Reply
Thread Tools View Mode
Old 3rd Apr 2012, 16:19   #21
iD2
Minimodder
iD2's Avatar
iD2 has yet to learn the way of the Dremel
Update PC Card Slot Cover
A little update with PC Card Slot Cover.
iD2 is offline   Reply With Quote
Old 11th Apr 2012, 16:59   #22
iD2
Minimodder
iD2's Avatar
Back to my work, try to test assembly case to prove that everything fit together but still need to drill and tap top panel and right panel i think i’ll finish top and right panel soon.
Test assembly
Top and Right panel design
Old 12th Apr 2012, 12:01   #23
Phyonics
Modder
Phyonics has yet to learn the way of the Dremel
Looking good
Phyonics is offline   Reply With Quote
Old 12th Apr 2012, 13:01   #24
iD2
Minimodder
iD2's Avatar
Originally Posted by Phyonics View Post
Looking good
Thank you
Old 12th Apr 2012, 14:23   #25
exexs
Multimodder
exexs's Avatar
exexs has yet to learn the way of the Dremel
Wooo.. good acrylic job! Fits perfectly
__________________
Support and comments for my FIRST worklog are appreciated: http://forums.bit-tech.net/showthread.php?t=228161
exexs is offline   Reply With Quote
Old 12th Apr 2012, 15:45   #26
p0Pe
gief cake?
p0Pe's Avatar
p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!
So let me get this straight, you build your own CNC, and am now making a machine with the machine you build?
Mod-ception! And i love it
Keep up the good work!
__________________
p0Pe is offline   Reply With Quote
Old 12th Apr 2012, 16:36   #27
iD2
Minimodder
iD2's Avatar
Thank you
Old 12th Apr 2012, 17:36   #28
iD2
Minimodder
iD2's Avatar
Just finish cutting right panel and finish drill ,taps top panel and next step i’ll do spray paint.
Right Panel Work
Top and Right panel
Note :: For anyone want to see images of my cnc build log (include cnpc case build) you can see it here Photo gallery
*** Warning image over 550+ images***
Old 12th Apr 2012, 17:52   #29
Baguette
Multimodder
Baguette has yet to learn the way of the Dremel
Now THAT is clean precise work...that's sizing up nicely
Baguette is offline   Reply With Quote
Old 12th Apr 2012, 18:43   #30
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.
Lovely work.
I have to say that using 'cheap' in the title is misleading. Nothing I've seen here is cheap. Everything is top-notch.
Cheapskate is offline   Reply With Quote
Old 12th Apr 2012, 19:05   #31
iD2
Minimodder
iD2's Avatar
Thank you.
Originally Posted by Cheapskate View Post
Lovely work.
Thank you For 'cheap' it's about my pc part and component most of them was second hand parts and hardware for build this case (aluminium profile and acrylic) was cheap than brought aluminium case and mod that aluminium case , actually i need to build extreme pc case with high-end part and using water cooling system too but most of my money just spend to build my cnc.
XD
Old 12th Apr 2012, 20:31   #32
Samrobmoe
Minimodder
Samrobmoe's Avatar
Samrobmoe has yet to learn the way of the Dremel
I love the precision engineering in this project, something I only wish I could achieve...
Good work!
Samrobmoe is offline   Reply With Quote
Old 14th Apr 2012, 15:32   #33
iD2
Minimodder
iD2's Avatar
Good work!
Thank you
Old 14th Apr 2012, 15:43   #34
iD2
Minimodder
iD2's Avatar
Finish right and top panel and some other update !!
I'm just finish right and top panel . Not much description because i'm not good in English but this image will describe what i'm done and what i'm working.
Right and Top panel and Other work
Old 16th Apr 2012, 14:30   #35
Phyonics
Modder
Looking really good!
Old 19th Apr 2012, 17:32   #36
iD2
Minimodder
iD2's Avatar
Thank you
Old 19th Apr 2012, 21:13   #37
SuicideNeil
I'm insane, not stupid.
SuicideNeil's Avatar
SuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpit
__________________
ASUS P8Z77-M PRO | INTEL CORE i5 2500K @ 4.3GHZ | EVGA GEFORCE GTX 670FTW | CORSAIR VENGENCE DDR3 1600MHZ 2x 4GB | SAMSUNG SPINPOINT F3 1TB | TITAN FENRIR | ACER PREDATOR | WIN 7PRO x64
SuicideNeil is offline   Reply With Quote
Old 19th Apr 2012, 21:44   #38
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
Yup, just creamed my pants
thanks a lot
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 19th Apr 2012, 22:03   #39
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for president
GJ. Looks nice.
Pranja is online now   Reply With Quote
Old 20th Apr 2012, 07:55   #40
rak500
Multimodder
rak500's Avatar
rak500 has yet to learn the way of the Dremel
Can't wait to see it all build up, Awesome build!
rak500 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
