#1 |
Minimodder
"CNPC" - Cheap PC and CNC components all in one case
Hello, This is first time i'm post in this forums. Any comments , recommend are welcome.
Project description :: This case build for put CNC component and PC components together. Why i need to put everything together? - 1 year ago i design and build my own CNC machine but the electronic components didn't have enclosure yet and after finished build machine my old PC was dead so need to brought new one, so i need to put it in same case together. OK, for my CNC build log you can see it in my blog here "iD2CNC Newbie guide to build CNC with less tools , newbie experience to newbie" but first post will not have English, but for English detail can found it here "CNCZone" PC Hardware components :: - MB - Asus M5A78L-MLX - CPU - AMD ATHLON II X2 250 - Ram - Kingston 2Gb x 2 DDR3 1066 - HD1 - OCZ Agility 60GB (Second hand) - HD2 - Western Green SATAII 500GB (Second hand) - VGA - HIS 6670 1GB DDR5 (Second hand) - PSU - RaidMax RS530 530watt - Monitor - Sharp 17" LCD (Second hand) - CDROM - Asus (Second hand) CNC Electronic components :: - 3x Stepper motor driver JMC M542 - 3x Terminal Block - 1x DB25 BreakOut Board - 6x 8mm 12v Fan - 1x Switching PSU 24v 15A - 1x Switching PSU 12v 5A - 1x Switching PSU 5v 5A - 6x Fuse block - 1x VFD Spindle Inverter etc,. Case dimension :: - Case size 60 x 40 x20cm Case material :: - Frame use aluminium profile 20x20mm - Acrylic 6mm Case feature :: - 3x input AC 220v - CNC and PC component in case - Not much huge case - No additional led light , use only from PSU itself etc,. Sponsor :: N/A Notes :: I'm not good in English , so if i make you confuse or i use wrong word or any mistake , please help me to make it right. First time Scratch :: ![]() this scratch was not complete , it not finish in detail and position of components Second time scratch :: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() In Color detail :: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Acrylic drill and tap position :: ![]() ![]() ![]() Start cutting aluminium profile :: ![]() ![]() ![]() ![]() ![]() Cutting acrylic for PC black side panel :: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Spray paint :: ![]() ![]() ![]() ![]() ![]() ![]() Other acrylic components :: ![]() ![]() ![]() ![]() CNC DB25 BreakOut Board mounting :: ![]() ![]() ![]() ![]() ![]() ![]()
#2 |
Multimodder
hi iD2
What is the surface work of your cnc? How thickness is the acrylic do you use in the mod? Thanks and good luck
__________________
"Raikkenstein Mod" http://forums.bit-tech.net/showthread.php?t=215645 MOTM January 2012 Winner |
#3 |
Multimodder
Mate what can i say, o followed your CNC project by your blog and the only thing i can say is that your work is inspiring... Hope to see more from you soon.
#4 | ||
Minimodder
My table top of CNC using aluminium profile and working area of my CNC machine 64cm x 55cm x 15cm (X,Y,Z axis). For acrylic , i use 6mm because it fit to slot of aluminium profile. ![]() Quote:
#5 | ||
Minimodder
- My table top of CNC using aluminium profile and working area of my machine 64 x 55 x 15 cm (X , Y , Z Axis) ![]() Quote:
#6 |
The Keeper of History
I watch
john
__________________
My deepest gratitude to this community.
#7 |
Minimodder
OK, This's my PC and CNC electronic components right now. All of this components will put it in together.
#8 |
Multimodder
Looking forward to this one
__________________
i7 2600k @4.42GHz, | Asus Maximus IV Gene-z | 8GB G.Skill Ripjaws CL9 | GTX 570 @ 803/2002 | 128GB Crucial M4 SSD | Coolermaster RP Pro 1000w | Lian Li PC70 | Onkyo SR608 amp | Mordaunt Short components | |
#9 |
Shut up and Mod
Me too.
__________________
Life. Liberty. The pursuit of those who oppose it.![]() Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide @furballzen |
#11 | |
Just a Clumsy Ape
iD2 nice to see you here too! been looking at your logs at cnczone... very nice build indeed. building a CRP2448 myself. perhaps later, you can give me some pointers on spindles... |
#12 |
Minimodder
Hello, everyone for anyone i reply you late , i'm apologize for that because this my first thread and first post here so my post still less than 10 and it will not display until moderator approve my post first.
#13 |
↓ Don't trust that face!
Nice rig. -Both the mill and the future control box.
__________________
#14 |
Bought time you noticed CNC and showed up Cheaps. This is NICE,
![]() john
__________________
#15 | ||
Minimodder
#16 | |
Minimodder
#18 |
What's a Dremel?
Nice to see my first SU model used in this thread... It's the SSD... Did you download it from http://scc.jezmckean.com ?
Anyway - awesome project... Building the CNC also... |
#19 | |
Minimodder
Thank you. |
#20 |
Minimodder
Today i went to shopping and some part just finish but not much thing i can do, a little update.
Shopping part and components :: ![]() ![]() Then i just resolve my hole of PSU on right top , it not fit when test it need 1mm left , so i need to fix it and just finish design my PC card slot cover. Redesign and fix some cosmetic issued :: ![]() ![]() ![]() ![]() ![]() ![]() And just do some aluminium PC card mounting it not finish yet , still need to measure position of card and then drill and tap. Aluminium PC Card mounting :: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And just finish spray paint acrylic custom fan grill , this fan grill i already finish about 2 week ago. This fan grill use for 80mm fan. Fan grill 80x160mm :: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And other foot of fan grill to mount with bottom acrylic case. Other components :: ![]() This's aluminium for SSD mounting and Switching PSU mounting , it need to spray paint but didn't do it yet. Aluminium for SSD mounting and Switching PSU mounting :: ![]() Everything update it will update on my blog too iD2 ![]()
| Thread Tools | |
| View Mode | |
