Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 20th Mar 2012, 12:44   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Just five Windows 8 ARM devices at launch, say sources
Sources have claimed that just five ARM devices will be available when Windows 8 launches in October.
http://www.bit-tech.net/news/bits/20...-arm-devices/1
brumgrunt is offline   Reply With Quote
Old 20th Mar 2012, 12:53   #2
Fruitloaf
Tinkerer
Fruitloaf's Avatar
Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!
Really this news has become less and less interesting all the time. What I would really love is a multifunctional tablet like the Transformer. Stick it in the dock and you can do useful multitasking work and when you don't need it leave the dock at home/in your bag and you have a good touch friendly tablet.
WoA might do the later but well so does Android and Apple and they have way more apps than MS.
Fruitloaf is offline   Reply With Quote
Old 20th Mar 2012, 12:57   #3
Bauul
Sir Bongaminge
Bauul's Avatar
Bauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run Crysis
The only reason Windows 8 will support ARM is so it's a valid tablet OS option. Microsoft aren't interested in ARM powered laptops or desktops or anything, which is why they're locking out other operating systems being installed.
__________________
Intel Core i5-2500K | 8Gb Corsair Vengeance DDR3 1,600 Mhz
Gigabyte Geforce 460 GTX OC 1Gb | 1Tb + 1.5Tb Samsung Spinpoint F3 | Asrock Z68 Extreme4
Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups
Bauul is offline   Reply With Quote
Old 20th Mar 2012, 12:59   #4
DwarfKiller
Multimodder
DwarfKiller's Avatar
DwarfKiller has yet to learn the way of the Dremel
Pretty sure that should be 'pairing' and not 'paring'
4th paragraph.
__________________
i7 930 @3.8 + Titan Fenrir | Asus P6T SE | HD5870 PCS+ | Corsair XMS3 Classic DDR3 @1600 | CM690-II Adv. | 750W Seasonic-X |
DwarfKiller is offline   Reply With Quote
Old 20th Mar 2012, 13:38   #5
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
4th paragraph.
Whoopsie - fixed, ta.
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 20th Mar 2012, 14:10   #6
kenco_uk
I unsuccessfully then tried again
kenco_uk's Avatar
kenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyan
Not so much WARM as tepid.
__________________
formaggio gāteau
kenco_uk is offline   Reply With Quote
Old 20th Mar 2012, 15:53   #7
Blackshark
Multimodder
Blackshark has yet to learn the way of the Dremel
Win 8 is the first OS I dont think Ill be installing. Sure if I buy a tablet or slate, but the non touch interface is non existent, hostile even.
Cant see Business being happy that all their corporate PCs (without touch) will require staff to go on a 'how to do everything you are used to in Win 95/98/2000/XP/Vista/7'!! Really hope that the normal Win 8 Desktop, control panel are updated before released (or should that be regressed).
Blackshark is offline   Reply With Quote
Old 20th Mar 2012, 18:14   #8
Madness_3d
Bit-Tech/Asus OC Winner
Madness_3d's Avatar
Madness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for president
Won't be using it, I like running my apps in a window thank you very much. Nothing wrong with 7
__________________
XFXScorpio911 ¦ INTEL i7 3770k @ 4.5Ghz ¦ SLI GTX 480 1536MB ¦ ASUS MAXIMUS V FORMULA ¦ 16GB CORSAIR DDR3 1600 9-9-9-24 1T¦ CORSAIR HYDRO H50 ¦ CORSAIR Force 3 120GB ¦ WINDOWS 7 HP 64bit ¦ Musings On The Technical World ¦ Steam
Madness_3d is offline   Reply With Quote
Old 21st Mar 2012, 02:05   #9
SexyHyde
Supermodder
SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.
The company has confirmed that Windows 8 on ARM won't feature any form of abstraction layer to offer compatibility with existing x86 applications, meaning users' existing programs won't work. Worse still, the company has confirmed that it will be requiring OEMs to enable UEFI Secure Boot functionality, preventing users from installing alternative operating systems.
it'll be like linux then, only without the community and open source software.
SexyHyde is offline   Reply With Quote
Old 21st Mar 2012, 07:34   #10
azrael-
I'm special...
azrael-'s Avatar
azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!
I think 5 ARM devices with Windows 8 for an October 2012 release is pretty good considering the "Windows on ARM" release is slated for early 2013.
Sadly, for me Windows 8 is a complete non-starter unless Microsoft changes its mind and makes the Metro UX optional on the desktop. Which we all know won't happen...
__________________
It's not the end of the world ...but you can see it from here.
Xeon E3-1245 v2 3.4 GHz | ASUS P8C WS | 16GB Kingston ECC DDR3 | Samsung 830 256GB | eVGA GTX670 2GB | SB Audigy | Seasonic X-560 | Corsair Obsidian 550D | Dell 2209WA
azrael- is offline   Reply With Quote
Old 21st Mar 2012, 08:46   #11
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.
Yup. Same here. Nothing wrong with Windows 7, plenty wrong with 8.
__________________
The Box:i7 2700K@5.3GHz|EK Supreme LT+Coolstream XT 360|16GB HyperX DDR3@1866MHz|EVGA GTX780 ti+EK FC780ti|MSI P67A-GD55||M5 512|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Perixx MX2000 + Intuos 4M
Audio: PC->TosLink->TEAC UD-501->Fostex TH600|InEar LivePro 3|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Reply
Tags
warm
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
