Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 8th Mar 2012, 13:42   #1
docodine
I Mod, Therefore I Own
docodine's Avatar
docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!
Cheap Korean 27" IPS Monitors
http://hardforum.com/showthread.php?t=1675393
http://www.overclock.net/t/1215866/r...d-catleap-q270
Basically, 2560x1440 27" IPS monitors for half the price of Apple, Dell, etc.
Does anyone here have any experience with these? Apparently these monitors have the same panels as the Apple 27" display, but they're being sold for ~$400 (£250) on eBay. More for the more feature-full variants (OSD, better dead pixel guarantees, etc).
I've already started budgeting for one, and might buy by the time my birthday rolls around next month.
Quality seems to be extremely hit and miss, especially on the one with the glass screen. Reports of bits of dust stuck inside the housing aren't uncommon. Backlight bleed also seems to be all over the place.
Some variants have VESA mounts, which is pretty neat.
These are definitely not better than the U2711 or others, but for the price they seem fantastic.
__________________
Intel i7-3820 @ 4.65GHz | HD 7850 | 4x4GB Vengeance | Asus Sabertooth X79
HAF XB | OCZ 1000W | Samsung 830 256GB | CM QF Pro w/Browns | CM Xornet
docodine is offline   Reply With Quote
Old 8th Mar 2012, 14:05   #2
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.
wow, that's fantastic value. a bit of casing lottery, but the actual panels should be solid. (since there's only one LG IPS that does this resolution)
i would say go for it, looks like a great deal.
__________________
i7 2700k \ 16GB \ gtx580 \ D2X \ z68x-UD5 \ m4 128GB +2TB \ Ax850 \ FT02-RW \ G15+G5+G51 \ U2711 27"
5D mkII \ 24-105 L \ 17-40 L \ 85/1.8 \ 35/2 \ 70-300 Di \ 270ExII \ 430ExII \ 3LT Adrian \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 8th Mar 2012, 14:26   #3
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.
It's funny, it's EXACTLY the Hazro, look, just the name is different. LOL!
http://www.tftcentral.co.uk/reviews/hazro_hz27wa.htm
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features.
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is offline   Reply With Quote
Old 8th Mar 2012, 14:27   #4
true_gamer
Cheesecake anyone?©
true_gamer's Avatar
true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.
I'm liking the 95Hz-97Hz refresh rate.
__________________
i7 3930K @ 4.7GHz - ASUS Rampage IV Extreme - 16GB Corsair 2400MHz 10 12 12 31 - 3x EVGA GTX 670 F.T.W 4GB Tri SLI with AquagraFX waterblocks Cores: 1306MHz Memory's: 7114MHz - 128GB OCZ Vector SSD - 2TB WD Black Caviar - Silverstone TJ07 - Silverstone Strider 1KW - Samsung DVD/RW - Custom Waterloop - U2713HM 2560x1440 @ 90Hz Overclocked
ORIGIN username: wipeyourarse - Steam ID: true_gamer - UPLAY ID: true_gamer
My Crysis 3 Ultra Config My Crysis 1 ultra Config
true_gamer is offline   Reply With Quote
Old 8th Mar 2012, 14:40   #5
longweight
GIFted
longweight's Avatar
longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.
If they do a 30" version I will be all over it for my desk at work!
longweight is online now   Reply With Quote
Old 8th Mar 2012, 14:57   #6
GoodBytes
GoodBytes's Avatar
I am voting that the monitor circuitry is busted, or the circuit drops it down to 60Hz, so you are feeding the monitor more frames it can actual handle.. don't ask what it will do to gaming. It might even break the circuit inside at a long term... (especially that I highly doubt that there is any quality out of these) who knows, but the specs states 60Hz, If people desires to push it, well to bad for them.
__________________
Old 8th Mar 2012, 17:16   #7
IvanIvanovich
будет глотать вашу душу.
IvanIvanovich's Avatar
IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.IvanIvanovich is the Cheesecake. Relix smiles down upon them.
They do seem like an alright deal on B-grade panels. I'm still going to wait and see what LG prices the upcoming DM series at. Considering how competitive pricing was on BN series these might not turn out to be that great of a deal.
__________________
[end of line]
intel i5-750 | evga p55 sli | 8gb mushkin blackline | evga gtx670 | 240gb mushkin chronos dx
| creative titanium hd | mushkin 580w | gh60 custom | logitech mx revolution | achieva shimian qh270
IvanIvanovich is offline   Reply With Quote
Old 8th Mar 2012, 17:27   #8
.//TuNdRa
Resident Bulldozer Guru
.//TuNdRa's Avatar
.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president
I'm curious to see the actual quality of one of these panels. I've been wanting IPS goodness for a while, and upgrading to 2560x1440 while i'm at it would be nice.
__________________
Dozy Beast: AMD FX8120 | Thermalright Archon | Asus Crosshair V Formula | 16GB (4x4GB) Corsair Vengeance LP | Asus Xonar DX/XD | 2X SLI KFA2 550Ti White Edition | Silverstone SSTG1000W | Silverstone Raven RV-02B V1.7 | OCZ Agility 3 60GB | 1.5TB in Drives | Lite-on Blu-ray ROM
Acer H226HQL | Sennheiser HD 485s | Creative Gigaworks T40s | Logitech G13 | Microsoft Sidewinder X6 | Cyborg R.A.T 9
.//TuNdRa is offline   Reply With Quote
Old 8th Mar 2012, 17:28   #9
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
I'm rocking a couple of the LG BN panels and they're great! Especially at £126 each.
Even if the monitor is that much of a bargain, I still wouldn't be tempted if they're hit and miss.
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 9th Mar 2012, 00:20   #10
Mac_Trekkie
Source Engine's #1 fan!
Mac_Trekkie's Avatar
Mac_Trekkie has yet to learn the way of the DremelMac_Trekkie has yet to learn the way of the Dremel
It seems to have pretty solid reviews, and a couple of the Catleap variant sellers on EBay have near perfect feedback. I might try getting one, I'm in no need of professional level controls like the U2711 has, and at this price I don't see how I could pass it up, since it's about the same as the Dell U2412m I was eyeing up.
__________________
The Brass Balls: i7 870 @ 4.2ghz | Cooler: CM Hyper 212+ | 8gb G.Skill Ripjaws DDR3 1600 | GPU: ZOTAC GTX 560 Ti 448-core 1,280mb | Motherboard: MSI P55-GD65 | Case: ThermalTake Element G | ThermalTake 850w PSU | Samsung Spinpoint F3 1tb | Corsair Nova 32gb SSD
Mac_Trekkie is offline   Reply With Quote
Old 9th Mar 2012, 00:37   #11
GoodBytes
GoodBytes's Avatar
Never listen to user reviews. Else the 80$ TN panel, no stand included, and you have to drill your own VESA holes yourself, would also be an excellent choice.
The problem is that people consider price... and anything can be a "good deal". That is also why we don't have nice things, and consumer computer are bombarded with junk and advertisement per-installed, only 1 year warranty, horrible warranty service, horrible after sale service, and cheap quality.
The reason why I am not exited by this, is because I was exctlay like you.
"Oh RAM is RAM, I won't overclock it. Let me buy this no name value pack value RAM", same for everything with my computer down to keyboard and mouse. I was like "A mouse is a mouse, I won't fall for these marketing crap and fancy colors and spending more than 8$ on a mouse.". I was usng VIA chipset. The only thing that was not crap was my CRT monitor, because I had no choice, as the flickering was too much, so I had to get a monitor, not only with a fast response time, but also higher grade phosphore to stop it, and the GPU, because I had to play games.
All I had was problems, everything was not enjoyable, which made everything sucked. The computer was noisy, always crashing, my keyboard was impossible to type on, and keys stops working shortly after. Friends laughing at me for all the problems I had with the system, forum (not here) gave up on helping me. This is where I had enough. I worked my ass off during summer to save up and get myself and high-end (not really spec wise, but I did spend 700$ on a CPU, to get AMD's (Intel had nothing alike) first Dual Core, 64-bit CPU. And it never caused me any issues since, And it's still running today.. it pass thought XP, Vista 64-bit with an enjoyable experience, and now Win7 64-bit.
My dad uses it now, as the CPU isn't powerful enough for my needs, but still awesome how far it keeps going. It passed though a few keyboard and mouse, but always great ones, which made the experience very enjoyable. And today I continue this path.
This is what i expect from this monitor:
-> Floating stand (the monitor will hold in in place)
-> Terrible back light bleeding
-> Terrible back light evenness
-> Horrible build quality
-> 0 warranty
-> 0 support
-> Will break in a year (else you got a manufacture error, lucky you)
-> Average colors (a la TN panels,)
-> not great ACTUAL response time
And of course glossy.
Is it worth it? Not in my book.
__________________
Old 9th Mar 2012, 00:43   #12
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.
Glossy screen. I'll pass.
__________________
Uni Box:i5 2500K@5GHz|EK Supreme LT+Coolstream XT 240|16GB HyperX DDR3@1866MHz(in blue)|EVGA GTX670SC 4GB+EK FC670|MSI P67A-GD55||M4 256|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Sidewinder X5 + Intuos 4M
Audio: PC->TosLink->TEAC UD-H01->Schiit Asgard-> Denon 5000|PFE232|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 9th Mar 2012, 05:59   #13
.//TuNdRa
.//TuNdRa's Avatar
Glossy; I can live with. The colours appear to be better in all comparison images I've seen. (Yes, even on my TN panel.) Backlight bleed doesn't look anywhere near as bad as my current screen, so that would be an improvement. Blacks look better. I'm going to be sticking it on a VESA mount anyway, so even if the stand is crap; It doesn't matter.
At the end of the day; I think we all recognize it's not going to be amazingly high quality. However: If it proves to be better than everything else at the same price-point, and doesn't explode within a short amount of time; what is there to loose? I've known some exceptionally cheap components that have just refused to die before now.
Everything I can find so far, albeit in Korean, claims that the panels are actually reasonably good. Not groundbreaking amazing like the U2711, but considering it's not much over half the price; I wouldn't complain too much about it.
__________________
Old 9th Mar 2012, 07:27   #14
j4mi3
Ultramodder
j4mi3's Avatar
j4mi3 can run Crysisj4mi3 can run Crysisj4mi3 can run Crysisj4mi3 can run Crysisj4mi3 can run Crysisj4mi3 can run Crysisj4mi3 can run Crysisj4mi3 can run Crysis
No way in hell would I risk that. Also good reviews can easily be done by the sellers themselves
__________________
BF3: Pr0_snipe
i7 2600k @ 4.6 | Asus P8P67 Deluxe | Asus GTX 670 Direct CUII TOP | Gskill Ripjaws x 16gb 2200mhz | Noctua nh-d14 | Antec 1200 | Enermax Revolution87+ 850w | Crucial M4 64gb | WD Caviar Black 500gb | Dell U2711 |
j4mi3 is offline   Reply With Quote
Old 9th Mar 2012, 07:34   #15
longweight
GIFted
longweight's Avatar
I just want the big resolution, I don't care about the colour quality that much.
Old 9th Mar 2012, 07:50   #16
Parge
Do you even mod, bro?
Parge's Avatar
Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.
To anyone considering this monitor, be aware that you are entering a lottery.
On the one hand you might get a good deal - a 27" 2560x1400 IPS panel for ~£300
On the other hand you might get a panel riddled with dead pixels, that lasts a year, with absolutely no chance of a refund. Be aware that a new Dell U2711 with a three year warranty and pixel guarantee costs £600 or so - and that is not a rip off.
Goodbytes advice is sound, but of course, the decision is yours.
__________________
Deep Silence 1 - 2500K @4.6Ghz - ROG Maximus V Extreme - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG
Parge is online now   Reply With Quote
Old 9th Mar 2012, 07:54   #17
longweight
GIFted
longweight's Avatar
Yeah I know but I don't need the U2711 quality at work, I love it at home but I just need more work space at work! 2, 1920 x 1080 monitors isn't good enough and the low resolution really bugs me!
Old 9th Mar 2012, 08:12   #18
Margon
Margon Man
Margon's Avatar
Margon is definitely a rep cheat.Margon is definitely a rep cheat.Margon is definitely a rep cheat.Margon is definitely a rep cheat.Margon is definitely a rep cheat.Margon is definitely a rep cheat.Margon is definitely a rep cheat.Margon is definitely a rep cheat.Margon is definitely a rep cheat.Margon is definitely a rep cheat.Margon is definitely a rep cheat.
my monitor is a cheap pos anyway that cost about the same as this so I might buy one of these at the end of the month - Then i'll let you all know how good/bad/ugly it is!
__________________
i7 920 - 12GB - 5870
Keycool 87 Ergo-Clears - Cougar Attack Reds - KBT Oni Blue + clear springs - Ducky DK1087 Browns - Cherry G80-3700 Blacks
Margon is online now   Reply With Quote
Old 9th Mar 2012, 10:11   #19
Parge
Parge's Avatar
Please do!
__________________
Old 9th Mar 2012, 10:22   #20
jizwizard
stop your grinning and drop your li
jizwizard's Avatar
jizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpit
All the info you need on these monitors
170 pages of info reviews and much more
Enjoy
__________________
Bitfenix Prodigy / Asus p8z77-I deluxe / 2700k@5.2 / Samsung 2x4gb @ 2400mhz /
Hx1050 (overkill) / Gtx570 (soon to be 690) / 2x64gb M4 / WD 3tb book / BenQ 2410t
G19 / G27 / and some watercooling for good measure
jizwizard is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
