Reply
Thread Tools View Mode
Old 21st Mar 2012, 19:51   #1
s0lid
Dremel? Hacksaw!
s0lid's Avatar
s0lid has yet to learn the way of the Dremel
LanAmmoBox
First time this idea came to me when mini-itx Via Epias were the only brand on that segment and Athlon 64s something brand new. But now the situation is changed to better direction, mini-itx boards have became affordable with wide range of cpu sockets to choose from and most importantly proper slots for GFX card. Since local military goods shop (varusteleka) got these NATO .50cal ammoboxes in stock again I decided to throw together a compact and durable machine for Lan Partying.
--The plan/goal
-Fit lanbox into NATO .50cal Ammobox (id: 27.8x14.4x17.5cm LxWxD)
-Build a insert for the parts from 1.5mm steel sheet
-I/O will be facing up, since lid of the ammobox is easily removeable
-Not a single change to the Ammobox itself
--HW
-A8-3850
-Asrock A75M-ITX
-Powercolor HD7750
-8GB DDR3
-2TB 3.5" Samsung HDD
-2.5" SSD (tba)
-BQT 350W SFX psu the s0lid edition
-Noctua LH-N12 in single fan mode + 2-3 60x60x25mm fans
-Pci-e x16 flexriser
--Todo list@23.03.2012
-Cut 2-3mm extra from the bottom of insert -> fits deeper -> more space for i/o and face plate under the lid and the gasket.
-Bend face plates mounting flaps.
-Smoothen and paint the insert so it doesn't look like it has been forget with a hammer (which it is ).
-The face plate
--(Crappy) pictures
The box.
Results of Day #1, the insert pretty much cut into shape and most of the mounting holes are done. Everything is fixed to the steel with m3 self-clinching nuts (drill a hole, insert nut into it and apply ~2tons of pressure).
Hdd mount. Chopped lian li hdd tray and some angled aluminium.
Nothing extra ordinary here. Just testing that the board fits with the holes.
The psu. All the C(r)apxon capacitors have been replaced with proper NC KZE series caps exculding one tantalium cap and the mains capacitor (also NC but different series ofc). Cable shortening/removal inc...
Tomorrow will be fun, gotta do the bends. Which are highlighted with red in the following picture.
Those already installed S.C.Ns cause some consern and it's not really possible to install them after doing the bends (only got this big 20 ton hydraulic press -> flat sheet only).
Those little flaps with S.C.Ns are used for mounting the face plate which will hold the GFX card inplace, power connector, intake and exhaust fans, power button and i/o shield. The face plate itself will be made either from the very same steel or aluminium.
Reason why this is Scratch Build: There will not be any mods done to the ammobox itself which will simply be the outer shell and everything else is built from scratch.
__________________
Main rig: i7 3820 + 32GB DDR3 + Gigabyte X79-UD3 + HD7970 + HD6350 DMS59 + HX520 + 2x X25-E 32gig R0 + 2x 1.5TB.
ESXi cluster: 2x Dell C6100 XS23-TY3 nodes - 4x L5630 + 96GB ECC REG DDR3 + 2x Qlogic QLE2460 4Gbps FC
Solaris server: Intel L5630 + 24GB ECC REG + Supermicro X8DAH+-F + M1015 + Supermicro 826E1 + Supermicro 500W 80+ Plat + 8x 3TB Raidz2 + 2x 3TB Mirror + QLE2462 Dual 4Gbps FC + Solaris 11
s0lid is offline   Reply With Quote
Old 21st Mar 2012, 20:06   #2
fr0Zen
sabertooth 990FX
fr0Zen has yet to learn the way of the Dremelfr0Zen has yet to learn the way of the Dremel
i wan't one now! I've been thinking about all the awesome things you could do with ammo boxes.
mod on
__________________
http://forums.bit-tech.net/showthread.php?t=249950the big thing
fr0Zen is offline   Reply With Quote
Old 22nd Mar 2012, 14:21   #3
s0lid
Dremel? Hacksaw!
s0lid's Avatar
Small update.
Test fit after bends, the fit is tight... Too tight actually had to use small sledge and piece of wood to get insert in there.
Now i gotta get that outta there, some how and make it fit better :P
__________________
Old 22nd Mar 2012, 18:06   #4
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Um... If you had to take a hammer to it, it didn't really fit. -You made it fit.
I like ammo box rigs. I really like ammo box rigs that can still be waterproof.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 22nd Mar 2012, 19:29   #5
s0lid
Dremel? Hacksaw!
s0lid's Avatar
Spend 1-2 hours alone hammering the insert so it now slides in and out with ease without being too loose.
Yeah the case will be waterproof when lid is closed :P
Also new pic.
The bends look excatly that rough on every side atm
__________________
Old 23rd Mar 2012, 14:06   #6
s0lid
Dremel? Hacksaw!
s0lid's Avatar
Small update once again.
SSD mounts done.
Todo list: (goin to copy this to first post)
-Bend face plates flaps.
-The face plate
__________________
Old 23rd Mar 2012, 15:42   #7
novaris
Minimodder
novaris has yet to learn the way of the Dremel
bookmarked..
i had planned on doing this when i saw some old ammo boxes for sale but i was already working on another project.
novaris is offline   Reply With Quote
Old 23rd Mar 2012, 15:45   #8
spolsh
Supermodder
spolsh's Avatar
spolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyan
nice idea, hope it works out as planned.
spolsh is online now   Reply With Quote
Old 24th Mar 2012, 14:17   #9
s0lid
Dremel? Hacksaw!
s0lid's Avatar
Already chopped off 2mm from the bottom of the insert but looks like i can still take off another 2mm
At the moment insert fits to ammobox so that it's about 1.5mm below ammobox's edge.
Which is still too high because the gasket and how the lid is built.
the imprint from the edge is about 1mm deeper than rest of the gasket and when lid is closed the mechanism presses edge of ammobox about 2 mm into the gasket. So there's really like 171-172mm of space at the edges when the lid is closed.
Also minor problem. I gotta remove the cooler when I got to remove or install the board..
__________________
Old 24th Mar 2012, 17:53   #10
s0lid
Dremel? Hacksaw!
s0lid's Avatar
Moved the psu mounts 1 cm to the center.
Also forged that side a bit so the inserts fit is pretty much perfect.
The long side does not bend any more when put into place and the whole insert is easier to remove.
__________________
Old 24th Apr 2012, 12:12   #11
s0lid
Dremel? Hacksaw!
s0lid's Avatar
Month later... Updates!
The insert is pretty much cut into lowest possible shape. The gasket on lid does not hit the edges or i/o ports and there's maybe 0.5-1mm space between edge of mobo and bottom.
__________________
Old 24th Apr 2012, 17:35   #12
Cheapskate
Cheapskate's Avatar
You got me wondering if you can fit ITX/PSU/ssd in the next size down ammo box. It looks very doable.
__________________
Old 24th Apr 2012, 18:30   #13
Cown
Supermodder
Cown's Avatar
Cown has yet to learn the way of the Dremel
This is pretty awesome, looking forward to more
__________________
Finished Projects:
ROG Meets Lian Li - Picade - Mr. Wallmount - Milk on the Wall WIP: The Iron suit project
Facebook page:
Cownbuilds
Cown is offline   Reply With Quote
Old 24th Apr 2012, 18:31   #14
s0lid
Dremel? Hacksaw!
s0lid's Avatar
The 30. cal one?
I think that's too small for this, it's only 26x16.5x5.8cm LxHxW.
E: Did some digging as Varusteleka says the .30cal is 26x16.5x5.8 but elsewhere I found different size which is 28x19x8.9cm. That indeed is doable with ease
__________________
Old 9th May 2012, 16:29   #15
s0lid
Dremel? Hacksaw!
s0lid's Avatar
Started working on the front panel.
Fit is perfect but the lid won't close wanna quess why?
Shortest distance in the lid is 146mm, so is the shortest distance for the outside for the ammobox.
The edge is of that front panel is made to fit there when the lid was not closed. Now the distance at the middle of the ammobox is around 148mm.
Looks i gotta remove 1mm on the both sides of that front panel to get the lid to close
__________________
Old 10th May 2012, 16:49   #16
s0lid
Dremel? Hacksaw!
s0lid's Avatar
Small update: I/O plates hole is done
That is 1.5mm aluminium btw.
__________________
Old 11th May 2012, 18:03   #17
s0lid
Dremel? Hacksaw!
s0lid's Avatar
AC inlet and exhaust psu fan.
__________________
Old 22nd Jun 2012, 19:20   #18
s0lid
Dremel? Hacksaw!
s0lid's Avatar
Little over a month later, after moving out and being employed about 600kms away from every possible tool:
Re-take on the plate that'll will hold every possible fan and other thing; ac inlet, power button, gfx card (you'll see) etc.
Got still tomorrow to work on this. Next time will be be before assembly summer '12 so i can get this finished for the party
__________________
Old 23rd Jun 2012, 19:20   #19
s0lid
Dremel? Hacksaw!
s0lid's Avatar
Little update for today.
Did the gfx mounts, power_on button hole and psu rf/emi shield.
gfx mounts.
power button and little bit of psu rf/emi shield.
Inside shot from rf/emi shield. The shield is mounted from the sides with 4x m3 screws.
Next update will be in next month, as it's not cheap to travel 600kms and back :|
__________________
Old 23rd Jun 2012, 20:03   #20
warboy
Insane modder
warboy's Avatar
warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.
great idea! brilliant!
warboy is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
