Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 3rd Mar 2012, 16:12   #1
Mandragorin
Minimodder
Mandragorin has yet to learn the way of the Dremel
i7 920 Asus P6t Deluxe V2
I upgraded my ram from the Corsair Dominator 6GB CM3X2G1600C8D to Corsair Dominator GT 24GB CMT12GX3M3A2000C9 and my previous overclock has failed. I've reset my BIOS setting to its default state.
I had previously followed the overclocking guide on bit-tech and had a stable 4ghz overclock.
Does anyone have any ideas what BIOS settings I should try changing?
I've been at this for the last 6hours!!
__________________
PC Specs - CPU: Intel Socket 1366, i7-920 @ 2.67GHz | Motherboard: Asus P6T Deluxe V2 (BIOS version 1108) | CPU Cooler: Xigmatek Thors Hammer | Memory: Corsair Dominator GT 24GB CMT12GX3M3A2000C9 | PSU: Enermax 850W | Graphics: Sapphire Radeon R9 280x Vapor-X 1GB | OS Win 10 (64bit) | Monitor: Dell U2711 (Rev A07)
Mandragorin is offline   Reply With Quote
Old 3rd Mar 2012, 16:14   #2
noizdaemon666
I'm Od, Therefore I Pwn
noizdaemon666's Avatar
noizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyan
Up your VTT I think. Populating all your DIMM slots can affect overclocking stability.
__________________
I make up-to-date Windows ISOs for the making of faster installs
noizdaemon666 is offline   Reply With Quote
Old 3rd Mar 2012, 18:25   #3
thetrashcanman
Angel headed hipsters
thetrashcanman's Avatar
thetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpit
+1 to this, filling all the slots on X58 always made overclocking a pain in the ass
__________________
is rebuilding his rig.... Asus Maximus IV Extreme/ i5 2500k @4.4Ghz/ EVGA 780 Classified/ 2 x Corsair 960Gb Neutron XT SSD / Mac Pro Tower
thetrashcanman is offline   Reply With Quote
Old 3rd Mar 2012, 19:56   #4
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
I have the same board and CPU.
Tell me your settings, and I'll try to help.
Although, it should be fairly easy to run 20 multi at 200BLCK, with the ram at 1604MHz and 1.64vdimm.
Depending on your CPU, 1.3v should be enough Vcore for 4GHz, with a little bump on QPI/Dram voltage to help the BCLK. IOH might need a liitle extra volts, although 200BLCK is hardly extreme.
Enable loadline calibration, and switch off Spread Spectrum.
Thinking about it - I'm not sure how much of an impact filling all six memory slots will have on overclocking - however, as I'll be fitting 6x2GB 2133 sticks next week I'm sure I'll find out. **Just read the above comments - looks like it's a significant factor**
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170|32GB|256GB M.2|500GB SSDs|8TB NAS|980 Ti|3007WFP-HC|Parvum S2.0
David is online now   Reply With Quote
Old 4th Mar 2012, 09:34   #5
Mandragorin
Minimodder
Thanks for the help guys. I've managed to o/c to 4ghz but have had to underclock the ram.
Would be grateful for any help on getting the Ram settings up and whether you think any of my voltages are bit high.
NB. Not sure how stable these settings are as I still need to run Prime95
Here are my settings:
Ai Overclock Tuner Manual
CPU ratio 20
Intel Speedstep Off
BCLCK Frequency 200
PCIE Frequency 100
DRAM Frequency 1603
UCLCK Frequency 3208
QPI Link Data Auto
CPU Voltage 1.3
CPU PLL Voltage 1.96
QPI/Dram Core Volt 1.35
IOH Voltage Auto
IOH PCIE Voltage Auto
ICH Voltage Auto
ICH PCIE Voltage Auto
DRAM Bus Voltage 1.66
All other settings Auto
Load Line On
CPU Differential Amp 800Mv
CPU Clock Skew Auto
CPU spread spectrum Off
IOH clock skew Auto
PCIE spread spectrum Auto
BIOS: Advance (CPU Configuration)
CPU ratio 20
C1E Support Off
Hardware Prefetcher On
Adjacent Cache Line On
MPS & ACPI MADT Modern
Intel Virtualisation Tech On
CPU TM Function On
Execute Disable Bit On
Intel HT Tech On
Active Processor Cores All
A20M Off
Intel Speed Step Off
Intel C-State Tech Off
__________________
Old 4th Mar 2012, 09:39   #6
LennyRhys
Fan Fan
LennyRhys's Avatar
LennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming Saiyan
191x21 is a much better approach to 4GHz because, for some unknown reason, the even multipliers are usually unstable or (at best) extremely hard to get stable. I had my 920 for a long time and never ran it with an even multi... ever; it was always either 191x21 or 200x21.
BCLK holes are another potential setback, and they are more evident with my 990X than they have ever been with any other CPU. My PC won't even boot with 152 BCLK... no matter what I do, it just doesn't happen.
__________________
i7 5820K | MSI X99A Gaming 7 | 32GB Ballistix Sport | EVGA GTX980Ti SC | Corsair RM550 | Dell U3014
LennyRhys is offline   Reply With Quote
Old 4th Mar 2012, 10:04   #7
David
RIP Tel
David's Avatar
Also, take your IOH voltage out of Auto and try it at 1.20V.
Probably asking the obvious here but, have you ruled out the possibility of a bad RAM module? One out of six is far more likely than one out of three.
__________________
Old 4th Mar 2012, 10:28   #8
Big Elf
“not another f—-ing elf”
Big Elf's Avatar
Big Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming Saiyan
These are just minor points but might make a difference
CPU PLL Voltage 1.96 - Seems quite high
CPU Differential Amp 800Mv - Change to Normal
PCIE spread spectrum Auto - Change to Off
The main thing to experiment with is the QPI/Dram Core Volt. The IMC might not be a good one on that chip so you may need to go even higher for 1600MHz and a lot higher (up to 1.6v) for 2000MHz. As an example my 920 needed 1.38v for 1600MHz and 1.58v for 2000MHz at an overclock of 4.2GHz.
__________________
Case Labs TH10│Asus Rampage III Extreme│Core i7 990X│24GB Corsair Dominator GT│GTX Titan SLI│Samsung 850 EVO 256GB│Crucial M4│2TB Samsung Momentus x 2│SeaSonic P1000W│EK Supremacy│EK FC-RE3│EK-FC Titan SE x 2│EK-RAM Dominator│Black Ice SR-1 480 x 3│Swiftech 35X2
Big Elf is offline   Reply With Quote
Old 4th Mar 2012, 10:57   #9
David
RIP Tel
David's Avatar
Virtualisation can hamper an overclock too - not normally 4GHz, but I don't know the impact of six DIMMs on that. Try turning it off, epsecially if you don't need it.
__________________
Old 4th Mar 2012, 18:09   #10
Mandragorin
Minimodder
Thanks for all the suggestions. Latest update on the o/c is that I've got it to 3.6ghz and the Dram frequency running at 1904Mhz.
Changes to the above settings I made are:
Ai Overclock Tuner - XMP
CPU ratio - 19
Bclck frequency - 190
Dram frequency - 1904
Uclck frequency - 3808
CPU pll voltage - 1.9 (is this still a bit high?)
Qpi/Dram core voltage - 1.45
Ioh voltage - 1.2
CPU differential amp - Auto
Pcie spread spectrum - Off
Still need to run prime95 though.
I did run memtest86+ and win 7 memory diagnostic, both returned no error reports
__________________
Old 4th Mar 2012, 18:47   #11
Big Elf
Big Elf's Avatar
A reasonable start. One thing I'd forgotten about is that the mobo might default to aggressive memory timings when you reset the BIOS so make sure you set those manually if you haven't already done so. I'd drop the CPU PLL to default (1.80v?) and then only increase it if the overclock is unstable.
__________________
Old 4th Mar 2012, 19:11   #12
Mandragorin
Minimodder
I'm still quite new to overclocking! How do I manually set the memory timings?
__________________
Old 4th Mar 2012, 19:22   #13
Big Elf
Big Elf's Avatar
In 'AI Tweaker' go to 'DRAM Timing Mode' and then set the first 4 timings manually. The timings are, I think, 9-11-9-27 but check the label as it will be on there and could be 9-10-9-27. Changing the 'DRAM Timing Mode' to 2N might also aid stability.
__________________
Old 4th Mar 2012, 19:39   #14
Mandragorin
Minimodder
Ok, thanks. I'll give that a go.
I've got my o/c running at 4ghz with the following changes:
CPU ratio - 21
CPU PLL Voltage - 1.8
Dram bus Voltage - 1.64
I had reduced the QPI/Dram core voltage to 1.4 but that failed so back up to 1.45. I'll manually set the memory timings and then run prime95 overnight. If it's still going in the morning I'll leave it running so that I get a good 18hrs of testing.
__________________
Old 4th Mar 2012, 19:46   #15
Big Elf
Big Elf's Avatar
If the timing were set lower than what they're supposed to be you could try reducing the QPI voltage but it may be that your IMC (Integrated Memory Controller) on the CPU isn't brilliant especially with the 6 sticks of RAM. For the minuscule loss of performance I'd suggest dropping the RAM a notch to around 1523MHz.
I've never had problems on the later version of that mobo with setting a BCLK of 200 and a Multi of 20 to get 4GHz and doing that would mean you could run the RAM at 1600MHz.
__________________
Old 5th Mar 2012, 14:10   #16
towelie
How do I Internet!!
towelie's Avatar
towelie has yet to learn the way of the Dremeltowelie has yet to learn the way of the Dremel
I have a P6T SE and a I7 930.
Would be good to see your settings/pics/temps as i'm thinking of clocking mine to 4gh or close as possible.always been unsure what settings to apply then i think ahhh il leave it!!
__________________
CPU:Intel I7 930(Bloomfield) @2.80GHZ CPU Cooler:Under water
MOBO:Asus P6t SE Graphics Card: Palit 980GTX 4GB EVGA OC
RAM:12GB Corsair XMS3 1600mhz 9-9-9-24 PSU:Corsair HX 750W
Hard Drives128GB SSD Corsair Force GS/1TB WD Green 7200RPM
Case:NZXT 810 Switch Black
towelie is offline   Reply With Quote
Old 11th Mar 2012, 10:46   #17
Mandragorin
Minimodder
Ok guys, after a lot of tweeking here are my stable starting overclock settings (6 March column) and the settings I currently have.
BIOS - AI Tweeker 06-Mar 10-Mar
.................................@4ghz...@3.99
Ai Overclock Tuner....... XMP...... XMP
CPU ratio......................20.........21
Intel Speedstep ...........Off
BCLCK Frequency..........200......190
PCIE Frequency.............100
DRAM Frequency............1603....1904
UCLCK Frequency..........3208.....3809
QPI Link Data................Auto
CPU Voltage..................1.3........1.35
CPU PLL Voltage............1.8........1.86
QPI/Dram Core Volt.......1.35......1.5
IOH Voltage...................1.2........1.26
IOH PCIE Voltage..........Auto
ICH Voltage...................Auto
ICH PCIE Voltage..........Auto
DRAM Bus Voltage.........1.64......1.66
All other settings...........Auto
Load Line...................On
CPU Differential Amp...Auto
CPU Clock Skew..........Auto
CPU spread spectrum...Off
IOH clock skew...........Auto
PCIE spread spectrum..Off
BIOS - Advanced (CPU Configuration)
C1E Support.................Off
Hardware Prefetcher....On
Adjacent Cache Line P..On
MPS & ACPI MADT.........Modern
Intel Virtualisation Tech.On
CPU TM Function...........On
Execute Disable Bit.......On
Intel HT Tech................On
Active Processor Cores.All
A20M............................Off
Intel Speed Step...........Off
Intel C-State Tech.........Off
At the moment, yesterdays settings are still holding but I may try to reduce the cpu and cpu pll voltages a fraction.
At 1.5v the qpi/Dram voltage is a little higher than I would like (just because this is my first o/c and seeing the figure in red, in the bios, is a bit scarey!)
I'm quite happy with an o/c to 3.99ghz running with the ram at 1904mhz. Let me know what you guys think and if you have any advice on my settings.
__________________
Old 11th Mar 2012, 11:21   #18
Big Elf
Big Elf's Avatar
Have you changed the RAM timings to match their spec? You're going to have a high QPI voltage if you run your RAM close to their rated speed. For the slight loss of bandwidth running at a BCLK of 200 with 1600MHz means a lower QPI voltage and a bit less heat. Also you'd probably be able to reduce the DRAM voltage a bit.
As has been mentioned before unless you use virtualisation disabling Intel Virtualisation Tech could help stability.
I'd run it with Speedstep on. Unless you're exploring the higher reaches of overclocking it's unlikely to affect stability.
__________________
Old 11th Mar 2012, 11:30   #19
Mandragorin
Minimodder
The dram timings are at 9-11-9-27 with timing mode at 2N. I'll switch off Virtualisation as suggested.
So if I overclock with 21 x 200 and drop the ram to 1603mhz should I get better performance than with 21x190 with ram at 1904mhz?
__________________
Old 11th Mar 2012, 12:05   #20
Big Elf
Big Elf's Avatar
It'll only be noticeable in benchmarks.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
