#1 |
I *am* a Dremel
Software for reducing Music size
Hi,
Im looking for a program that will convert my music from 320kbps (CD Rips) and 256kbps (iTunes) to a smaller file size. What is the smallest file size you would recommend and how would I go about this? TIA |
#2 |
Hey What Who
well if it wasnt for the fact that you use itunes i would say use wma (windows media audio), file sizes are a hell of a lot smaller.
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands |
#3 |
Of reasonable knowledge...
Dbpoweramp music converter.
__________________
Pooting: Antec 300, P6T SE, i7 920 (3.20), Corsair F120SSD, 3x1TB HDD, 9Gb (1600XMP), GTX560Ti 2Gb (880/1760/2100), Win7 x64. Grooving: Linn LP12, Klimax DS, Klimax Kontrol, Aktiv Akurate x 10 with Aktiv 242's. Watching: WDTV Live to 50" Panasonic. Serving: HP Proliant Microserver N40L running Openmediavault. |
#4 |
I *am* a Dremel
Its to go on a memory card in a (oldish) phone.
#5 |
I *am* a Dremel
#6 |
I Mod, Therefore I Own
Bear in mind that encoding music twice generally isn't a good idea, will be better quality if you can encode them from the source.
__________________
i5 750@3800 - MSI P55 GD65 - Asus GTX670 DirectCU II - 4GB OCZ DDR3 @1440 7-7-7-18 - Be Quiet! Straight Power E9 500W - Nanoxia Deep Silence One - X-FI Xtreme Gamer - Samsung 830 128GB - Spinpoint F3 1TB - WD Caviar Blue 640 - LG Flatron W2252TQ - Razer Deathadder - Thermaltake Contac 29. |
#7 |
Multimodder
Can only speak for mp3's , but, under 192 kbps always seems to sound wrong to me, you lose a lot of audio quality with the compression. Rip a CD to 128 kbps and you'll probably be able to hear what i mean. 320 kbps sounds good, but obviously flac and wav tend to give even better sound (with a much larger file, not what you want). Doing a variable bit rate can help lower file sizes a little.
If it's to use the phone as a walkman type thing, see if it's possible to get a larger memory card maybe ? Freeware app for conversion - Freemake Audio Converter - i found it off a google search, so can't say how good it is, but it says it does what you'd want. Maybe try converting a track to a few different formats and see if any suit your needs ? |
#8 |
Multimodder
foobar 2k? Converts from any format to whatever you want. As for bit rate, you might want to think about where you'll be listening to that music. Noisy subway with somewhat decent in-ears where you can still hear the crowds. You'll probably be able to get by with 192kbps. Leaky earbuds, maybe 128. Essentially the better you can hear the music, (quiet surroundings / better sound isolating equipment etc) the higher you'd want the bitrate. No point bringing around quality if you can't actually hear it.
PS: Entirely my POV as I've done it before. Bringing FLAC around though the surroundings are so noisy that unless i blast my music I can't hear the details. Until I had a duh moment while I was yet again swapping out the songs dus to storage constraints. |
#9 |
Suck my unit! Kirk lazarus (2008)
Check out audacity, also 128 is the lowest I would recommend to go, 256 is the lowest I would personally go, also use VBR
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk |
#10 |
I *am* a Dremel
Thanks for the suggestions and I'll just try them all out to see which is best.
the card is already 4gb up from 512mb and I only listen to music on it rarely so I don't really think it would be worth it. |
#11 |
How many song are you trying to fit on? I can get over 400 highest quality VBR's on to 4 GB and still have room to spare.
__________________
#12 |
Supermodder
At low bitrates, AAC generally gives the best quality. If you're listening on a phone, 128Kbps AAC is probably fine.
__________________
Lian Li PC A05NB - AMD 955BE@3.8GHz - XFX ATI HD5850 - 8GB DDR3@1333MHz - 2x1TB Spinpoint F3 - Corsair Force 3 120GB - Enermax Modu82+625W - Asus Xonar D2X - Dell 2408wfp (A02) - Filco Majestouch II Ninja (browns) - Mackie MR5 x2 |
#13 |
I *am* a Dremel
#14 |
Multimodder
VBR = variable bit rate.
#15 |
If it's only 200 or so you should have no problem, 320's aren't that much bigger than hq VBR's.
__________________
#16 |
What's a Dremel?
I also agree with the point mentioned by Dedar, as the source media file will be nice to go with instead of editing the copied one.
#17 | |
What's a Dremel?
#18 | |
Minimodder
To get there you can use iTunes. Change CD import settings to 128aac and then right click on the files in iTunes and choose "create aac version" If for some reason you don't want to use iTunes, a standalone, powerful (but slightly more complex to use) encoder is fre:ac. Free and open source and is properly multithereaded so its faster on good machines. (iTunes only uses 2 cores unless something has changed recently). You just need to select FAAC encoder and "configure selected encoder" to 64kbs per channel, max frequncey to 41100 (41.1khz), allow joint stereo, don't allow temporal noise shaping, and under format tab choose MP4 and LC. Enjoy
__________________
Main Rig | Antec P182 | Gigabyte GA-MA790FXT-UD5P | X4 965 @3.7GHz | Thermalright HR-02 | 2x HD5850 @775/4500Mhz | 8GB DDR3 | 256GB M4 | 2x 500GB RAID0 | 2x 2TB | 2x Dell 2408WFP | SteelSeries 6Gv2 & Sensei Raw DJing Machine | HP ProBook 6470b w/256GB M4 | Denon MC3000 | Kontrol F1 | MF3D |
| Tags |
| conversion, music, software |
| Thread Tools | |
