#1 |
Administrator
bit-tech Staff
OCZ releases Vertex, Agility, Solid2 firmware update
OCZ has released the Arowana 3.55 update for its Vertex, Agility and Solid2 SSDs.
http://www.bit-tech.net/news/hardwar...id2-firmware/1 |
#2 |
Supermodder
What a ridiculous update. Some performance boost on some models but with a guaranteed loss of capacity? Just another reason to buy an M4.
__________________
Quote from Bungletron: And certainly if my house was burglarized I would phonerelize the police right away, what idiot would not? Bungletron, I salute you! |
#3 |
Hypermodder
Well, that's what over provisioning is: extra space in reserve on the disk to reduce write amplification.
In fact, if you did the same on an M4 it would speed it up too. What a ridiculous comment.
__________________
Intel Core i5 2500k @ 4.5GHz - Asus P8Z77-M - 4x4 GB Corsair XMS3 1.65v 1600mHz - Asus GTX 570 - 120GB OCZ Vertex 2 - Samsung F3 1TB - Samsung F1 1TB - Samsung F4 2TB - Corsair HX650 - Silverstone TJ08-E - LG IPS231P-BN x 2 |
#4 | |
Supermodder
Destructive Only applicable to a restricted number of a particular model Reduces the capacity on an already reduced capacity drive due to overprovisioning. Why don't they use 90% of the drive space for overprovisioning, and sell people a 256Gb SSD with 8Gb of free space? That'll be really fast! The M4 doesn't need overprovisioning to be fast. At least when you buy a 128Gb M4 you basically get 128Gb (near enough anyway). Also the updates are not destructive, they apply to all M4s and there is no reduction on your capcity to boot!
__________________
#5 | |
I *am* a Dremel
Edit: just read the article fully and that is actually rather a lot of over provisioning for not a lot of gain :/
#6 |
Minimodder
Bad update?
you lose about 5.3% of space and gain 28% sequential write speed! Doesn't sound like a bad deal to me - especially since I got my SSD because it's FAST, not big. |
#7 |
Supermodder
I suppose it all depends upon your point of view - with this type of drive, expecially with this update, there is quite a large reduction in capacity over the M4 et al (total space loss approx 17% of the drive for 128Gb), meaning that the realistic Gb per £ ratio is much reduced, and I don't believe the increase in speed averaged out across all situations is worth sacrificing all that capacity.
__________________
#8 |
Minimodder
well you've payed for your drive already, if you don't think the upgrade is a good idea then you don't have to use it. if you think it would be a good idea then great news, there it is!
seems like a not-lose, win situation to me. whats so bad about that? |
#9 |
Cool, this might apply to me.
__________________
Intel i7-3820 @ 4.65GHz | GeForce GTX 480 | 4x4GB Vengeance | Asus Sabertooth X79
Silverstone TJ07 | OCZ 1000W | Samsung 830 256GB | CM QF Pro w/Browns | CM Xornet |
#10 |
Minimodder
PS: you can get the same random write performance boost by formatting your drive with this: http://en.wikipedia.org/wiki/HDDerase
It resets all flash cells so they don't have to be erased before a write operation (making random write slow at times - slowing your SSD significantly over time, even with TRIM enabled). |
| Thread Tools | |
