#41 |
Minimodder
Thank you
#42 |
Minimodder
Update, Assembly PC and extend 4pin PSU wire
Just assembly PC and have some problem with 4pin wire to connect motherboard , it too short and i need to extend it about 20- 30cm.
![]() ![]() ![]() ![]() After finish extend 4pin wire , than test open PC to make sure it still work. ![]() ![]() ![]() Put CNC Component to case ![]() ![]() ![]() ![]() ![]() Left panel
#43 |
Minimodder
OK, Start to wiring and put some stuff to case.
#44 |
still thinking....
Nice work mate, I read your worklog on CNC zone. Fantastic work!
__________________
stillthinking |
#45 |
Multimodder
There are some times, if you really want something. So it does not realy matter for him/her they just do it. And when its redy, looks absolutly sunning. Even if it is made in the bedroom.
So what ever you are doing dont give up. I realy like your cnc. |
#46 | ||
Minimodder
, Building CNC in bedroom there were a lot of problem but big problem was noise when drilling but everything was done . Now i concern if one day i need to move out from this condominium that mean i need to disassembly my CNC it'll big job too.Quote:
![]() (sorry for my English , if any words was not correct please tell me) |
#47 |
Minimodder
80% Finish Wiring
Still working with wiring everything together
80% Finish wiring ![]() ![]() ![]() ![]() ![]() ![]() ![]() My case vs Standard case ![]() ![]() ![]() ![]() ![]() Next job ![]() ![]() This my next job to use this resistor to reduce 12v to 8v , to make fan quiet. Actually i need to use PC Fan Control it can adjust voltage but it expensive so i decide to invest with this resistor it very cheap. |
#48 |
Minimodder
Just back to work !!! Sorry for nothing update for long time , my routine work very busy . I don't have much time to work so this a little update and need to finish my case soon.
Case Handle ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() will be back soon....
#49 |
The modding head is firmly back on.
Now everything about this project is just seriously cool !
#50 |
Minimodder
If you want to run the fans slower but not at 5V you can skip the big resistors and just connect between the +5V live and the +12V line of your pc PSU this gives you 7V for the fan.
__________________
If you're not living on the edge you're taking up too much space.. |
#51 |
Minimodder
As Sulu once shouted, Shields !!!.
You may also want to consider a solid or mesh metal cover for the PC motherboard as the CNC equipment can be very electrically noisy.
__________________
#52 | ||
Minimodder
Thank you
![]() Quote:
thank you for your advice ,i'll design cover plate for my motherboard by using acrylic ,it look like asus sabertooth but i'll do it after everything finish.
__________________
My CNC and Case build :: https://idea2reallife.wordpress.com |
#53 |
Dremel?
Your attention to detail is astonishing as is the craftsmanship!
Top stuff, await your next update! Thanks. |
#54 |
Minimodder
Hello, Long time nothing update because i need to work out of my office and my PC was dead stil waiting for RMA but can't wait anymore , so i decide to sell my pc component and bought new one.
New Spec :: CPU --> AMD A6-3670K Motherboard --> ECS A75F-M2 Ram --> Old Ram (2x Kingston bus 1333) PSU --> (This part was dead , still waiting form RMA) , New RaidMax 730Watt OK, Just back to work not much update but need to update my new PC and something i already done. Foot base ![]() ![]() Custom chip heatsink ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
__________________
#55 |
Minimodder
Long time nothing update on this forums , Now big update. Let's see.
Foot base ![]() ![]() Led light ![]() ![]() ![]() Side Panel ![]() Put spindle inverter to case ![]() ![]() Side panel when connect wire component ![]() ![]() Font right panel ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
__________________
#56 |
Multimodder
This looks very simpel but jet very cool
. The wiering shold be littel better but i understand if there is any problem u wanna acsess fast but sill i lke it very much
#57 | |
Minimodder
__________________
#59 |
Minimodder
Just finish my Left font side panel , not much anything to describe just see picture.
Aluminum for hold acrylic ![]() ![]() ![]() Put it in Case ![]() ![]() ![]() ![]() Start cutting acrylic for font left panel ![]() ![]() ![]() ![]() ![]() Finish cutting and put it in ![]() ![]()
__________________
#60 |
Minimodder
Thank you
__________________
| Thread Tools | |
| View Mode | |
