Thread Tools | View Mode |
#21 |
Multimodder
looks amazing ... strange thing is, i find my eyes drawn to the cases feet - the way you've done them is fantastic. (and i don't normally have a thing for feet LOL)
#22 |
The Keeper of History
I like this a lot. I watch.
john
__________________
My deepest gratitude to this community.
#23 | ||
< Your add here >
And yep I'm making a custom case for the psu:Quote:
thanks! |
#24 |
What's a Dremel?
This looks great, i love how clean and symmetrical the rads look, doesn't happen very often. +sub
#25 |
< Your add here >
Thanks wilkinson
![]() Did a bit more work on the psu, mounted it on the bottom panel of the case and I've made the holes for the connectors in the top of the psu: (The long screws on top will ofcourse be cut to lenght.) |
#26 |
Supermodder
this going to be a very special build, me like!
__________________
Works as a tool retailer, glad if i can help someone with tool questions! Hopes that i someday completes my first scratchbuild... |
#27 |
Pump Killer
I got to agree with kelmannen. Very special, and it looks darn good!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nomineeWII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
#28 |
< Your add here >
Thanks guys
Dispite of the hectic last couple of days (I became a daddy yesterday!!) I did manage to find some modding time. I've evened out all of the 'corners' of the frame. The frame, the plexi strips and the aluminum panels now all are the same size. I still need to do some small corrections with a small file, but it looks quite nice already: I've also countersunk the screws on the left side of the case, looks alot cleaner this way: Up next is finishing the PSU housing and placing the pump
#29 |
< Your add here >
I've cut the hole for the pump/reservoir:
#30 |
< Your add here >
#31 |
What's a Dremel?
PSU mod is shweet. favorite part of the build so far.
#32 |
< Your add here >
Thanks A80
![]() I've finished the 2nd pass-through to the top of the case and connected some of the parts to check if everything lines up correctly: |
#33 |
Multimodder
what tools are you using to do this? its all so clean, great work
#34 |
< Your add here >
Thank you Dirky!
For the aluminium and plexi I just use basic tools: A couple of big files to get rid of the big chunks, smaller files for the details, sandpaper to smooth the edges. Most important is alot of patience
#35 |
Supermodder
This looks fantastic.
I love the way you used the fittings... it gives more of a industrial look to the build
__________________
Latest Project: « «[ Little Angel ]» » (FINISHED!) Sponsors: *** Aquatuning | Atlas Informática | NZXT *** *** ProSilentPC | Seasonic | IzarMicro | E22 *** Follow me on Facebook! |
#36 |
Multimodder
#37 |
MD of Mutant Zombie Armies Inc
Looking really nice already. I'm a big fan of straight wc tubing so muchos repos!
__________________
Project: RAt MoD - Updated 16th June '13 i5 3570K, ASUS Maximus 5 Gene, Gainward GTX 670 Phantom, Modded Antec Kuhler 620, 4GB 1600MHz G.Skill RipjawsX CL6, Enermax Revolution 1050W, WD Raptor 150GB , Antec P182 How to Get a FREE (sort of) Hard Drive and Other Small Parts.[/b] |
#38 |
< Your add here >
Haven't had much time to mod lately, but I found some time to get this done:
I've countersunk the screws in both sides now, which gives the whole case a much sleeker look. I've also added some ledstrips in the top part of the case. For the lightning I've ordered a RGB Led Controller with remote control. |
#39 |
Calmer than a monk on morphine
Case looks sweet and congratulations on the +1 earlier! (I hope you get more sleep then I get!)
__________________
All progress is precarious, and the solution of one problem brings us face to face with another problem. - Martin Luther King, Jr. |
#40 |
Multimodder
subbed. i absolutely love what you did with the acrylic.
__________________
Intel i5 3570K - ASUS Maximus V Gene - ASUS GTX 560 Ti DCII TOP - Patriot Viper Xtreme 8GB RAM - OCZ ZT 750W Power Supply - OCZ Vertex 4 128GB SSD - Gelid Tranquillo |
| Tags |
| asus z77, inverted |
| Thread Tools | |
| View Mode | |
