Reply
Thread Tools View Mode
Old 3rd Apr 2012, 15:56   #1
Overminde
Multimodder
Overminde's Avatar
Overminde has yet to learn the way of the Dremel
[Project] Urban Camouflage [Updated 28/5 =)]
After a project that was only posted in Portuguese forums we decided to try and extend boundaries so here we are to try our luck on Bit Tech.
Like I said before our first project was well accepted in the Portuguese Gaming community so we will be trying to exceed the expectations on our next project that goes by the name of “Urban Camouflage”.
Our project has the intention to restore an old server case, that even bein a bit old has some excellent finishing touches. Just like our past project we will be using a full water cooling system on a case that has no kind of support for it.
All the case water blocks will be personalized, the paint job will be done in Urban Camouflage so will the radiators and the major components inside the Case. The side panel will have an acrylic window to show the motherboard.
Has a newbie in Bit Tech I hope you guys can throw some opinions and critics that can make this project grow =)
News will come soon so stay tuned.
Our Sponsors for this project are:
NOX -
Corsair -
.: SYSTEM :.
• [Case] – Old server case
• [CPU] - AMD Phenom x6 1055T
• [Motherboard] - Asus SABERTOOTH 990FX
• [Memory] - GSKILL PC3-14900 8GB Sniper CL9
• [SSD] - 2x Corsair Force GT 120gb
• [Graphic Card] - XFX ATI Radeon HD 6950 2GB
• [PSU] - NOX Hummer M 750W
• [Optical Drive] - N/A
• [Mouse] - N/A
• [Keyboard] - N/A
• [Phones] - N/A
• [OS] - Windows x64 7 Pro
.: COOLING:.
• [CPU] - Personalized Block By ModGamer
• [Motherboard] - Personalized Block By ModGamer
• [Graphic card] – Personalized Block By ModGamer
• [Radiator] - N/A
• [Pump] - N/A
• [Reservoir] Personalized aluminum reservoir By ModGamer
Some Pictures of the Case still in one piece and it all disassembled. Hope you like them and sorry if you don't understand something i say since I'm not English
Overminde is offline   Reply With Quote
Old 3rd Apr 2012, 16:09   #2
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.
Nice case and good start.
I watch.
john
__________________
Coming to a forum near you. January 2014.
jhanlon303 is offline   Reply With Quote
Old 3rd Apr 2012, 19:29   #3
fr0Zen
sabertooth 990FX
fr0Zen has yet to learn the way of the Dremelfr0Zen has yet to learn the way of the Dremel
sabertooth = subbed
mod on
__________________
http://forums.bit-tech.net/showthread.php?t=249950the big thing
fr0Zen is offline   Reply With Quote
Old 5th Apr 2012, 11:32   #4
Overminde
Multimodder
Overminde's Avatar
And some hardware starts to arrive
Fans NOX NX 120mm
Heheheh seams that there is something more in the box and not just fans
PSU NOX Hummer 750w Modular ZOMG hehehhe
Hope you like them and let me just thank NOX Xtreme for their help specially Rogelio, hope you like this.
__________________
Urban Camouflage
Old 5th Apr 2012, 15:25   #5
Rosas
What's a Dremel?
Rosas has yet to learn the way of the Dremel
Like It
Rosas is offline   Reply With Quote
Old 5th Apr 2012, 15:31   #6
Overminde
Multimodder
Overminde's Avatar
Nox fans will have a custom paint job with the same color as the Case itself.
__________________
Urban Camouflage
Old 10th Apr 2012, 14:06   #7
Overminde
Multimodder
Overminde's Avatar
One more shipment , small in size Big on Quality
Big thanks to Corsair specially Gareth.
__________________
Urban Camouflage
Old 10th Apr 2012, 14:21   #8
Rosas
What's a Dremel?
Old 11th Apr 2012, 08:58   #9
Overminde
Multimodder
Overminde's Avatar
The catia render of the case
This is the case in its original state we re going to start the design now to implement the modifications
Hope you like it
__________________
Urban Camouflage
Old 11th Apr 2012, 19:36   #10
dirky90
Supermodder
dirky90 is the Cheesecake. Relix smiles down upon them.dirky90 is the Cheesecake. Relix smiles down upon them.dirky90 is the Cheesecake. Relix smiles down upon them.dirky90 is the Cheesecake. Relix smiles down upon them.dirky90 is the Cheesecake. Relix smiles down upon them.dirky90 is the Cheesecake. Relix smiles down upon them.dirky90 is the Cheesecake. Relix smiles down upon them.dirky90 is the Cheesecake. Relix smiles down upon them.dirky90 is the Cheesecake. Relix smiles down upon them.dirky90 is the Cheesecake. Relix smiles down upon them.dirky90 is the Cheesecake. Relix smiles down upon them.
raid 0 i presume??
dirky90 is offline   Reply With Quote
Old 12th Apr 2012, 08:08   #11
Overminde
Multimodder
Overminde's Avatar
Originally Posted by dirky90 View Post
raid 0 i presume??
Ho yeah already tested them, they are soooo FAST
__________________
Urban Camouflage
Old 12th Apr 2012, 12:14   #12
dirky90
Supermodder
I bet, I have a raid 0 vertex 2 setup at the moment. not sure if i should upgrade but thats by the by.
keep up the good work!!
Old 13th Apr 2012, 09:26   #13
Overminde
Multimodder
Overminde's Avatar
Sorry for the late reply well i dont know whats your setup cause to really take all of this babies you need a good sata III controller i can get almost 1gb/s of speed from them im really happy with this setup and my sata controller isnt the best for them. See a pic from Atto benchmark i did bellow:
__________________
Urban Camouflage
Old 16th Apr 2012, 08:25   #14
Overminde
Multimodder
Overminde's Avatar
Some more of the drawings
This is the "mid plate" that will divide the water cooling system radiators from the botherboard
It will have a preventive draining system so any drain will not fall on top of the motherboard or in the graphic card.
Chapa já aplicada na caixa.
__________________
Urban Camouflage
Old 19th Apr 2012, 15:38   #15
Overminde
Multimodder
Overminde's Avatar
We are proud to announce PikaPedra as our sponsor, PikaPedra is an airbrushing store that also does painting jobs follows a picture of the paint job he will be doing on our case, Thank you very much Pedro from http://www.PikaPedra.com/
PaintJob:
PiKaPedra:
__________________
Urban Camouflage
Old 19th Apr 2012, 16:22   #16
failariel
What's a Dremel?
failariel's Avatar
failariel has yet to learn the way of the Dremel
nice!!! good work
failariel is offline   Reply With Quote
Old 20th Apr 2012, 17:46   #17
Overminde
Multimodder
Overminde's Avatar
Originally Posted by failariel View Post
nice!!! good work
Thks mate
__________________
Urban Camouflage
Old 2nd May 2012, 08:22   #18
Overminde
Multimodder
Overminde's Avatar
Radiator fit tests:
2x Black Ice 360mm in sandwich, with 6 fans NOX NX 120.
Its time to disassemble and clean it all up=)
__________________
Urban Camouflage
Old 2nd May 2012, 14:57   #19
Cown
Multimodder
Cown's Avatar
Cown has yet to learn the way of the Dremel
Looking good, love the fans
__________________
Finished Projects:
ROG Meets Lian Li - Picade - Mr. Wallmount - Milk on the Wall WIP: The Iron suit project
Facebook page:
Cownbuilds
Cown is offline   Reply With Quote
Old 2nd May 2012, 17:59   #20
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
yeah old server cases are cool
dream1 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
