Reply
Thread Tools View Mode
Old 10th Mar 2012, 04:26   #21
KayinBlack
I Endure
KayinBlack's Avatar
KayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for president
Time to shift a bit of metal...
Doesn't look like much, but that lip turns into a hanging corner, stopping a rad from going there.
Repeated on the other side...
Removing the spring steel drive holders... I have a right angle drill that will be removing the interior welds.
And the last one. It doesn't look like much, but honestly every one of these cuts took a long time to plan out, to make sure I didn't remove something else important and didn't compromise case integrity. I'm proceeding slowly, to make sure each thing I do is the proper thing to do. It's not always a simple thing.
KayinBlack is offline   Reply With Quote
Old 10th Mar 2012, 04:45   #22
KayinBlack
I Endure
KayinBlack's Avatar
This is a grille in development for the top rad setup. White Light Laser (like them here on FaceBook) is sponsoring all of my acrylic and cutting for this build.
I've also got as sponsors Ice Dragon Cooling and the local movie studio/publication house JessAndy Entertainment, who I often help with props, editing machines, etc. There's some really good fiction available through them, and I should be publishing some pieces there soon as well.
I have other stuff in talks, including a local option for custom decals, but for the moment I've still got a great list of sponsors.
Just thought news like that deserved its own post.
Old 10th Mar 2012, 09:12   #23
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
That looks pretty damn nice!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 12th Mar 2012, 01:57   #24
KayinBlack
I Endure
KayinBlack's Avatar
Sleeving proceeds apace...
I'm doing away with the Kensington lock slot to make one uninterrupted piece. The hexes are going away too-there's simply too few of them.
Metal-filled epoxy in the hole. There's excess to allow me to file it to shape.
Removing the lock slot's hardware on the case itself...
Rivets drilled out...
And lock bar removed.
Now back to the fully hardened filler...
The extra is cut off and the top scored up for filler...
Yeah. Filler.
A little thick but workable. Some time later...
And with the addition of these...
First coat done. Most of the hexes filled in just fine. High build primer and spot filler ought to do the rest. And gouges will be dotted with filler before I shoot primer for this. But all in all, a success.
Weather had to turn bad on me today. Tomorrow is a doctor day for the little one, so progress should pick back up on Tuesday.
Old 12th Mar 2012, 02:03   #25
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.
Family first, as always. Mondays suck anyways - even if one doesn't work.
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 13th Mar 2012, 03:26   #26
Furball Zen
Shut up and Mod
Furball Zen's Avatar
Furball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run Crysis
__________________
Life. Liberty. The pursuit of those who oppose it.
Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide
@furballzen
Furball Zen is offline   Reply With Quote
Old 13th Mar 2012, 03:58   #27
KayinBlack
I Endure
KayinBlack's Avatar
I take it you're a fan?
Pics tomorrow, but I finally finished the PSU. Self-welding tape will be left overnight to bond. Tomorrow is more bondo and such.
Old 15th Mar 2012, 01:12   #28
KayinBlack
I Endure
KayinBlack's Avatar
Another day, another coat of Bondo...
And sanded... This is about all I can do without a guide coat.
Instead, I spent my day doing this...
The only problem is, I have no drives to attach to it.
Old 15th Mar 2012, 01:56   #29
Furball Zen
Shut up and Mod
^^^My level of crazy
__________________
@furballzen
Old 15th Mar 2012, 02:20   #30
BearC
Profound Modification
BearC's Avatar
BearC has yet to learn the way of the Dremel
Looking great, real mod going on, will follow
__________________
3TB WIN7 64, XFX GTX 280, 2X 4GB 800MHz, 4 Core AMD 3.4 GHz
My gamer blog
BearC is offline   Reply With Quote
Old 15th Mar 2012, 23:47   #31
KayinBlack
I Endure
KayinBlack's Avatar
What's so special about this tray?
Polished zinc?
Yeah, polished zinc. I have my work cut out for me getting the rest of the skeleton to match, huh...
Old 16th Mar 2012, 03:31   #32
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.
Will you have to have the rest of the skeleton plated? Or will just polishing the surface suffice? (I can't see the rest of the frame's construction very clearly - from the mottling it looks like galvanised mild steel? If it is, can that zinc plating be polished?)
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX750, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 16th Mar 2012, 03:37   #33
KayinBlack
I Endure
KayinBlack's Avatar
Yes, the zinc can be polished. I'll get some outside pics tomorrow to show the contrast better.
Lots of work, but it's better than the alternative, which was paying for powdercoating. I don't know how people do it-my quote was well over $200 for just a case frame.
Old 16th Mar 2012, 08:34   #34
KidMod-Southpaw
This is just insanity! Great work!
__________________
Old 17th Mar 2012, 20:53   #35
KayinBlack
I Endure
KayinBlack's Avatar
I'd like to announce a new sponsor!
120mm Overkill Billet Fan Grills
3M Di-Noc Carbon Fiber Sheet
Thanks to MNPCtech for the Overkill billet fan grille and the Di-Noc Carbon Fiber vinyl they're sponsoring!
Old 18th Mar 2012, 22:05   #36
Diegojavbau
Minimodder
Diegojavbau's Avatar
Diegojavbau has yet to learn the way of the Dremel
Knigth Rider !!!! Memory's from my childhood come back to me , Great theme !!! , here in Argentina was called "El Auto Fantastico" (the fantastic car)
Keep it Up !!!!!
PD :congratulation for the sponsorship !!!
Diegojavbau is offline   Reply With Quote
Old 20th Mar 2012, 04:37   #37
KayinBlack
I Endure
KayinBlack's Avatar
Some more work today...
This is the polished vs bare in sunlight. Much more evident.
Another shot. The demarcation is evident.
Can you tell what's missing?
From this angle maybe? The floppy bay at the top has been completely removed to help with rad and SFX clearance.
Motherboard tray pulled, getting ready for polishing...
And some artsy pics of wire clips, because I need to know where they go back after I dye them black.
Enjoy, I'm off to doctors with the little one today(tomorrow, whatever) but I've got more polishing and such ahead of me.
Old 20th Mar 2012, 05:06   #38
jhanlon303
jhanlon303's Avatar
OH, polishing. I tried that once. didn't fare well for me. too many knooks and crannies.
Take the sprout to DR and know that we are here as always. May not comment but always watch
john
__________________
Old 23rd Mar 2012, 20:11   #39
KayinBlack
I Endure
KayinBlack's Avatar
Getting some real modding done...
This is the PCI fan mount, that's situated to blow over the southbridge, video and RAID card.
Attacked with Dremel...
MNPCtech billet grille in place... This will get cleaned up and repainted when I start painting, and when my airflow straightener gets in, it'll go in this.
There it is in place. The cover that goes over it isn't in place yet, I'm taking a look at what I can do differently.
And, an update as to what I'm working on now...
As you can see, someone tried to get into this package before it got to me.
What is it? Well, it's 1000 denier Kevlar-5.6 oz. And it's a fairly large amount-36"x70".
Along with carbon fiber cloth.
KITT was supposed to be waterproof, fire proof, bulletproof and explosionproof. Let's see just how far we can get with today's tech.
Old 23rd Mar 2012, 21:33   #40
KayinBlack
I Endure
KayinBlack's Avatar
This wasn't expected to show up at all, but it did. Yay me!
What's in the box?
Cat! No, she's just resting after tearing through the house. Knocking over floor tiles, stuff like that. You know, cat things.
Hexagonal armor tiles. Almost every piece is in place, and one piece is something that has to be made, not acquired.
I'm reviewing the directions for my resin to decide if I can do it inside or if I have to be outdoors. I'm also looking at a few other ideas to make sure that when I put this together it's gonna stay together and work as intended. No sense in rushing, this stuff while not expensive is honestly just too nice to go and mess up.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
