Reply
Thread Tools View Mode
Old 10th Apr 2012, 13:48   #41
abezors
Lurking since '08
abezors's Avatar
abezors has yet to learn the way of the Dremel
Enjoyed this speedy mod. Glad no rebel scum decided to blow it up at the LAN!
So.. when's the Death Star II mod coming? (then you really will need a new office)
abezors is offline   Reply With Quote
Old 10th Apr 2012, 16:56   #42
IanW
Grumpy Old Git
IanW's Avatar
IanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpit
I just realised what's missing from this mod:-
A Snowspeeder shaped mouse - wired of course!
__________________
i5 2500K@3.3GHz / Corsair H50-1 / Asus P8P67-M PRO / 16GB Corsair Vengeance / MSI GTX670 / 240GB Samsung 840 /
1TB HDD / Silverstone 600W / Silverstone SG-09 / Dell U2713HM / CM Storm Quickfire TK / Logitech G9 / Win7-64 Ultimate / Ubuntu 13.04-64
IanW is offline   Reply With Quote
Old 11th Apr 2012, 06:27   #43
ASPHIAX
Beyond Complexity Lies Simplicity
ASPHIAX's Avatar
ASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the Dremel
LOL, Its not completely done yet and I have 7 buildupdates and video's to share , will be adding as I fo=ind time to structure the images. I have already been asked to and I would love to build the deathstar! Only drilling 20 to 30.000 holes for the lighting will get tiresome quick and cost a lot of time I think!
Yes blue is what is missing !
LOL, you read my mind! I am already looking for one on ebay!
And a matching screen! So much more plans !
__________________
Current Build : BORG COSMOS II
Current build : 2001 - A Case Modyssey
Finished build : IMPERIAL AT-AT
Finished Build : USS EURISKO - Intrepid Mark II Class
www.asphiax.wordpress.com
ASPHIAX is offline   Reply With Quote
Old 11th Apr 2012, 08:26   #44
ASPHIAX
ASPHIAX's Avatar
Hi all, here is another update of the work that I had to do for the AT-AT!
With the hood removed I could start thinking on how I would mount (and cover the non attractive parts) of the hardware!
Had to cut out the middle section of the models interior baseplate without messing to much with the fixation points that provided its structural strength.
Cut away to much and it would not be capable of supporting the hardware.
Replaced the frosted plexi with a piece of UV red I had laying around. This will fit better into the overall lighting scheme.
Playing around with the location of the pump !
This looks like an easy job but actually took a couple of hours getting it to fit exactly with no luight from the interior shing through on the sides, the hood needed to to fit perfectly and the pump had to be taken apart to fit into the hole in the vertical piece of plexi. Must have done 50 test fittings in total.
One of the main design criteria was that it had to look original from the outside, so the pump had to be well inside the model for the backdoor to close. (unfortunately this also meant my GTX580 was 2 cm to long)
This was the original idea, the hardware on that location was soon changed to the I/O plate!
Well that was it for now !
Next update will have my first ever build video (let me know what you think!)
Laters
__________________
Old 12th Apr 2012, 07:21   #45
ASPHIAX
ASPHIAX's Avatar
Started work on all the cabling that had to be extended through the legs and into the body for the pc hardware. The 2x240 radiators and PSU will come in the base.
Had to cut out a lot of plastic to be able to route all the cables through. But I had to do that again without compromising the structural integrity of the model asa AT-AT that continuously drop to its knees wont destroy any rebel bases soon!
Also had to route 2 x 3/8th Tygon tubing to and from the rads into the legs. This was a very tricky point. I do have some restriction in my loop now, but the cooling works beautifully!
When all the wiring was done, I had to trace them all to be sure I wouldnt connect any of them incorrectly!
All the cabling installed! What did I install in total:
2 X 6 Wire GPU Pwr
4 + 4 Wire Mobo Pwr
24 Wire ATX Connector
4 Wire Molex
HDMI
USB2.0
CAT5e
2 x 3/8th Tubing
Continued ---
__________________
Old 12th Apr 2012, 07:21   #46
ASPHIAX
ASPHIAX's Avatar
--- Continued
Also installed a little fan, its all watercooled (except for the RAM) But having some airflow is never a bad thing!
The connection to the base. This way it can move around the base a little but is still firmly attached (this is actually one of the first thing I will change; get a full modular psu)
AT-AT Chainsaw Massacre --- There's legs everywhere !!
Anyone got a wiring scheme???
Luckely I had some tiny helper hands for them hard to reach places!
That was it for this update !
Laters!
__________________
Old 12th Apr 2012, 10:36   #47
ASPHIAX
ASPHIAX's Avatar
I would REALLY like to know what you guys think of this!
Is this something you would like to see more ?
__________________
Old 15th Apr 2012, 18:26   #48
ASPHIAX
ASPHIAX's Avatar
Started work on the reservoir that needed to be placed between the legs !
Heavily modified the clamp to made it fit perfectly when the I/O hood was placed.
It was really removing a mm at a time to make it fit perfectly !
Fits perfectly into the design of the AT-AT's underbelly IMO !
Cutting away all the places where ther res needed to go, left me with a large hole through which light could escape! This hasd to be fixed !
Fixed!
I modded a 10 cm ccfl to fit inside the reservoir !
Just need to make a resistor setup to be able to control the amount of light emitted by the CCFL. This is just too strong ! I had to cover the whole inside of the body with alu tape to prevent light from shining through!
That was it for this update!
The video will follow soon!
__________________
Old 16th Apr 2012, 14:24   #49
andyb123
Minimodder
andyb123 has yet to learn the way of the Dremel
haha, this is brilliant, well done
andyb123 is offline   Reply With Quote
Old 16th Apr 2012, 15:11   #50
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
I was enjoying this project until I found you were using child labor!
Actually I'm worried about you having the pump above the reservoir.
Cheapskate is offline   Reply With Quote
Old 16th Apr 2012, 17:48   #51
ASPHIAX
ASPHIAX's Avatar
Thanks man!
LOL, if she cant look inside my office or modding room at least once a day, she'll be crying untill she does! Cant keep her away from the EURISKO or the AT-AT.
What has you worried about the res cheaps?
__________________
Old 17th Apr 2012, 12:30   #52
Timmynator
What's a Dremel?
Timmynator has yet to learn the way of the Dremel
As a long-time Star Wars fan I'll subcribe to this project.
Also, I'd highly recommend to anyone the "official" conclusion of the movies by Timothy Zahn, the Thrawn Trilogy as well as the Hand of Thrawn Duology. The books, mind you...
Timmynator is offline   Reply With Quote
Old 17th Apr 2012, 15:27   #53
k4p84
Modder
k4p84 has yet to learn the way of the Dremel
Hey
Cheaps is referring to the general rule that the res or t-line should be above the pump so that the pump does not ' run dry ' during low coolant situations, eg filling the loop.
I love the build, keep it up.
Ed
k4p84 is offline   Reply With Quote
Old 17th Apr 2012, 16:02   #54
Cheapskate
Cheapskate's Avatar
I'm guessing you found a way to get the lines bled before you cranked it up, though.
The odds are good you will know about a leak early too. The rig won't look housebroken.
Looking back. I think pointing the pump outlet down is a no-no too. I forget...
Old 17th Apr 2012, 18:01   #55
ASPHIAX
ASPHIAX's Avatar
Originally Posted by k4p84 View Post
Hey
Ed
Aha, yes! Thanks !
What I did is put the fillport 5 cm before the inlet of the pump.
That way the pump didnt run dry!
Actually I did fry a motherboard and CPU with this build. But that was because there was some coolant trapped in the 12v (vertical connector) when I put the build horizontal it ran out and shorted the whole thing. BAD LUCK !!
__________________
Old 18th Apr 2012, 12:53   #56
ASPHIAX
ASPHIAX's Avatar
Here is the second build video !
New update soon !
__________________
Old 18th Apr 2012, 12:57   #57
Lance
I ate Bhindi Bhaji.
Lance's Avatar
Lance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on you
Oh cool! This is looking more and more interesting.
__________________
Originally Posted by mrMonkeyChunks View Post
All hail lance, the lord of interior design.
Lance is online now   Reply With Quote
Old 18th Apr 2012, 13:06   #58
Parge
Do you even mod, bro?
Parge's Avatar
Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.
Its Aaaamazing! That is all.
(oh and also, I wish I'd had this idea, and then was blessed by the talent, tools and time to pull it off)
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG
Parge is online now   Reply With Quote
Old 18th Apr 2012, 23:29   #59
Baeowolf
What's a Dremel?
Baeowolf has yet to learn the way of the Dremel
Oh wow!! Your going like 100 times more into this then I did!!
Awesome job so far!!
Baeowolf is offline   Reply With Quote
Old 19th Apr 2012, 06:42   #60
ASPHIAX
ASPHIAX's Avatar
Thanks man !
Have you seen the PM?
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
