Reply
Thread Tools View Mode
Old 21st Jun 2012, 20:55   #81
mybadomen
Multimodder
mybadomen's Avatar
mybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremel
"UPDATE"
Well hiya guys, I have an update but its not huge. I am now back to working on ME3 as well as another build but making ME3 the priority right now.
Here is the point the build was at before today as you can see i have been working on her a bit:
Here is some work i did Today.
Mounted the 2 Plextor M3 Pro Series SSD Drives.
Wrapped the Modded top front Panel with more 3M Di noc Carbon Fiber
And also Painted another NZXT FZ-140 Fan Red and Modded the lower front panel and cut out some Mesh that will be painted to match the mesh on top and inside. (Front is still incomplete)
Also did some boring wiring but didn't photo it as it was nothing special.
And thanks to My Sponsors involved in this Update:
Plextor for their PX-M3 Pro Series SSD Drives that are smoking fast Clean or Dirty !
More Info Here : http://www.plextoramericas.com/index...-m3-pro-series
NZXT For everything they Sponsored for this build:
More Products from NZXT Here: http://www.nzxt.com/new/product_all.php
ATXPCREPAIR & MNPCTECH For huge help getting all the 3M Di-noc Carbon fiber needed for this build which is a total of 2 feet x 10 feet and is far from cheap stuff!
More Info on ATXPCREPAIR Here:
http://atxpctech.com/
For all MNPCTECH's great products, guides,blobs look here : http://www.mnpctech.com/casemodstore.html
Sorry for the long wait but hope you guys like where its heading. Looks like its almost done but its all the tiny details that drive me crazy, But you should see allot more updates from here on out as i am all set up to work here now.
Take care and really hope you guys like it:
More to come soon so keep watching:
MybadOmen
mybadomen is offline   Reply With Quote
Old 21st Jun 2012, 20:57   #82
mybadomen
Multimodder
mybadomen's Avatar
More to come Soon !
Keep Watching.And thank you all for your Support through these builds.
MybadOmen
Old 22nd Jun 2012, 01:21   #83
B.o.B
Minimodder
B.o.B has yet to learn the way of the Dremel
^.^ I've been waiting for this day. Welcome back and thank you for continuing with this beauty!
Your build has been a great source of inspiration and instruction for me and I've made a few tweaks to my own ME3 build as a result. While I'm currently working on another project, this update has me itching to get back to mine
B.o.B is offline   Reply With Quote
Old 26th Jun 2012, 13:16   #84
mybadomen
Multimodder
mybadomen's Avatar
Thanks Mate Glad you like it. Also i know the feeling as i am trying to Jugle 3 Mods myself at the moment and may be adding a fourth.
But highly appreciate the compliment.
MybadOmen
Old 26th Jun 2012, 13:16   #85
mybadomen
Multimodder
mybadomen's Avatar
UPDATE!
Just another small update of getting a little more work done to the front of the Case. Looks a bit funny right now till the actual Theme is applied and the Window etc is Modded.
Ok Lets get started :
Here is the lower front Panel that i started Modding in the last update:
Now to paint the Mesh i made earlier to match the top. First step because it is bare metal is to Prime it with an etching Primer:
Next i paint the whole piece in Black Krylon "Fusion" Satin Black. I have completely switched to using Krylon when using rattle can pants now. The stuff is really amazing on Metal or Plastic and also has an Adhesion Promoter already in it.
Next i mark it and tape of a 2 inch space that will be Painted white as part of the red and white stripe. (Usually this stripe would go on the side but i wanted to be original as this is my Version of Mass Effect 3 Build so i wanted it Centered) Also again using White Krylon Fusion.
Totally forgot to take a Photo of the white panted and taping off the Red. but basically all i did was let the white dry and taped off a 1 inch stripe in the center to pain red and here is what it looks like drying with the tape off.
Now i move on to the Heat gun and 3M Di-noc Carbon Fiber to wrap the lower panel that the Mesh will be sitting in:
And after a little heating and carefully getting all the edges its wrapped:
and a Shot of it back on the ME3 build:
More to Come Keep Watching
Take Care,
MybadOmen
Old 27th Jun 2012, 06:21   #86
Sn00k3r
Minimodder
Sn00k3r's Avatar
Sn00k3r has yet to learn the way of the Dremel
i really like this Mod
Love the Detail-Work and the tidy setup..! Keep on going mate!
Sn00k3r is offline   Reply With Quote
Old 27th Jun 2012, 07:08   #87
SilveR_172
Supermodder
SilveR_172 has yet to learn the way of the DremelSilveR_172 has yet to learn the way of the Dremel
Looks brilliant Omen ! It looks so clean inside and although i said about the Headunit from antec it actually flows well with the Res and fan controller !
well done
SilveR_172 is offline   Reply With Quote
Old 27th Jun 2012, 20:31   #88
mybadomen
Multimodder
mybadomen's Avatar
well done
Thanks guys for all the compliments and advice and also support
Old 28th Jun 2012, 16:26   #89
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Fantastic modding mybadomen, man I really should check the case mods out more often.
stars & rep
Waynio is offline   Reply With Quote
Old 29th Jun 2012, 04:06   #90
mybadomen
Multimodder
mybadomen's Avatar
UPDATE
First off don't miss the Great article Charley Bwoy wrote about Me and the Mass Effect Build. He did an incredible job.
Article is here: http://modderdiaries.blogspot.ca/201...t-3-build.html
Again a small update it would seem but took many hours for this small update.
Took everything apart on Top and the Front of the Case to Carbon Fiber Di-noc the edges as the whole case will be Carbon Fiber and Flat black like the N7 armor in ME3
Will just Post some Photos without explaining , Basically used a Heatgun and Dinoc:
Tops Done , Now for the Front:
Top and Front Di noc done
Not sure what happened but the before Photos of the SSD harness didn't come out so unfortunately all i have is after Photos and its also dark out for the final Photos so bad lighting at the worse time but you guys are aware of what the build looks like with good light:
Custom wire harness for the 2 Plextor 128 gig M3 Pro Series SSD Drives
Build is getting extremely Close to done so stay keep watching and pray the rain stays away for a bit so i can finish some wiring.
Random Photo's (at night with bad lighting) but figured id share them anyway:
Lol Sorry for the last 2 Photos. I only have an iPhone to take Photos for my build logs and cant afford a real camera and parts to build so i do my best with what i have.
Keep watching, as now its time to make this thing look beautiful and finish it off.
Take Care and thank you for looking,
MybadOmen
Old 29th Jun 2012, 16:02   #91
krussellusaf
Modder
krussellusaf has yet to learn the way of the Dremel
That racing stripe looks great. I love how you incorporated that into the SATA cables as well.
krussellusaf is offline   Reply With Quote
Old 4th Jul 2012, 02:50   #92
mybadomen
Multimodder
mybadomen's Avatar
UPDATE !
And another update already that fast. I told you they would be coming pretty steady now till completion and i am not going to cut corners to meet any deadlines. This build will be done and hopefully Beautiful when its completed.
That being Said lets get yo the Update:
This Update is me Modding the window .I decided to just leave leave 1 1/2 " of metal completly around the window so people can see all the work inside and i curved the edges. Lol wait till you see what i used for a tool to curve them.
First a couple Photo's with the window off :
And now to Start Modding the NZXT Switch 810 Window:
Marking out where my cuts are going to be:
Marking out the curved edges with my High Tech tools .
Jig saw with Guide i will be using to cut out the window. (The Guide will help make nice straight lines until i get to the rounded edges. Its all skills from there )
Just checking to see if it looks right . It does so we can move on. OH YA normally i would tape off around where i was cutting but this is getting Di noc wrap so i didn't bother. My saw does have plastic feet though so i used a scotchbrite after to smooth it out after.
The Scraps
These Photos are of ,me sanding the scratches and edges smooth and also a shot of some of the tools i used to get a really nice edge:
Mnpctech . Lol seems like this name comes up allot in my Threads . Well this time is because i am using the Mnpctech U-Channel Molding which is one of the best i have ever used or seen. The stuff is super thin and looks incredible. In my eye's at least.
Well this Molding was also sponsored by Bill and Mnpctech.com so as always i will give a link where you can get some yourself.
Mnpctech U-Channel Molding here:
http://www.mnpctech.com/UChannel.html
Ok now everything is all nice and even and smoothed out i finally move on to the Di-noc and U-Channel molding.
Will get better Photos of this tomorrow because my iPhone cant take pictures at night at all they come out terrible. Lol not to mention i ran it over yesterday so not only did i need a camera badly for my logs .I now also need to replace my iPhone 4 Glass which i do all the time for money so that's not an issue. Lol yeah but imagine, I ran over my own Phone with a GMC Jimmy and its perfect besides the glass.Thank god it happened in the grass i bet cement would be another story.
Really sorry for this last Photo as you cant tell how nice it came out but i promise you will see soon enough.
Take Care and Keep Watching . This Build is almost over and then you guys can watch my next build that's already started ,Just not posted yet.
More Updates Soon
MybadOmen
As Promised i am back to add some better Photo's. Well a little better at least.
Hopefully that gives a little better idea of what it is starting to look like but still i cant get the colors as bright as they really are in real life. The chrome sparkles everywhere and goes perfect with the Carbon fiber and red and white. Best i can do for now but i did promise i would be back with some better Photos .
More Updates soon so keep watching
MybadOmen
Old 4th Jul 2012, 17:40   #93
mybadomen
Multimodder
mybadomen's Avatar
Added Better Photo's to last Update!
Old 4th Jul 2012, 20:29   #94
jamsand
Hypermodder
jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!
that rig is a thing of beauty!
jamsand is offline   Reply With Quote
Old 4th Jul 2012, 21:42   #95
jotinha17
What's a Dremel?
jotinha17 has yet to learn the way of the Dremel
no comments, this excellent ...
jotinha17 is offline   Reply With Quote
Old 5th Jul 2012, 06:20   #96
Sn00k3r
Minimodder
Sn00k3r's Avatar
beautiful Work, love it..!
Old 5th Jul 2012, 12:36   #97
Pinwmpires
Minimodder
Pinwmpires's Avatar
Pinwmpires has yet to learn the way of the Dremel
Very nice build.. Good job mybadomen keep it up!
Pinwmpires is offline   Reply With Quote
Old 6th Jul 2012, 11:53   #98
Waynio
Waynio's Avatar
Well deserved vote coming your way.
This is excellent.
Old 7th Jul 2012, 14:05   #99
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Very sexy build mybadomen! loving that you haven't gone overboard with the red, just enough to make it pop
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 7th Jul 2012, 18:11   #100
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
Squigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the Dremel
This has to be one of the tidiest builds I have seen in a while, you can really see the effort that has gone in!! love your work mate and congrats on the MOTM nomination!!!
__________________
Ω Omega Desk Ω
Squigly is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
