#81 | |
Modding and coffee
#82 |
Modding and coffee
Another Update!!!
![]() ![]() ![]() ![]() ![]() Ok, can't resist posting the pics of a filled M8 ![]() After adding 2.5 liter EK-Ekoolant blood red ![]() ![]() ![]() ![]() Still some air in the front ![]() ![]() Picture with some leds, but don't know if i keep these ![]() Other side a bit more careful so just in case everything is covered ![]() And again a build without leaks, maybe because this time I used EKWB rotery's ![]() After some hours The beautiful EK-FC680 GTX - Acetal + Nickel CSQ ![]() And the EK-Supremacy - Nickel ![]() ![]() All tubes filled ![]() ![]() ![]() ![]() ![]() ![]()
#83 |
Supermodder
Beautiful!
Now trying to justify a double wide build LOL
__________________
Intel i5 2500k @ 4.5Ghz / Dark Rock Adv. MSI Z68A-GD55
Asus Radeon HD6850 Direct CU @902Mhz 8gb (4x2) Corsair Vengance LP 1600Mhz OCZ Vertex 4 128gb Seagate 320gb & Samsung 1tb Coolermaster 600w Silent Pro Modded Lian Li PC-0700 |
#85 |
Multimodder
Inspiring as always!
__________________
Project Carbon Apple |
#86 |
Modding and coffee
![]() Thanks That's why we do it |
#87 |
Supermodder
Awesome job man, looks great! Do you have any tips for planning what you need for the acryl pipes? Like how many fittings you need? I keep thinking I won't end up with straight lines like you did.
#88 |
Modding and coffee
Update!!!
![]() ![]() ![]() ![]() ![]() It took a while, but here is on of the latest updates of the CaseLabs M8 build Because of some problems related to shipping and other stuff it took a little longer before i received the second Lamptron touch controller. Thanks to Highflow I received it so that I could continue The 2e Lamptron touch controller Not long after this I got the controller from Lamptron thanks Lamptron !!!![]() ![]() Installed and tested. Works perfectly!!! ![]() ![]() Looking good i think ![]() Time to connect the cables ![]() ![]() ![]() ![]() ![]() ![]() ![]() Before the power goes on some detail shots ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I also have applied some SMD LED strips, which are made available by a good friend of mine from lumenledverlichting. Clenn Thanks!!! ![]() Above a white LED strip and underneath 2 red LED strips, and this on both sides ![]() And on top of the HDD coolers also a LED strip instead of a single LEDs ![]() ![]() Something wrong with this picture above ![]() Not anymore now!! ![]() Looks good with the lights and fans ![]() ![]() ![]() ![]() ![]() ![]() Up and running!!! ![]() ![]() Soon the final photoshoot
#89 |
Never stuck with stock@Hotmods.net
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#90 |
Modding and coffee
Final Update!!!
![]() ![]() ![]() ![]() ![]() After a long wait.... the final pics. This build was quite a challenge given the size and space to be filled. Now .... no more text only pics. Hope you like it!!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() That's it!!! A lot of pics I know, but easy to read ![]() My thanks goes to the following persons who have made this build possible: Jim from Caselabs for providing the beautiful Caselabs Magnum M8 ![]() Maurizio Lamptron for the Fancontrollers and switches ![]() Freddy from Highflow for various products...best shop in town ![]() ![]() Marco and Ruud from Coolermaster for the PSU and gamegear ![]() And Gregor from EKWB for supplying the water cooling products and always having the confidence in my builds ![]() Clenn from lumenledverlichting for the SMD ledstrips ![]() Without these people, the build couldnt finish like it is now.....thanks y'all And of course the people of the various forums for the support and comments |
#91 |
www.^.nl
Awesome build again Ries!
__________________
Preparing: Raz3r D3sk Finished : L3p Parvum - Cross - L3p AlCu - L3p L4n - L3p D3sk Sites: www.l3p.nl - www.redharbinger.com |
#92 |
Multimodder
Most beautiful tubing I've ever seen! And an impressive combination of colours!
#93 |
Terminating People Since 1980....
Gorgeous rig such attention to detail amazing work
__________________
Main: i5 4670k/ Asus Maximus VI HERO / 8Gb Corsair Vengeance 2133mhz RAM (Red) / 120Gb Kingston V+200 SSD / Asus HD7970 / Corsair AX850 / CM Storm Trooper / Mionix Zibal 60 / HTPC: HP ProLiant G7 N54L microserver The Project: Antec TwelvOrange |
#94 |
Supermodder
Absolutely stunning man, love the acrylic tubing details all around the case. Well done sir!
+rep |
#95 |
Fenrir The Wolf
Looks apsolutely amazing. Great job,mate.
#96 |
Project: Elegant-Li
Fantastic end result, congratulations
__________________
Project: Elegant-Li *NEW* Project: Alpha FINISHED Project: LEXA Revival FINISHED Project: LEXA FINISHED MOTM Nominee October 08 |
#97 |
What's a Dremel?
One of the most beautiful mods I have ever seen by the modding King.
| Thread Tools | |
| View Mode | |
