#181 |
< Your add here >
#182 |
< Your add here >
Triple-post! (what do I win?!)
Update Ok I get it you are bored with paint updates, so how about this: I've almost finished the right sidepanel. Tonight I've installed the rads, the touchscreen and the fancontroller: The print with the on/off switch for the screen is on the left side of the bottom frame: Domenut as temporary button (any ideas what to replace it with?) Better?!
#183 |
Multimodder
Not bored with paint updates at all, fantastic finish you've managed to get on this.
#184 |
Supermodder
You paint is just great!
Before painting white are you using primer and a varnish after the white paint? I'm asking because I tried to varnish a white painted piece and it turned yellow and I still thinking where is my mistake. Thanks and keep up the excellent work!
__________________
Latest Project: « «[ Little Angel ]» » (FINISHED!) Sponsors: *** Aquatuning | Atlas Informática | NZXT *** *** ProSilentPC | Seasonic | IzarMicro | E22 *** Follow me on Facebook! |
#185 |
Keep calm & mod on. =)
Main reason I believe I'm boring people is I've been doing scroll sawing all flipping year
& still don't have any of it fixed together yet. ![]() ![]() ![]() You haven't had a prolonged boring stage at all during this Meelobee & the paint finish is really nice mate, sweet project is sweet.
#186 | |||
< Your add here >
![]() Quote:
If anyone knows how to add varnish without it turning the white paint yellow I'd love to hear how to do this. Quote:
I guess I was bored with it myself, kinda eager to get some stuff build. Thanks again Waynio
#187 |
Multimodder
Wouldn't a clear lacquer work better than varnish?
#188 |
< Your add here >
lol isn't it the same? I used clear coat spraypaint and it gave a yellow hue to the white , I tought that's what xsombrax meant.
#189 |
Minimodder
amazing, love the tidiness of your work!
#190 |
Minimodder
Awesome job! One question a bit off topic.
Are those corsair fans quiet? Because I really love the way they look but I want to know if they're quiet.
__________________
Lurking |
#191 | |
< Your add here >
Thanks Red13
![]() Quote:
Update! Today I added all the plexistrips to the frame (which also was painted) and I've installed the front and back side: |
#192 |
Looking beautiful Meelobee & that paint finish is superb mate, so tasty.
#193 |
Supermodder
Simply stunning build awesome work !!
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
#194 |
What's a Dremel?
Wow, amazing!
Love the fact that it's very original, never seen anything like it, but still it has clean and simple straight lines. |
#195 |
Never stuck with stock@Hotmods.net
Amaaaaaaazing!
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#196 |
Multimodder
#197 | |||
< Your add here >
![]() Thanks bluc ![]() Quote:
Thaaaaaanks! ![]() Quote:
The paint is done by rattle can (spraycans from the local hardware store.) But more important for the finish; I've spend alot of time sanding the aluminium down to P2000 and repeated that between every layer of paint (6 layers in total) |
#198 |
Modder
Excellent fit and finish Meelobee, it's looking fantastic
![]() Is that blue tape on the radiator pipes coming through the case? I guess it's just there to protect the paint for now. I was wondering if rather than solid black fitting coming through those holes, some crystal likes would look better? |
#199 |
Multimodder
WOW:O thaat looks sooo niiiicee:O
but that blue tape?? remember to remove that are you going to mod/paint some of the hardware? |
#200 | ||
< Your add here >
Yes the blue tape is there to protect white paint on the panel, and the black on the fittings, especially the fittings tend to scratch really fast. Not sure if Crystal Links would look better, the holes in the panels are made for the black fittings, Crystal links are a bit smaller so it would leave a gap.Quote:
The tape will be removed, I won't forget I've got some idea's on painting the hardware, but I won't be painting the whole rad. Just some small touches here and there. Stay tuned for more on that
| Tags |
| asus z77, inverted |
| Thread Tools | |
| View Mode | |
