Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 8th Mar 2012, 11:58   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
SSDs to get faster with SATA Express
DRAMeXchange has published a list of industry trends which includes a timescale for adoption of SATA Express.
http://www.bit-tech.net/news/hardwar...sata-express/1
brumgrunt is offline   Reply With Quote
Old 8th Mar 2012, 12:01   #2
B1GBUD
More Biddy Bang Bang than Sean Paul
B1GBUD's Avatar
B1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming Saiyan
If Express can do for SATA what it did for PCI then I'm all in, oh and cheaper SSD's cheesecake!
__________________
Teh unofficial Bit-Tech proof reader and understander of all the necessary hashtags
B1GBUD is offline   Reply With Quote
Old 8th Mar 2012, 12:27   #3
notmeagain
Supermodder
notmeagain's Avatar
notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.notmeagain is the Cheesecake. Relix smiles down upon them.
mmm 2tb/s transfer speeds.
in raid0....
My pr0n will load in 0.00003e-12m/s
__________________
Intel i7 4790k @ 4.8ghz | Palit Jetstream GTX980 @ 1379mhz | 16GB Patriot RAM @ 2145mhz | Asus VG248QE | Oculus Rift DK2
notmeagain is offline   Reply With Quote
Old 8th Mar 2012, 12:29   #4
dunx
ITX is where it's at !
dunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysis
What "app" needs 2TB/s ? But I'll form an orderly queue...
dunx
__________________
Gigabyte Z87x OC-Force - i7-4790k @ 4.3 GHz - 16 GB Crucial Ballistix Tracer Orange/Blue DDR3 @ 1600 MHz - 256 GB Plextor SSD x2 - 6x WD Caviar Black 1TB SATA III HD's - GTX 970 x2- GTX 780 - Titan Black - Coolermaster 1250W PSU - Lian Li PC-D600 - 3x Noctua NF-A14 fans - custom water-cooled - Alphacoool 420mm rads in white - XSPC CPU block and D5 pump - Griffin Powermate x2
dunx is offline   Reply With Quote
Old 8th Mar 2012, 12:40   #5
Cerberus90
I Mod, Therefore I Own
Cerberus90's Avatar
Cerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming Saiyan
The only practical use I can think of for those sort of speeds would be large scale backup systems. But then, the SSDs wouldn't be larger enough to store enough data for a backup system that needed speeds like that.
Unless we're going to start getting >10TB drives, it seems a bit pointless.
__________________
Steam: Cerberus90
| i3-4160 3.6GHz | MSI Z97S SLI Krait | 16GiB HyperX Fury 1866 |256GB Samsung 830 |
| Strix GTX980 WC'd | Thermaltake Armor |
Cerberus90 is offline   Reply With Quote
Old 8th Mar 2012, 13:30   #6
Bauul
Sir Bongaminge
Bauul's Avatar
Bauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run Crysis
dunx
2TB/s is fast enough to use a harddrive as RAM. Not that SSDs are fast enough for that yet, but it paves the way for a system design that doesn't need RAM any more.
__________________
Intel Core i5-2500K | 8Gb Corsair Vengeance DDR3 1,600 Mhz
Gigabyte Geforce 460 GTX OC 1Gb | 1Tb + 1.5Tb Samsung Spinpoint F3 | Asrock Z68 Extreme4
Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups
Bauul is offline   Reply With Quote
Old 8th Mar 2012, 13:42   #7
Adnoctum
Kill_All_Humans
Adnoctum's Avatar
Adnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for president
No more load screens? How am I going to learn how to play a game without reading the tips during the load screens?
Read the manual? PFFT, what do you think I am, someone with TWO X chromosomes?
__________________
Main Rig: Amiga A1200 - Motorola 68EC020@14.2MHz + 68030@50MHz Acc. Card - Lisa Graphics - 2+8MB RAM - 80MB HDD
LAN Rig: Amiga A500 - Motorola 68000@8MHz - Denise Graphics - 512+512KB RAM
Adnoctum is offline   Reply With Quote
Old 8th Mar 2012, 14:09   #8
[-Stash-]
Multimodder
[-Stash-] has yet to learn the way of the Dremel
<sarcam>NOOOOOOOO!!!! I don't want faster hardware, what a complete and utter waste of time. I don't ever see myself *ever* using anything faster than I have right now. Especially since SSDs are never going to get bigger, or cheaper, because no one needs more space on them or wants to pay less.</sarcam>
Why do people *always* say stuff along the lines of "what's the point of having something faster than I can use today"? Well silly, so you can create NEW use cases if you have hardware more capable than you need today. I mean who look back to 1995 or so and Myst - today we can freely move around in an environment, prettier than that, in real time. But out current hardware is laughably overkill for running Myst today!
Bring on the development I say - keep the competition high and we'll keep getting better and better computing at cheaper and cheaper prices!
[-Stash-] is offline   Reply With Quote
Old 8th Mar 2012, 15:50   #9
azazel1024
Supermodder
azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.
Future proof.
Current RAM speeds are roughly 20-40GB/sec compared to SATA6Gbps, which is roughly .6GB/sec max real transfer rate.
So RAM is still close to 100x faster than the fastest SATA interface. NAND flash and other chip based storage doesn't look like they'll be fast enough to be on par with RAM anytime soon, but at the same time opening it up for years and years of future proofing is not a bad thing. PCI-e electrical interconnect might also reduce latency some, though most is related to the NAND itself, which is still massively slower than DRAM.
However, it doesn't hurt to be able to push a GB/sec or two. Nothing wrong with loading up Windows in 3-5 seconds instead of 20-30 seconds of a fastish SSD now. Speeds up enterprise stuff too. In portable stuff it'd reduce power consumption as well as the processor could drop back to idle faster instead of being at a higher power state processing data as it slowly comes in from mass storage instead of being able to hammer through it as it floods in and then go back to sleep.
A 30s load time for an app wastes a lot more power than running the CPU at a somewhat higher load and being able to pull it from main storage in 4-8s.
__________________
Core 2 Duo E7500, MSI P43-C51, 2x2GB G.Skill Eco DDR3 1600 Cas 7, OCZ Vertex 60GB, Vertex 30GB, Samsung F3 500GB, Samsung F4 2TB, Powercolor Go Green ATI 5570
azazel1024 is offline   Reply With Quote
Old 8th Mar 2012, 18:57   #10
ch424
Design Warrior
ch424's Avatar
ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.
2TB/sec sounds completely wrong - it'd be 140 PCIe 3.0 lanes... Maybe in 10-15 years, but certainly not any time soon!
ch424 is offline   Reply With Quote
Old 8th Mar 2012, 19:42   #11
N17 dizzi
Mod Amateur
N17 dizzi's Avatar
N17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming Saiyan
Originally Posted by azazel1024 View Post
Future proof.
However, it doesn't hurt to be able to push a GB/sec or two. Nothing wrong with loading up Windows in 3-5 seconds instead of 20-30 seconds of a fastish SSD now.... snip
What do you consider loading windows?
Not including POST, my SSD loads a ready to use win 7 in less than 10 seconds now
N17 dizzi is offline   Reply With Quote
Old 9th Mar 2012, 03:33   #12
iwod
Multimodder
iwod has yet to learn the way of the Dremel
I think they mean 2 Tbps which is more then 3 times faster then current 6 Gbps.
Most test show we will need many software adjustment to take advantage of these speedy storage.
iwod is offline   Reply With Quote
Old 9th Mar 2012, 03:53   #13
rogerrabbits
Banned
rogerrabbits has yet to learn the way of the Dremelrogerrabbits has yet to learn the way of the Dremelrogerrabbits has yet to learn the way of the Dremel
Progress is good.
rogerrabbits is offline   Reply With Quote
Old 9th Mar 2012, 08:58   #14
ch424
Design Warrior
ch424's Avatar
If it's Tb/sec, then 2000/6 = 333 times faster than today's standard
If it's TB/sec, then (2000*8)/6 = 2666 times faster than today
I think there must be a typo in the press release or something. They could mean 2GB/sec, as in 16Gbit, which would be plausible!
Old 9th Mar 2012, 13:09   #15
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Yeah, looks like the release was wrong: SATA-IO says 16Gb/s: http://www.sata-io.org/technology/sataexpress.asp
I'll stick a correction in.
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 14th Mar 2012, 10:01   #16
steve30x
Multimodder
steve30x has yet to learn the way of the Dremel
I just want a fast and reliable SSD in my rig. I am fed up of listening to the sound of my mechanical HDD inside my computer case. I cant wait until I can buy a 500GB SSD at a resaonable price.
__________________
CPU : Intel Core I5 760 @ 3.9GHZ
GPU : Palit GTX580 (with palits dual fan cooler)
Motherboard : Asus Maximus III Gene
RAM : 4GIG Kingston ValueRam 1333MHZ @ 1224mhz
Power Supplie :Corsair HX1000
steve30x is offline   Reply With Quote
Old 14th Mar 2012, 12:44   #17
kenco_uk
I unsuccessfully then tried again
kenco_uk's Avatar
kenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyan
16Gb = 2GB bandwidth. So that's nearly 4 x current speeds. Not too shabby.
__________________
formaggio gāteau
kenco_uk is offline   Reply With Quote
Old 15th Mar 2012, 22:14   #18
leexgx
CPC hang out zone (i Fix pcs i do )
leexgx's Avatar
leexgx has yet to learn the way of the Dremelleexgx has yet to learn the way of the Dremelleexgx has yet to learn the way of the Dremelleexgx has yet to learn the way of the Dremelleexgx has yet to learn the way of the Dremelleexgx has yet to learn the way of the Dremel
Future proof.
forgot to correct that for you before
Sata 6 is 600MB/s not 6GB/s, around 550MB/s useable
DDR3 is more like 15GB/s ish or 15000 Ish MB/s,
__________________
i7-920 (4Ghz) <> Titian ferna <> Rampage extreme III<> GTX480 <> 24gb 3x8gb random make 1600 <> SSD Mx100 500gb / segate .11 1.5TB <> X-Fi Titanium Fatal1ty <> TK 1000w Toughpower <win7 x64> GreenFrog Computers Warrington
leexgx is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
