#1 |
No disassemble!
Dragon Reworked [looking for ideas]
I have finally decided to start work on my old Chieftec Dragon case.
Currently, I have very little in the way of an overall plan for it, so I'm looking for ideas and inspiration. Here's the old girl Even without a clear idea of what I want to achieve, there's nothing stopping me making a start; so, after ten minutes of rivet drilling, I'm left with this... And this... I will be watercooling, so I do plan on a 360 rad in the roof and a 240 in the lower front panel. I'm currently degreasing and cleaning the parts, and I'm either going to paint them or send them for powder coating. Clearly I won't be doing any of that until I make the required cuts and holes. Anyone know the costs of powder coating, and a good company to use?
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes! 2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60 |
#2 |
FT03 is a bitch to watercool
ooooh the memories.
#3 |
No disassemble!
Slight change of plan. I have (will have) two 240 rads spare pretty soon, so I'm putting a 240 in the roof, instead of a 360; for now.
30 minutes with a jigsaw and file, plus around an hour's hard graft with an emery pad, and the difference is striking... My arms feel like they're gunna fall off. I am so unfit.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes! 2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60 Last edited by Spreadie; 26th Feb 2012 at 12:49. |
#4 |
The modding head is firmly back on.
as I was reading the first post I was thinking that's just crying out for a rad in the roof and you done it...Nice start, i love these cases.
It's got to have a window in it as well. |
#5 | |
No disassemble!
It'll be getting at least one window, Jeff - anything to reduce the amount of sanding required for those side panels. ![]() That reminds me, I need to find some flat u-channel edging; and I have to research the best way to remove acoustic matting.
__________________
#7 | |
No disassemble!
The rad templates are from MNPCTech. Clicky Cheers!
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes! 2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60 Last edited by Spreadie; 26th Feb 2012 at 17:30. |
#8 |
Multimodder
Oo, looking forward to this. That case certainly brings back a lot of memories
__________________
Project Fluttershy |
#9 |
Is the daddy!
I have much love for these cases, all i am going to say is 'keep it pure to the design' its a classic case which needs love and attention
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
#10 |
What's a Dremel?
Nice post thanks for sharing.
#11 | |
No disassemble!
The idea is that it will remain, and be recognisable as, a Dragon. However, if that means I only give it a lick of paint and throw a bit of fairy dust on there, what's the point? On the other hand, this is my first project log, and skills and budget are not exactly boundless. A perfect example is the front door and fascia panel - that is what identifies the case. So, my problem is how do I make changes to the front without destroying it's identity? I have a lot of thinking to do. Thanks for the comments, guys.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes! 2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60 Last edited by Spreadie; 27th Feb 2012 at 07:54. |
#12 |
Multimodder
Damn i´m getting old *memories*. Nice idea putting that good old trusting case to a new job. I should revive mine too
#13 | |
Is the daddy!
That was 7 coats of Ford Mexico yellow, each flatten and buffed, the main chassis painted black. I miss the case as it ended up in a skip after uni as I had no room for it ![]() However I do have another one shown bellow in my old render farm.With yours I would extend the hole pattern on the side panel into something interesting and back-light it
__________________
#14 |
No disassemble!
Nice looking Dragon!
Interesting idea about the hole pattern. I'm going for a window, but there's nothing to stop me making a pattern on the other panel. Food for thought, thank you. In other news, I'm praying for the rain to hold off this weekend, so I can make some more progress. I don't have a garage, unfortunately, and the shed is rammed.
__________________
#15 |
CPC_refugee
Had any ideas yet mate? Or is that asking too much?
__________________
Don't do today what you can put off until tomorrow Battlefield 3 adidan_uk BF3 Stats i7 3770 3.4GHz // Asus P8Z77-M // Scythe Big Shuriken // Gainward 570 Phantom // 8Gb G.Skill Ripjaws 1600MHz // 250Gb Samsung 840 // 650W Be Quiet Dark Power Pro // Lian Li V351b Apache Filled // Samsung T220 22" // W7 64 |
#16 |
No disassemble!
I'm still stripping it back to bare metal at the moment, mate. And building up the courage to try removing the acoustic matting.
__________________
#17 |
Making You Feel Old Since 2010
Looking good, nice start. Can't wait for more!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#18 | |
CPC_refugee
__________________
#19 |
What's a Dremel?
How is the modding going, as I have the same GIANT case doing nothing......
Tr3 |
#20 |
No disassemble!
The project is on hold at the moment, but by no means abandoned.
It's mostly stripped back to bare metal and the foam matting is gone, but all the bits are in a box in the shed for now. I have some designs made out for the side panel lighting, but I need access to a pillar drill to do them justice - there may be an old one up for grabs at work, I'm just waiting for a decision from the gaffer. Also, my mate is building a proper spray booth at the bottom of his garage - so I'm hoping to give it a really good paint job.
__________________
| Thread Tools | |
| View Mode | |
