
What's a Dremel?
deragoku has yet to learn the way of the Dremel
I read the other build, elegant summed up quite well, building on their real good FeAl metal.
deragoku is offline   Reply With Quote
Old 14th Apr 2012, 19:44   #57
Corsaronero333
Supermodder
Originally Posted by grejh0t View Post
amazing work
Thanks guys for a great evening up
In all the banquets that respect there is always a need for air flow at the top, in this case we have created a 2 and a right to the left, both featuring 80mm fan but ...... what has been created is well beyond .....
The media can raise and tilt freely to suit asks that a
Old 14th Apr 2012, 19:45   #58
Corsaronero333
Supermodder
There's still light and watercooling the entire system and see the beautiful.
In written corsaronero333 will be applied on the underside with a plexy green LED so you can highlight just the writing.
Old 14th Apr 2012, 19:46   #59
Corsaronero333
Supermodder
Last 4 photos for tonight, let's see what happens tomorrow
Old 14th Apr 2012, 20:47   #60
Corsaronero333
Supermodder
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
