Reply
Thread Tools View Mode
Old 15th Apr 2012, 04:23   #21
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
I do love a good WC'd SFF build
Mankz is offline   Reply With Quote
Old 15th Apr 2012, 11:13   #22
kelmannen
Supermodder
kelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremel
like like =) is the holes placed so it'll go directly to the gpu with pipes and not hose? water cpu-(rad/pump-)floor-gpu-floor-(rad/pump-)cpu?
or am i way of? im following... =)
__________________
Works as a tool retailer, glad if i can help someone with tool questions!
Hopes that i someday completes my first scratchbuild...
kelmannen is offline   Reply With Quote
Old 15th Apr 2012, 13:25   #23
Mr.Evil
Minimodder
Mr.Evil has yet to learn the way of the Dremel
Though usually I don't like water cooled pc, your project is simply amazing !
I really like the black and white theme with a touch of red, then, I love ITX size ...
Mr.Evil is offline   Reply With Quote
Old 23rd Apr 2012, 03:40   #24
Laine
This and that
Laine has yet to learn the way of the Dremel
Who doesn't?
You got that right, but the order is res-pump-floor-gpu-floor-floor-120rad-cpu-140rad-floor-res.
Thanks!
Thank you!
Part V
I'm back after a short break, let's continue!
Fitting of the midplate and the GPU together, the midplate is a bit off centre by the GPU's unsupported weight, making the crystal link a bit tilted.
The GPU block had its first encounter with the dremel, still a long way to go for a perfect fit.
See you guys soon!
__________________
Current Bit-Tech project log: [Inet 001 - Codename Mono]
[Curreal] - [Simplicity] - [Purple Haze] - [Red Wine] - [Malay] - [Nano]
Laine is online now   Reply With Quote
Old 23rd Apr 2012, 06:42   #25
B.o.B
Minimodder
B.o.B has yet to learn the way of the Dremel
Very stylish and clean build so far. I love seeing these kinds of builds in a small case!
sub'd
B.o.B is offline   Reply With Quote
Old 23rd Apr 2012, 06:53   #26
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
This is just, amazing! Love every aspect of it!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 23rd Apr 2012, 07:24   #27
Kranik
What's a Dremel?
Kranik has yet to learn the way of the Dremel
This is a fantastic project. Great inspiration for someone that wants to make a m-ITX water cooling build after a build in a Phantom! It's perfect!
Kranik is offline   Reply With Quote
Old 23rd Apr 2012, 09:28   #28
rak500
Multimodder
rak500's Avatar
rak500 has yet to learn the way of the Dremel
That is a very tight fit! I really like the midplate idea!
rak500 is offline   Reply With Quote
Old 24th Apr 2012, 18:06   #29
SkyThread
What's a Dremel?
SkyThread has yet to learn the way of the Dremel
Looks very good, but I'm wondering if you will get enough cooling for it.
SkyThread is offline   Reply With Quote
Old 8th Sep 2012, 15:23   #30
AT0MAC
Mac Mod'er
AT0MAC's Avatar
AT0MAC has yet to learn the way of the Dremel
Maybe you can help me, I wonder what the height is of the case without the feet on? I want to buy this and place it under my TV were I only have a height of 30cm
AT0MAC is offline   Reply With Quote
Old 8th Sep 2012, 19:31   #31
Fonne
Multimodder
Fonne has yet to learn the way of the Dremel
That rad + fan combo looks amazing ... A shame they dont really got any static pressure, but the look is soooooo nice
Fonne is offline   Reply With Quote
Old 25th Jan 2013, 00:34   #32
Laine
This and that
sub'd
Thank you for the sub! :-)
Thank you, sir!
It's been a long time now, did you get around to making it? Cheers! :-)
Thank you!
To be honest, I don't know. I think it comes down to the overclocking. I did some calculations and it seems to work out, I had another set of eyes on it and he agreed but I really don't know until it's up an running.
Sorry for the really late answer, but the height is 31,5 cm.
Hopefully I can get enough out of it, but we'll see!
Part VI
It's been a loooong time since I last stepped into this thread, that plus a midset break or what ever you would wan't to call it, for school I'm back to finish what I've started.
As she sits!
[/IMG]
Here's where I will put a 20mm fan.
Or a fillport!
Got myself a pair of wedding rings for that sweetheart.
Flush!
Kind of tight, hopefully it will do.
Halfway finished with the front radiator mount.
SSD-holder with two yummy GT-disks.
Threw the radiator on there, starting to look like something.
Again, starting to look right!
The rear, lots of work to do here still.
It's not as bad as it looks to be, one set of wires are not yet sleeved, and the others need a good stretch, but it will look better once the PSU-shroud is on.
Test mounting!
What do we think?
No longer a 460!
Lowered the entire reservoir about 5mm, through the floor.
Hopefully I'll be back really soon to update you guys on progress.
__________________
Old 25th Jan 2013, 00:41   #33
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
Let's talk about tight spacing between components
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is offline   Reply With Quote
Old 25th Jan 2013, 01:20   #34
Sissilisko
Multimodder
Sissilisko has yet to learn the way of the Dremel
Im in love... with you're case.... and you're skills that is THE most tightest **** ive ever seen please, show me more... sensei.
__________________
Finished:
-Mini-PC http://forums.bit-tech.net/showthread.php?t=248203
unfinished:
none!
Sissilisko is offline   Reply With Quote
Old 25th Jan 2013, 01:30   #35
Laine
This and that
Typing this with only one hand, kind of got the other one stuck. :-D
Wow, thank you so much!
Just because you two are so kind and welcoming, you get another one!
Part VII
I got an Aquaero as some sort of "main central" of all the mechanical components. But it doesn't fit! Just 1mm to tall, shouldn't be a hard fix though.
Also mounted a water temperature gauge/reader to utilize more of the Aquaero. Since last time the rad support in the front was painted, pump wire lengthened, the fan wires resoldered and shortened, as well as shortening the probe wires and USB. Don't worry, all connectors will be painted.
Oh, and I also made some splitters for the molex lines, and finished off the sata-power. It still needs some fine tuning though, as you can tell.
__________________
Old 25th Jan 2013, 14:14   #36
Furball Zen
Shut up and Mod
Furball Zen's Avatar
Furball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run Crysis
Coming along nicely
__________________
Life. Liberty. The pursuit of those who oppose it.
Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide
@furballzen
Furball Zen is offline   Reply With Quote
Old 25th Jan 2013, 14:52   #37
Parge
Do you even mod, bro?
Parge's Avatar
Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.
I'm not sure what I like better, the mod or the photography!
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG
Parge is offline   Reply With Quote
Old 25th Jan 2013, 15:08   #38
Mankz
dat steak
Mankz's Avatar
A cracking little project, thats for sure.
Old 26th Jan 2013, 03:48   #39
craig - toyoracer
Supermodder
craig - toyoracer's Avatar
craig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremel
Great to see this back in progress mode
It's all in the details and you have soooooo many
__________________
octTower
craig - toyoracer is offline   Reply With Quote
Old 1st Feb 2013, 11:08   #40
Laine
This and that
Originally Posted by Furball Zen View Post
Coming along nicely
I'm glad you like it, Zen!
I'm not sure I want to know! Haha! :-D
Thank you, Mankz!
It's nice to be back. It's hard to get it the way I want to, and it's so time consuming because of the space, or rather the lack of it. Thank you as always, Craig!
Part VIII
Windowtime! Also got working a bit more on the two-tone paint.
Marked areas will need some love.
And some nicer shots, because I finally found some time for it.
It came out pretty good in my opinion.
Now I'm off to work some more on this! Until next time, thank you for following. :-)
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
