Thread Tools | View Mode |
#41 |
*learning english*
great build!!! nice shiny copper end good style!!!
but I have couple OT questions first - is there white PCB MoBo on market to match color-scheme of uch great build? AFAIR there is white PCB GFX (GF ti5*0 KFA2 or smth)and second: what happened with this world that we have to modd case to make it white??? (yeah i'm that old )
__________________
10 re-plan "SuperBestBuild Of My Dream" 20 have a sleep 30 goto 10 |
#42 |
Multimodder
Wow, this is looking nice. Only suggestion I could make would be to paint the black plugs behind the mobo tray white...
__________________
Project Fluttershy |
#43 | ||||
Supermodder
![]() Thx Quote:
![]() ![]() I don't know i am just using it to make this build for the competition. I wont be using it when it is done Thank u ![]() Thx Quote:
![]() Quote:
![]() Update! Got my last piece from Imatex so i can complete the front now ![]() ![]() First i will start with filling up some holes in the front panel from the USB and card reader. ![]() ![]() ![]() When it is hard it time to sand the front panel. ![]() Sanded the grill also + make a small frame on the back of it so i can easly attach the RGB ledstrip to it. ![]() Ledstrip in place ![]() ![]() At the bottom i have made a small hole so there is enough room for the power cable ![]() I have also made a small movie of the RGB ledstrip that i can control with a remote ![]() ![]() Next step was to make the plexi front this needed some patience from before it was ready. ![]() To get a perfect angled corner i had to saw 2 pieces of wood whit a corner of 78degrace these 2 pieces i would set on my table with some sanding paper under it. ![]() The only thing i have to do is sand the plexi till i have my 78° corner on the plexi. ![]() Few hour later and 2 pieces later i had my corners of 78° ![]() ![]() The dirt ![]() ![]() Now i can assemble the 3 pieces of the front together with glue ![]() ![]() Drilling 4 hole to hold it all together against the front. ![]() Removing protection foil this will give u a better view ![]() Now when all the holes are made and taped it is time to paint the parts ![]() Only room left for power and reset bottom ![]() I have kept the original Cooler Master casebadge So i can place it on the front of the case.![]() ![]() All back together. ![]() ![]() ![]() Placed the front back on the case. ![]() ![]() ![]() ![]() ![]() ![]() ![]() The outside of the case is completed I only have to do some small improvements on the inside and then it is time for a photo shoot ![]() I also started the leak testing of the system.
__________________
Completed Projects: Cooler Master Silencio 550 Limited Edidtion Project White, Black Obsession, Project Umbrella |
#44 |
EvE Addict
Excellent build mate, that front plexi 3 part panel really finishes it off well, I think my favourite bit is the brass pipe work, looks soooo good, it's tempting me to go back to watercooling
__________________
|i5 2500K| |P8P67| |8GB DDR3| |GTX 580| |Corsair F3 120 SSD| |
#45 |
What's a Dremel?
That looks fantastic sir
#46 |
The German
EPIC finish to the front
good luck with the last little bits
__________________
Obsidian 650D | Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC | Cooler Master 850W Silent Pro M |
#47 |
Supermodder
Great work!
__________________
Current projects: Tydirium is on the way! Previous mods: | [/url]|Sandcrawler Mod| |Illuminated Mind| [url="http://forums.bit-tech.net/showthread.php?t=246505""]Graphite 5 Follow me on Facebook |
#48 |
Keep calm & mod on. =)
Subbed, starred & rep, this looks excellent mate, loving the hard polished pipe work & the modding throughout is top notch mate.
![]() Only found out about this 1 through motm. ![]() The front looks like an electric heater but a damn good looking one.
#49 |
Fenrir The Wolf
This is KillerMaster. Great job and amazing result.
#50 |
Minimodder
great looking mod
very impressive I'm curious, what material did you use to fill in the holes in the front panel? |
#51 |
What's a Dremel?
great mod men
#52 |
Multimodder
Superb build, mate! Congrats on the MOTM nomination!
__________________
[BUILD LOG] Project Ametros: Scratch Built Carbon Fiber Case + WC
Updated: Feb 29, 2012 |
#53 |
The modding head is firmly back on.
Those new panels are brilliant and that front panel...Oh wow, I love that, just looks superb.
#54 |
What's a Dremel?
Alain, do not change it.........it is excellent
#55 |
BTW that's a nice method for manually sanding a certain bevel.
#56 | ||||
Supermodder
![]() Thx Jezzafool Thanks Sarakon ^^ ![]() Quote:
![]() thank u Pranja Quote:
thx Bond0071993 Thank Motorsportcfd for u the same ![]() Quote:
![]() Haha thx i wont change anything ![]() Thanks Waynio, i had a lot of thoughts of how i would do it but this was the best way that i could think about.^^
__________________
#57 |
Pump Killer
Wow... Just... WOW!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nomineeWII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
#58 |
Ultimate Modder
You amazed us, now go get some more pictures of the build!!!!!
Mod on man!
#59 | |
The Keeper of History
What them guys said! john
__________________
My deepest gratitude to this community.
#60 |
Minimodder
thanks alain-s, but that's not what i meant (maybe didn't ask it right). what I was asking about was the specific material (filler) you've used to fill-in the front panel hole (audio, usb, etc.).
that is, i wanted to know what this stuff is: ![]()
| Thread Tools | |
| View Mode | |
