Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 21st Mar 2012, 09:41   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Why you should insist on USB 3
Ignore the USB 2 hard disk bargains - go for USB 3 instead
http://www.bit-tech.net/hardware/sto...ist-on-usb-3/1
brumgrunt is offline   Reply With Quote
Old 21st Mar 2012, 09:59   #2
ZeDestructor
Multimodder
ZeDestructor's Avatar
ZeDestructor is the Cheesecake. Relix smiles down upon them.ZeDestructor is the Cheesecake. Relix smiles down upon them.ZeDestructor is the Cheesecake. Relix smiles down upon them.ZeDestructor is the Cheesecake. Relix smiles down upon them.ZeDestructor is the Cheesecake. Relix smiles down upon them.ZeDestructor is the Cheesecake. Relix smiles down upon them.ZeDestructor is the Cheesecake. Relix smiles down upon them.ZeDestructor is the Cheesecake. Relix smiles down upon them.ZeDestructor is the Cheesecake. Relix smiles down upon them.ZeDestructor is the Cheesecake. Relix smiles down upon them.ZeDestructor is the Cheesecake. Relix smiles down upon them.
How about eSATA? I for one have an eSATA dock (has usb2 as well) and the necessary port is found on most machines. Since the disk is attached directly to the chipset, its basically running as fast as it will ever run.
ZeDestructor is offline   Reply With Quote
Old 21st Mar 2012, 10:30   #3
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
That is another option, if your external caddy supports it (a vast majority of 2.5in external drives are USB 2 or USB 3 though) however I've lost count of the number of people that have told me they hate it because of the connector - I too have found it a little too easy to pull out. Just moving my PC once saw it ping out of the socket on my motherboard!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 21st Mar 2012, 10:36   #4
Byron C
This space for rent.
Byron C's Avatar
Byron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming Saiyan
To be honest, I've never really bothered with external hard disks. I've always preferred an internal disk, even for backup purposes. I don't really share files large enough to warrant a USB hard drive; a flash drive has always sufficed.
USB3 is far better, but USB2 is so ubiquitous that it'll take an awful long time for people to switch.
And by the way...
Originally Posted by Page 1, Paragraph 7
The quoted figures of 5Gbps (625MB/sec) aren’t quite what you can expect, especially if you're not using an SSD, but as our testing shows, you can easily see upwards of 80MB/sec using USB 3 storage devices – a huge boost over their USB 3 counterparts, which can barely manage 20MB/sec - and this means you’ll lose little in the way of speed if you decide to use a USB hard disk instead of one connected to a SATA port.
That should be: a huge boost over their USB 2 counterparts, which can barely manage 20MB/sec
Originally Posted by Page 2, Last Paragraph
You’re next PC or motherboard or case for that matter certainly will, so investing in a USB 2 external hard disk is a very short-sighted thing to do, especially given how expensive they are.
You're and your - learn the difference! *wanders off somewhere to seethe with rage*
__________________
Saturn: Gen8 Microserver, G1610T, 4GB RAM, 5TB Disk | Titan: Raspberry Pi 2 Model B, 160GB USB HDD | Rhea: XW4600 Workstation, Xeon X3323, 4GB RAM, 292GB 15K SAS Array | Earth: RVZ01, i5-4670K, GA-Z97N-WIFI, 8GB RAM, 4GB GTX970 | Mars: Dell Inspirion 15-7559, i7-6700HQ, 16GB RAM, 4GB GDDR5 GTX960M
Byron C is offline   Reply With Quote
Old 21st Mar 2012, 10:45   #5
Combatus
Moderator
Combatus's Avatar
Thanks, sorted!
__________________
Old 21st Mar 2012, 10:53   #6
Byron C
Byron C's Avatar
Originally Posted by Combatus View Post
Thanks, sorted!
Sorry, don't mean to be picky!
__________________
Old 21st Mar 2012, 11:17   #7
ZeDestructor
Multimodder
I find it perfectly fine on the laptops with integrated esata/USB combo ports. If anything, I find them too stiff and unwilling to come out... I personally doubt I'll be abandoning eSATA in the near o medium future, especially since you can happily get SATA to eSATA cables and with some help from a PSU with power, easily bypass the dock completely.
Old 21st Mar 2012, 11:41   #8
Asouter
Asouter's Avatar
Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.
There's not many devices out there that are USB 3
__________________
Finished Projects : D33P THOUGHT : THING : Mini Moto Mayhem
Current Project : BITZA
Asouter is offline   Reply With Quote
Old 21st Mar 2012, 11:49   #9
SpAceman
Supermodder
SpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpit
I have found that most retailers have completely phased out their stock of USB 2 external HDDs. There are still quite a few USB 2 flash drives though.
__________________
i7 4770K | Asus Z87-Pro | 16GB Gskill DDR3-1866 | EVGA GTX 760
Silverstone Raven RV02 | Coolermaster V8 | Crucial M4 256GB | Corsair TX750
Dell U2412M | LG W2253TQ | Ducky DK9008 Pro PBT MX Cherry Greens | Naos 7000 | Logitech X-540 5.1 | Logitech G930
SpAceman is offline   Reply With Quote
Old 21st Mar 2012, 11:50   #10
tonyd223
king of nothing
tonyd223 has yet to learn the way of the Dremel
I'm the old guy here (can remember CP/M) and I think usb is one of the GREAT pc innovations. Faster, more power, and backwards compatible - what's not to like? Can't wait for the increase in true usb 3 peripherals though, so where are the HD webcams? The quad tuner DVB-T HD sticks? It's not just about hard drives...
tonyd223 is offline   Reply With Quote
Old 21st Mar 2012, 11:57   #11
Dave Lister
Hypermodder
Dave Lister's Avatar
Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!
I recently built an HTPC which happened to have USB 3 on the motherboard and I also picked up an external 2Tb drive for my media because the htpc is offline. It allows me to rip/download on my main pc and transfer the content more easily. I have to say that transferring to the htpc is much quicker than transferring from my USB 2 PC. My only gripe is that the external drive's USB cable has a weird non standard looking connector at the end going into the drive. If all the manufacturers are using that connector then that's fine, but if not that will put me off USB 3. I'm not a fan of proprietary connectors at all - there is no need for it.
__________________
Main Rig:Case: BitFenix Prodigy, Motherboard: MSI Z97I Gaming, CPU: Intel i7 4790K, RAM: 16Gb 2400Mhz Kingston HyperX Beast GPU: MSI GTX 970 Gaming, Primary HDD: 256Gb Samsung 850 Pro, Games Drive: 2Tb 2.5" Toshiba HDD, Cooler: Corsair H105, OS: Win 7 - 64
Dave Lister is offline   Reply With Quote
Old 21st Mar 2012, 12:06   #12
Mentai
Hypermodder
Mentai has yet to learn the way of the Dremel
I only transfer files to a back up once in a while, so the speed really doesn't make much difference to me. I do like the idea of increased power though, the more I can plug in without using external power the better.
Mentai is offline   Reply With Quote
Old 21st Mar 2012, 12:16   #13
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
It's a shame Apple haven't adopted USB 3 or... it's a shame the PC world hasn't jumped on Thunderbolt.
Even though Thunderbolt is the better tech (IMO) I don't mind which gets adopted as the new standard as long as one of them does!
Thunderbolt has the edge because it's based on PCIe and therefore allows use the use of external PCIe devices in an enclosure. It also carries video, eight channel audio and will allow connections over extreme distances (Using 'smart' cables of extreme price!)
Guinevere is offline   Reply With Quote
Old 21st Mar 2012, 12:17   #14
BrightCandle
Multimodder
BrightCandle has yet to learn the way of the Dremel
The slow take up is likely related more to the slow take up from chipsets on motherboards. Even Z77 isn't all USB 3 ports, its mostly USB2 with 4 USB 3 ports thrown in. The X78 motherboards all added USB3 ports with external controllers, but often those don't perform as well as Intel's chipset controller.
This revision in the specification seems to be quite costly to the chipset and motherboard manufacturers. They are trying to provide ports without replacing all the USB 2 ports. USB is a great advance from all the different ports we had for different devices and its made many things much easier. But has this step finally broken the economic model under which the ports are produced and now we are in real danger of getting stuck?
BrightCandle is offline   Reply With Quote
Old 21st Mar 2012, 12:26   #15
MjFrosty
Hypermodder
MjFrosty's Avatar
MjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on you
USB 3.0 is faster than eSATA in every test you care to mention. That said, people just don't CARE about the increase as it is to the consumer every bit as the same as USB 2.0. The jump from USB 1.0 was much more significant. Much like every thing in the industry right now, it's just a stepping stone.
__________________
Fast
MjFrosty is offline   Reply With Quote
Old 21st Mar 2012, 12:46   #16
Guinevere
Mega Mom
Guinevere's Avatar
Nice sound-bite but not entirely accurate. There's very much mixed results when comparing eSATA to USB 3.0
EG: http://www.youtube.com/watch?v=PqlqCoQMLsQ
EDIT:
Old link, but bit-tech also said that eSATA was faster
http://www.bit-tech.net/news/hardwar...a-still-king/1
But at the end of the day it doesn't make much of a difference, they are so close to each other I'd wager that differences are more of an issue with drives, caching, chipsets and drivers than which interface is actually faster.
If you want to argue over which interface is faster then you have to go with Thunderbolt!
Old 21st Mar 2012, 12:47   #17
ZeDestructor
Multimodder
Is it? Oh well, I'm not switching anytime soon, since on a desktop I just plug in drives directly. Needless t say, I have/need no external enclosures.
Old 21st Mar 2012, 12:49   #18
MjFrosty
Hypermodder
MjFrosty's Avatar
Oh don't get me wrong, I have an E-SATA dock and E-SATA hdd. No USB 3.0 devices at all currently.
@ Guinevere, at which point in that video should I start caring? His voice is annoying me and I have work to do That article is pretty old, controllers have come a way since then
__________________
Fast
Old 21st Mar 2012, 13:07   #19
MrJay
You are always where you want to be
MrJay's Avatar
MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.
Manufacturers need to phase out USB 2.0, saturate the motherboards with USB 3.0 connectors, make it impossible not to use USB 3.0.
As soon as this happens people will start adopting the devices.
Before mechanical storage had its massive price hike i got a WD Elements SE Portable 750 GB USB 3.0 for £48!
The crazy thing was it was priced a good £10-15 under its USB 2.0 counterpart at the same capacity!
__________________
Main Phanteks Enthoo ITX Windowed - Pentium G3258 @ 4.5GHz - 8GB Samsung DDR3 @ 1600 MHz - Sandisk Ultra 240GB - EVGA 760 SC 2GB - Asrock Z97M-ITX/ac - Windows 10
HTPC Intel NUC (Celeron 847) - 30GB Samsung mSATA SSD - 2GB Crucial RAM 1333MHz - Windows 10
MrJay is offline   Reply With Quote
Old 21st Mar 2012, 13:28   #20
kenco_uk
I unsuccessfully then tried again
kenco_uk's Avatar
kenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyan
Using a USB3 2.5" external caddy I am able to write to a 640GB 5400rpm drive at around 70-80MB/s.
http://www.everythingusb.com/targus-...ter-21477.html - interesting.
__________________
formaggio gāteau
kenco_uk is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
