#1 |
Supermodder
LIAN-LI PitStop T60 Red
LIAN-LI Pitstop T 60
Here we are ready for yet another adventure, well going to take 'into consideration a feast of Lian-Li. Fasten your seatbelts Do not smoke prepare the popcorn Following the beer and .......... good vision at all Ermanno Let's start with posting the material, the case ![]() ![]() ![]() ![]() Continue the presentation of the case: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#2 |
Supermodder
OCZ Power Supply
Now we will examine the power supply from 750w un'OCZ that will go 'part of this mod ![]() ![]() ![]() ![]() ![]()
#3 |
Supermodder
Asrock motherboard
now we move to the motherboard necessitudine staining I chose this card, fits perfectly with the mod and certainly will make 'his voice heavy lifting the cpu frequency to very high levels ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#4 |
Supermodder
And the adventure continues, but I'm going to submit another Harware, but rather the essential components that will dissipate the Lian-Li
We start with the arrivals from Aquatuning ![]() ![]() ![]() We begin with the pump, is a Koolance PMP-300 is the small but pushes much ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#5 |
Making You Feel Old Since 2010
Oh come on!?
I just had to pick my jaw up off the floor from your glass project, and now I have to get ready to do it again?
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#6 |
Supermodder
Now we turn to the flow, but this will be 'only visual, but there will be' a controlled dall'Aquaero xt
As I said this is only a factor esthete and will be 'enlightened, I removed the original and I placed an LED RGB LED ![]() ![]() ![]() ![]() You guys are a step above the lines, we are speaking of red anodized aluminum passive heatsinks, small Carello of photos and for working in the next post ![]() ![]() ![]() ![]() ![]()
#7 |
This is just too cool!
__________________
#8 |
Supermodder
#9 |
Supermodder
I can not put the thermometer and the fans are from Micro 40x40mm, rock 'also add the liquid of Nanoxia
#10 |
Supermodder
Consider the passive heatsinks, as you see them coming, then for them to adapt to my mod I had to do some little hole
Armed with the tip of 3.25 and male M4 I am going to do one of the first working ![]() ![]() ![]() ![]() ![]() ![]()
#11 |
Supermodder
Ok place, the processing of the thermometer in the upper eheheheh
Then you get a nice clean job I fitted a piece of paper tape that I put where I am going 'to cut to fit, and with a little' of sound patient I cut with the DREMEL ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#12 |
Supermodder
We're back to upload, today we examine the so-called shark fins term given by friends, guys here the work is long and containing many photos, I hope 'they just do not fall asleep ahahahahaha
Before processing "Aluminum" we speak of a panel dell'ACRyan satin black and a red Working as a first line them with the 80mm nastrocarta whole area of ??work, in my experience I know 'that the only film sometimes is not enough to protect from scratches especially if using jigsaws. Once coated is passed to the drawing or tracing on the panel, is preparing the work area (a chair with 2 planks of plywood) and the work begins ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#13 |
Supermodder
Here is the most 'delicate tracing of the holes of the fans are cutting and bending
Drilling ............... ![]() ![]() ![]() ![]() And here are the twins ready for further processing ![]() ![]() ![]() Here now we continue to place the media as the first finished work ![]() ![]() ![]() ![]() ![]()
#14 |
Supermodder
Now, let us casting off, bending, it affects the side so as not to incur abnormal folds and then with a little 'tug of war .... and the fold is ready
#15 |
Supermodder
Beat the fans are 40mm and see what comes out ........
#16 |
This is too much for me, so awesome!
Now stop going so fast!
__________________
#17 |
Supermodder
First phase was successful, the second pass, we prepare the coating media
#18 |
Supermodder
#19 |
Supermodder
Once assembled, we see that effect are also illuminated
#20 |
Supermodder
We see a beta assembly:
| Thread Tools | |
| View Mode | |
