Case Mod - In Progress [project] Apple Cube - final photos !!
Discussion in 'Project Logs' started by thegyufi, 5 Mar 2012.
  1. thegyufi
    thegyufi What's a Dremel?
    21 Mar 2011
    Hello bit-tech :eek:
    I post here for the first time one of my mod, called :
    Final Gallery :
    First, if you have the feelings that's it's a 4 years old child who speak it's normal because i'm french and my english is very approximate :wallbash:
    Also I want to specialy thanks my sponsors :thumb:
    - Prolimatech who gave me their support with their Samuel 17 CPU cooler :)
    please visit : www.prolimatech.com
    - Linitx also join my project by sending me a great picoPSU with an AC/DC adapter.
    Thansk a lot Chris for all your advice ! (If you want to create your own tiny computer or your car pc, this is THE adress :rock:)
    please visit : www.linitx.com
    - Kingston also accepted to join my project by sending me one of their high performance SSD : the HyperX 120Gb and one ram kit 2x2Gb HyperX Genesis
    www.kingston.com
    This project is based on the Apple Cube, some photos of mine I won on eBay :clap:
    As you can see, the cube is scratched, so the external design gonna change a lot to hide these scratches
    That's all, next post i'll show you the disassembly of the cube
  2. thegyufi
    21 Mar 2011
    The disassembly :
    What is it that all these components ?! :confused:
    Ok now I have little more space :D
  3. thegyufi
    21 Mar 2011
    The MB tray :
    the bottom of the case
    I create a paper MB of mine to make all the modifications I need.
    And I'll use the bottom of my FD Array case to create the MB tray
    Ok so now let do some :dremel: :rock:
    some cutting
    We fix the paper MB
    set in the cube
    drilling
    and checking :)
  4. thegyufi
    21 Mar 2011
    some work with the IO panel
    The position on the bottom of the cube
    cutting
  5. thegyufi
    21 Mar 2011
    I continue with the hdd support, on the back of the MB tray
    the cut lines
    cutting
    bending
    the HDD ready (@1080p haha ... :duh:)
    the mb (the real !) fix on their tray and here ... :wallbash:
    the position of the IO Panel is'nt aligned with the I/O of the MB ...
    I can't use a "normal" IO panel, because the "normal" positon is always a little more outside than the mb, i think i'm gonna create my own panel :worried:
    and the HDD on the back
    one overview
    That's it !
  6. Lance
    Lance Ender of discussions.
    6 May 2010
    Oh that looks really cool.
    Are you planning on sticking with the stock cooler just minus fan or are you heading down the 3rd party route?
  7. thegyufi
    21 Mar 2011
    I try with google traduction to understand your message but I think google isn't enough geek :D
    I'm not sure it will answer your question but i'll install the Samuel 17 fanless on my i5-760 @i3-540. If i can i'll put a slim 120mm fan, but I must be careful with the future position of the slim slot-in.
    Good answer ? :worried:
  8. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Me Gusta!
  9. Knighthammer
    Knighthammer What's a Dremel?
    18 Feb 2011
    Awesome job - I'm liking this a lot. I've got a Apple cube that I've wanted to mod for quite a while, so I'm watching this one with interest for sure!!
  10. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Looking very good
  11. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    that HDD mount has got my attention
  12. Cheapskate
    13 May 2007
    :thumb: <-- Need's no translation.:D
  13. jhanlon303
    7 Sep 2006
  14. NoobNeb
    NoobNeb Enthusiastic Lurker
    14 Nov 2011
    Really nice work man :clap: Are you going to use a 7750 in this?? seems ideal for it
  15. Lance
    6 May 2010
    Perfect answer.
    Good luck. I have a slim 120mm fan on my HTPC and it works very well.
  16. Fredo428
    Fredo428 What's a Dremel?
    19 Sep 2011
    Yeahh ! nice !
  17. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
  18. jhanlon303
    7 Sep 2006
    My cube did not survive the move from Colorado to Iowa.
    I watch.
    the john
  19. thegyufi
    21 Mar 2011
    Hello everybody,
    first, thanks a lot for your posts, I realy appreciate !:D
    @NoobNeb: about the 7750, I think this card is too powerfull for a htpc (I must be carreful with the consumptuion) and if I can I prefer a single slot card for the space. I plan to use a GT430 or GT520, but if you have any other idea for the card :idea: please let me know !!
    @John: sorry for your lost, I wouldn't be in your shoes :)
  20. avolla
    avolla Mini Water Modder
    26 May 2010
    Love what you've done with this so far. Keep up the good work. can't wait to see this progress.
