Old 3rd Apr 2012, 09:28   #1
Cygnitr0n
Minimodder
Cygnitr0n's Avatar
Cygnitr0n has yet to learn the way of the Dremel
Obsidian Carnage
Hello Readers from the Bit-Tech Forum,
I'm building a new system for myself with the new Asus Maximus IV Gene-Z, the Obsidian Carnage.
My name is Stef (eng: Steve) and I'm from Holland and living in a town called Enschede.
It will be a Game-PC with a fat OC tuning! I didn't want a big tower so I looked arround for a mid tower. With this mATX motherboard, a Big Tower will lose the effect on a little motherboard. And there will be to much space. Space I don't want or need. So that why I bought the Corsair 650D.
I wanted a nice Case with fine lines in it. No "tierelantijnen" so as we call it in dutch. Corsair Obsidian 650D.
This build has no known plan, and I am still figuring out what to tho with this 650D. So I will update every once a while. I'm not gonna bother you anymore with lame text. See for yourself.
PC Hardeware:
Intel Core i5 2500K
ASUS Maximus IV Gene-Z
EVGA GTX560Ti FPB (2x)
Corsair Dominator DDR3-1600 CL9 16Gb
OCZ Vertex 2 Extended 60GB
Samsung Spinpoint F3 1TB (2x)
Lite-On iHBS112-37
Corsair AX850 Watt
Cooling Materials:
EK-WB HF Acetal
EK-MOSFET Max IV Gene - Acetal+EN Nickel
EK-RAM Dominator X4 - Acetal + EN Nickel
EK-TUBE 250 Advanced
EK-CoolStream RAD XT 120
EK-CoolStream RAD XT 240
EK-FC560 GTX - Acetal + Nickel -EN- V2
KOOLANCE PMP-450 D5
Bitspower D5 Modkit
Bitspower TOP Acetal
DEMI WATER
Killer Coil 99.9% Silver
Extra Cooling parts:
EK-PSC Schroeffitting Black Nickel
EK-CPU Easy Mount HF - Black
Tygon R3400 - HighFlow - 3/8 ID - 1/2 OD - Black
Bitspower G1/4 Matt Black Low Profile Stop Fitting BP-MBWP-C09
Bitspower Crystal Link Tube For 2-Slots (SLI/CF) BP-CLTAC-S3
Bitspower Schroeffitting Paar - G1/4 (2 stuks) Matt Black
Bitspower G1/4 Temperature Sensor Stop Fitting
Scythe Gentle Typhoon 120mm 1850rpm
Scythe Slip Stream 120mm 2000RPM Slim
Extra Materials:
MDPC-X Sleeving
Led's by wwwicked Red
120MM Scythe Fan Guard12 SFG12-SL
List can still be updated
U can find more pictures or builds at www.cygnitr0n.nl
Again a new package!
So, and here we begin, screwing the nice Mosfet off (sorry that u have to go m8)
And cleaning everything with the Artic Cleaning Set.
This is a beautifull piece of EK. The Acetal Mosfet Block.
And the CPU getting the Acetal Top <what a work! $%(%# rubber>
EK-CPU Easy mount, very nice!
Tygon Black Tubes, keeping it black.
And for just a little modification, I made the stickers for the RAM with aan ROG look.
There they are.
The first one done
and the rest..
And this is how it looks on an Asus Maximus IV Gene-Z.
Cygnitr0n is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
