Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 25th Mar 2012, 17:50   #1
Chatsicle
What's a Dremel?
Chatsicle's Avatar
Chatsicle has yet to learn the way of the Dremel
Give me Inspirational Ideas! :)
I have just finished modding my Antect P180 case, which in my opinion looks fairly good, I mean I went a bit heavy with the G3 compound on one of the panels
I have managed a mirror finish on that and the remaining ones apart from the slight primer showing through on one! . I've also added a window and cut the separating chamber out and replaced it with an acrylic version instead, with some skyrim shouts cut in with my trusty Plunge router attachment for the Dremel 4000 model. Looks pretty good. a think....
Any how, Here I am again and there's a case am looking at on Ebuyer made by Casecom which is cheap and really basic in appearance. I am really looking for some inspiration on what to do to it. By as crazy and imaginative as you want!! Honestly the more creative the better!
http://i1062.photobucket.com/albums/...omCaseside.jpg
http://i1062.photobucket.com/albums/...mCasefront.jpg
http://i1062.photobucket.com/albums/...omCaseBack.jpg
Chatsicle is offline   Reply With Quote
Old 27th Mar 2012, 23:32   #2
SuicideNeil
I'm insane, not stupid.
SuicideNeil's Avatar
SuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for president
Try this for inspiration:
http://www.bit-tech.net/modding/2012...se-mod-index/1
without knowing what kinda theme you are looking to do it's hard to offer up ideas- there are just too many things you could do, impossible to find a starting point.
Check out MDPC if you haven't already...
http://www.million-dollar-pc.com/
__________________
ASUS P8Z77-M PRO | INTEL CORE i5 2500K @ 4.3GHZ | EVGA GEFORCE GTX 670FTW | CORSAIR VENGENCE DDR3 1600MHZ 2x 4GB | SAMSUNG SPINPOINT F3 1TB | TITAN FENRIR | ACER PREDATOR | WIN 7PRO x64
SuicideNeil is online now   Reply With Quote
Reply
Tags
case, ideas, inspirational, modding
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
