Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 31st Mar 2012, 22:16   #21
dunx
ITX is where it's at !
dunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysis
That's a tidy idea.... I can't find my Lego as I put it in the loft in the 70's ! ! !
A SKY+ PC sounds like fun though ?
dunx
__________________
Gigabyte Z87x OC-Force - i7-4790k @ 4.3 GHz - 16 GB Crucial Ballistix Tracer Orange/Blue DDR3 @ 1600 MHz - 256 GB Plextor SSD x2 - 6x WD Caviar Black 1TB SATA III HD's - GTX 970 x2- GTX 780 - Titan Black - Coolermaster 1250W PSU - Lian Li PC-D600 - 3x Noctua NF-A14 fans - custom water-cooled - Alphacoool 420mm rads in white - XSPC CPU block and D5 pump - Griffin Powermate x2
dunx is offline   Reply With Quote
Old 1st Apr 2012, 08:10   #22
dancingbear84
error 404
dancingbear84's Avatar
dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.
I do have some old sky boxes kicking around and an old p4 in the loft, I've been toying with combining for a while, trouble is that the heat sink is a massive dell thing.
__________________
It doesn't matter if you make a mistake, it only matters if you don't learn from it
dancingbear84 is offline   Reply With Quote
Old 1st Apr 2012, 10:01   #23
GeorgeStorm
Aggressive PC Builder
GeorgeStorm's Avatar
GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.
This is awesome, what kinda stuff can it cope with?
I've just inherited an older sempron pc, and was wondering how it would cope with HTPC duties
__________________
"Anyone who just plays games for fun is a n3rd" - Jörge "I should be in prison for what I'm thinking right now" - Will
My Parvum Systems build log - My flickr - My blog it'sfilmnotmovie - hwbot
I identify as mayonnaise-kin, think of it as white without the privilege.
GeorgeStorm is offline   Reply With Quote
Old 3rd Apr 2012, 13:06   #24
Vo0Ds
Fake potato
Vo0Ds's Avatar
Vo0Ds has yet to learn the way of the DremelVo0Ds has yet to learn the way of the Dremel
It's been able to handle anything I've played on it, plays HD stuff happily and zooms through menus and large-ish libraries.
If you're worried about your hardware running XBMCBuntu, OpenElec is an even lighter distro of XBMC.
UPDATE ON PROGRESS
...Nothing much to be honest, but I've updated the software to the final 11.0 Eden version. Good few bugs squashed and feels more stable.
The machine has just been happily working away, no bad smells or melted coloured plastic (touch wood)
__________________
Masara: i5 2500@4.2Ghz | Asus P8P67LE | EVGA GTX460SC | 8Gb Corsair 1600 | 1TB WD-C BLACK | Fractal R3 | LG 23" IPS
LEGO Ghetto HTPC: Broken-ass laptop pulled apart, now a HTPC... made of LEGO. UNDER CONSTRUCTION
Vo0Ds is offline   Reply With Quote
Old 3rd Apr 2012, 13:14   #25
GeorgeStorm
1080p no problamo?
And whats the network like? (if you're streaming from a file server or whatever?)
__________________
Old 3rd Apr 2012, 13:26   #26
Mankz
5318008
Mankz's Avatar
Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.
This is awesomesauce.
Mankz is offline   Reply With Quote
Old 3rd Apr 2012, 13:36   #27
Vo0Ds
Fake potato
Vo0Ds's Avatar
Yep will play 1080p, though admittedly I mostly watch TV episodes which are 720p & lower. I'm using homeplugs (can't remember their capacity) to stream media from my gaming PC to the HTPC. (it still blows my mind to stream Game of Thrones through my electrical socket )
I'd love to get a low power file server / torrent box sorted; leaving stuff to download overnight on my gaming rig causes expensive electricity bills. Setting this up on the HTPC would be a bit better, but don't know by how much. Maybe when my RaspberryPi arrives I'll experiment with downloading / streaming with an external USB HDD
I may need an extension to the Lego case to house it, hmm...
__________________
Old 3rd Apr 2012, 14:06   #28
GeorgeStorm
Fair enough, I was wondering because I watched Avatar the other night, and my p8600 in the laptop we were using was at 60% cpu usage, and we were getting stuttering every now and again, possible due to the network, although I would have thought 100mbps would have been fine for that :/ (was a 22gbish rip)
Edit:
Had an average bitrate of 16MBit, so maybe that's why it wasn't ok, considering 1000mbps is around 12mbit :P
__________________
Reply
Tags
ghetto, htpc, laptop
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
