Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 2nd Apr 2012, 11:02   #1
Moleo
What's a Dremel?
Moleo has yet to learn the way of the Dremel
Coolermaster GX RS650 to replace Antec TP 650?
Is that an appropriate swap?
Moleo is offline   Reply With Quote
Old 2nd Apr 2012, 12:54   #2
MrTeal
Multimodder
MrTeal has yet to learn the way of the DremelMrTeal has yet to learn the way of the Dremel
Depends which one it is as there are two versions of the GX 650W.
The first, original one was built by Seventeam and has the model number RS-650-ACAA-E3. This (and other members of the original series) were discontinued because of very negative reviews.
The second one was built by Enhance and has the model number RS-650-ACAA-D3. It is more commonly referred to as the GX Bronze.
Review for the Seventeam built one:
http://hardocp.com/article/2010/11/2...supply_review/
So that one should be avoided.
Reviews for the Enhance built one:
http://www.techpowerup.com/reviews/C...GX650W_Bronze/
http://www.kitguru.net/components/po...supply-review/
So it is better, but I'm still not a fan of the GX series. So I would recommend getting something else.
MrTeal is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
