Reply
Thread Tools View Mode
Old 29th May 2012, 12:47   #61
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
Nice controller & awesome news that it's ready for hardware.
And like the sackboy in the background.
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 30th May 2012, 00:39   #62
Halbyrd
What's a Dremel?
Halbyrd has yet to learn the way of the Dremel
Originally Posted by Meelobee
My camera screwed up so the pics have a blue hue..no idea why..
That's usually a white balance issue; check to see if your camera's white balance setting matches up with the dominant lighting in the room. A blue cast usually indicates that it's set for Tungsten lighting when it should be on Fluorescent. If you're using sunlight, try setting the white balance to Cloudy or Overcast.
Halbyrd is offline   Reply With Quote
Old 30th May 2012, 03:25   #63
bluc
Supermodder
bluc has yet to learn the way of the Dremel
Love the way the acrylic is lit up between the aluminium panels how are the leds mounted to the acrylic? Are they edge lit did you embed them into the edge? Or is it an led strip shining onto the surface?
bluc is offline   Reply With Quote
Old 30th May 2012, 07:43   #64
Meelobee
Hypermodder
Meelobee's Avatar
Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.
Thanks Halyrb, I'll check the settings on my camera
Bluc: It's lit by ledstrips shining onto the surface behind the plexi (see my last update post #59)
Meelobee is offline   Reply With Quote
Old 30th May 2012, 09:40   #65
thegyufi
Multimodder
thegyufi - it's over 9000!!!!!!!!1!1!1!!!thegyufi - it's over 9000!!!!!!!!1!1!1!!!thegyufi - it's over 9000!!!!!!!!1!1!1!!!thegyufi - it's over 9000!!!!!!!!1!1!1!!!thegyufi - it's over 9000!!!!!!!!1!1!1!!!thegyufi - it's over 9000!!!!!!!!1!1!1!!!thegyufi - it's over 9000!!!!!!!!1!1!1!!!thegyufi - it's over 9000!!!!!!!!1!1!1!!!thegyufi - it's over 9000!!!!!!!!1!1!1!!!thegyufi - it's over 9000!!!!!!!!1!1!1!!!thegyufi - it's over 9000!!!!!!!!1!1!1!!!
Your work is so clean !! It's hard to believe this is only made with handtools !
Great job here
thegyufi is offline   Reply With Quote
Old 30th May 2012, 09:58   #66
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
Great job matey ! Very interesting and loving your job on the PSU.
GuilleAcoustic is offline   Reply With Quote
Old 2nd Jun 2012, 13:38   #67
Meelobee
Hypermodder
Meelobee's Avatar
Thanks guys
Update!
to continue on the case I needed some hardware, so I got the memory and the motherboard:
Corsair Dominator GT (CMT8GX3M2B2133C9)
Asus Z77 Sabertooth motherboard:
Unfortunately I forgot to make pictures of the motherboard. But I do have these where the motherboard is allready mounted on the case:
Next up is making the holes for the cables and fittings
Old 2nd Jun 2012, 13:40   #68
bluc
Supermodder
Nice board
Old 2nd Jun 2012, 18:34   #69
Meelobee
Hypermodder
Meelobee's Avatar
And another small update:
The memory will be in the cooling loop, so I got a waterblock for it:
EK-RAM Dominator X4:
Installed it on the memory:
Old 4th Jun 2012, 09:47   #70
Meelobee
Hypermodder
Meelobee's Avatar
Yesterday I made a start with the tubing, using Bitspower Crystal Link tubes:
Old 4th Jun 2012, 09:53   #71
bluc
Supermodder
Wondering what sort of finish you have planned for the aluminium. I think clear coated brushed would look awesome
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
Old 4th Jun 2012, 10:38   #72
jamsand
Ultramodder
jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.jamsand is definitely a rep cheat.
^polished
jamsand is offline   Reply With Quote
Old 4th Jun 2012, 10:56   #73
bluc
Supermodder
OK cool equally awesome!
__________________
Old 4th Jun 2012, 12:44   #74
Waynio
Relaxing
Waynio's Avatar
Looking mighty fine mate, the mobo really looks good fixed up on this & memory watercooling cooling seems OTT to me but it completes the look of the motherboard & with the added tubes & fittings it's shaping up to be a beauty of a mod & system, nice.
__________________
Old 4th Jun 2012, 21:51   #75
Meelobee
Hypermodder
Meelobee's Avatar
Brushed alu would be cool, but I probably can't brush the aluminium myself, atleast not in a quality I would be pleased with it. So the case will most likely be painted, not sure on the colour yet. (white?)
Originally Posted by jamsand View Post
^polished
Nah too blingy
Thanks Waynio, yeah the memory cooling is a bit over the top. It might be handy if I want to overclock I suppose.. But damn it sure looks good
Did some measuring and filing for the sata connectors today:
Old 5th Jun 2012, 00:42   #76
bluc
Supermodder
Wow on thoe cutouts for the sata how did you get it that neat??!! I was hoping to find some through panel connectors and sata stuff for my mod but no luck. Also where did you get those sata cable from or did you paint it? Now all you need is double width right angle connector.
__________________
Old 5th Jun 2012, 01:12   #77
Mankz
5318008
Mankz's Avatar
Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.
This sort of stuff isn't normally my cup of tea, but have to say, Im growing increasingly envious of your design and finishing
Mankz is offline   Reply With Quote
Old 5th Jun 2012, 10:55   #78
(RFFN)-SqUeD
I eat dremels for breakfast
(RFFN)-SqUeD's Avatar
(RFFN)-SqUeD has yet to learn the way of the Dremel
WOW really like this build!!! will be following this one!
(I like open cases 2 chck sig )
__________________
MOD-madness ALL the Way
Casemod in Process: Exo-S - With Mystikal0412
Winner MOTM-May-11 Exo-S
(RFFN)-SqUeD is offline   Reply With Quote
Old 5th Jun 2012, 11:05   #79
Tattysnuc
Thinking about which mod to do 1st.
Tattysnuc's Avatar
Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.
I really wasn't sure about the overall looks of this until you installed the motherboard - WOW.
+rep, and a like on FB.
I look forward to your updates!
Tattysnuc is offline   Reply With Quote
Old 5th Jun 2012, 13:45   #80
Meelobee
Hypermodder
Meelobee's Avatar
Thanks bluc
For the sata holes I drilled holes are hand filed them to size with a couple of needle files. The black/white sata cables came with the Asus Sabertooth mobo. If I need more sata ports in the future I'll probably will use straight connectors in the ports above the ones used now.
Good to hear, hopefully I can live up to the expectations
Thanks alot SqUed I love the Exo-S, great style
Thank you very much
Reply
Tags
asus z77, inverted
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
