Reply
Thread Tools View Mode
Old 26th Dec 2012, 10:23   #21
exexs
Multimodder
exexs's Avatar
exexs has yet to learn the way of the Dremel
Originally Posted by siliconfanatic View Post
im not doubting you here, but how would that make your pump run dry? ts actually about the placement of the pump in terms of above or below the res if im not mistaken. as long as theres water in it your good to go, after that? your right but not quite specific and general info always seems to confuse me in the weirdest, most backwards kind of way. my mind works really weirdly...
I was confuse too, in the sense that my pump is really at the bottom of the case, I could not figure out how can it run dry (except for really small bubles)
BTW, my Santa's gift is on his way (my 360 EK rad and some fitting for the gpu^^)
__________________
Support and comments for my FIRST worklog are appreciated: http://forums.bit-tech.net/showthread.php?t=228161
exexs is offline   Reply With Quote
Old 26th Dec 2012, 16:11   #22
siliconfanatic
Car lover and Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
if you absolutely must just put a valve and t-fitting on the pump for a filler-thingy. or use common sense and make sure the line leading to the pump inlet is BELOW the water line.
i may be lacking in common sense everywhere else(maybe that last shot of taquela WASNT a such a good idea *cough* FLOOR *cough*) but i have the utmost consideration and forethought when it comes to tech.
and really small bubbles can be caused by the pump having to pull against t much gravity, leading to cavitation. that can only be fixed by shortening the loop height and/or putting more pumps in series intervals/ key locations in the loop to reinforce the loop. that in and of itslef should be done anyway, imho, due to the added benefit of redundancy.
__________________
Originally Posted by quizz_kid View Post
Blackalize it!
I *am* the guy who loves too many threads to bump them all.
siliconfanatic is offline   Reply With Quote
Old 28th Dec 2012, 19:44   #23
exexs
Multimodder
exexs's Avatar
Thanks for that! That is exactly why I post my modd, to get more insight than what I have in store myself
But time for UPDATE
I just got my new GPU and the waterblock for it!
Did you guess for wich GPU is it??
The answer is...
... 660GTX !
__________________
Old 28th Dec 2012, 21:07   #24
exexs
Multimodder
exexs's Avatar
Update
I also cut the front of the case to integrate my 360 rad!
As you can see, it as damaged the painting, so I'll have to repaint the case (as I expected) even thaugh I used some painter tape to protect my cut.
I'll polish the cut and repaint the case! I'm also working on acrylic front (update soon)
If you guys have any tips to finish well my cut, let me know
__________________
Old 29th Dec 2012, 03:32   #25
siliconfanatic
sexy case frame is sexy
__________________
Blackalize it!
Old 30th Dec 2012, 16:20   #26
exexs
Multimodder
exexs's Avatar
Here some pictures of the GPU I got for my Xmas, from my girlfriend
BTW, she's edditing all my pictures (with photoshop), here is a link to her blog where she explains some stuff she does with photoshop and some drawing http://capicolor.wordpress.com/ (I do some advertising for her )
And...happy new year everyone!
__________________
Old 30th Dec 2012, 16:54   #27
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!
Nice GPU.
But I think there is one problem-that card has custom PCB and I am afraid that is not compatible with block. Have you checked that?
__________________
Cosmos S Reaper
L.R.E.C.
Scorpio - under construction
Arya-under construction
Pranja is online now   Reply With Quote
Old 31st Dec 2012, 00:44   #28
exexs
Multimodder
exexs's Avatar
On the EK website they say it is compatible! So yeah I've checked but not in practice yet.. Will try in a few days.. I hope the EK website says right.. XD
__________________
Old 31st Dec 2012, 06:59   #29
Pranja
Fenrir The Wolf
Pranja's Avatar
So,MSi just just extended the PCB leaving electronics the same as referent model?
Good,I didn't know that. Thx for info.
__________________
Cosmos S Reaper
L.R.E.C.
Old 31st Dec 2012, 11:10   #30
exexs
Multimodder
exexs's Avatar
When you look at the pcb, electronics is the same, and on the extended part you just have some condensators (and the rest of the extended pcb is empty) i think they did that mostly for the rad/fan system twinfrost. Which is pretty "big" for a modest gpu like the 660GTX! But again, I haven't try yet, I'll get you some pictures when putting the gpu under water
__________________
Old 2nd Jan 2013, 22:58   #31
exexs
Multimodder
exexs's Avatar
Hello!
Update time
Some pictures of me while cutting the front pannel! It's acrylic 5mm and I'm using a Dremel! (What's a dremel?) I had to cut some holes for the fixation of the front panel and for the fans (3x120mm)
I'm sanding down and polishing the panel and I'll show you the final result soon!
BONUS: my crazy face
__________________
Old 8th Jan 2013, 12:19   #32
exexs
Multimodder
exexs's Avatar
Hello!
Still cuting some panels myself!
For long, straight line cut, I used the jigsaw... and it's much better than a dremel!
As you can see, the cut is just near perfect (or at least, I'm really happy with it!)
I still have some panels to cut, and some stuff to do on the case, I'll show it to you later! And then, everything will be ready for painting again..
I'm also waiting my orders, with the holiday season (Xmas, New Year,..) the delivery is kinda slow...
__________________
Old 8th Jan 2013, 16:43   #33
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
Nice!
k.3nny is offline   Reply With Quote
Old 11th Jan 2013, 17:57   #34
exexs
Multimodder
exexs's Avatar
Originally Posted by k.3nny View Post
Nice!
Always here for optimistic support! love it x)
Small update
Front panel is done, and ready for the EK XTX360 x) (still waiting for it btw)
and the back of the case is ready for some 80mm fan!
I never understood why there is no fans in the bottom of the case! I know the heat is going up, but when you put your hand, you can feel the heat stuck because of the GPU. (of course you can put your PSU the other way around to extract the hot air but I prefer it to take air from outside)
So, I have always wanted a fan instead of the pci-e slots (which will never be used as I don't go multi GPU)
I'm glad my project is progressing, even if it is slow! And I know it's not as a big deal as almost everything else you can find on bit-tech, so many thanks for followers and comments!
and now.. ready for painting again! x)
__________________
Old 11th Jan 2013, 19:52   #35
WhatTheTech
Macmodder Addict
WhatTheTech has yet to learn the way of the Dremel
Looking great - I'm excited to see how this turns out!
Bon courage!
WhatTheTech is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
